Spinning doesn't take place during spin cycle
I have a Whirlpool Stylemaster 4217141 washer that doesn't spin during the spin cycle. The water appears to drain out but I am left with clothes that are soaked due to spinning not taking place. Any thoughts as to what might be wrong and what part may need to be replaced.
  • 1 more comment
  • ajaymess Apr 21, 2009
    Thanks for the reply.
    The machine makes a humming noise but doesn't spin.
    Not sure if the hum is from the motor. I assume so but I am kind of new to this so I really can't say for sure.
    Would the switch still be the problem from what I have told you? Could it be that the timer is bad? Or is it more likely to be the switch?
  • ajaymess Apr 22, 2009
    My washer is still not working..
    The washer will fill up with water but when it stops all I hear is humming sound probably from motor and spinning doesn't take place. Seems like all the features of the washer work because the water will drain out during spin cycle but spinning action does not happen. Any thoughts of what part might be failing would be appreciated.
    Perhaps the timing switch??
    President:
  • 1,489 Answers
One possible problem is the door interlock switch. This switch prevents spinning when the door/lid is open. If the switch is bad (open/off all the time) it sends a false signal that the door is open and washer will not spin.
Does the machine just sit there when it's not spinning or does it sound like it's trying to spin but can't?
Posted on Apr 21, 2009
  • Samuel Charles Spriggs Apr 21, 2009
    Can you tell if the hum is from the motor running?
    If the hum is the motor turning, it's not the door interlock switch -- it's more likely the clutch.
    It is not likely the timer.
    You can check to see if the motor is running when the tub is supposed to be spining by taking off the panel and watching the motor during operation of the machine. This can be very dangerous -- so, if you don't have experience with it, I would suggest not doing it. Service call would be in order.
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Whirlpool stylemaster 4217141 rev
Check the water valve for continuity. Also check the screen on the cold water side to see if it is clogged. That is what I would do.
Oct 05, 2013 | Dryers
Whirlpool washer wont spin during spin cycle everything else appears ok.
Machine not spinning....check]
1..all water gone clean pump trap and check blocked drain
2....somehting stopping drum spin drum freely by hand.
3....too much soap use low suds soap and very little of it.
4....motor brushes wearing out...call for service for this one.
Good luck
T
Aug 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool GHW9250ML is having problems spinning
My Whirlpool Front Load Wasehr Model# GHW9250ML is having problems spinning on the final rinse cycle. The machine shuts down and the letter F appears on the digital read out.
Mar 06, 2010 | Whirlpool GHW9250M Front Load Washer
My Whirlpool stylemaster 907675 Washer wont spin.. The lid switch is fine.. Washes fine and all other cycles work.. just wont spin.
Hi, stylemaster washing machine won't spin on the top half. The bottom part spins perfect. the top doesn't seem connected. What
should I do ?
TIA
RJ
Jan 08, 2010 | Washing Machines
Spin Cycle "Whines" and keeps spinning after cycle is complete
need make & model # to correctly solve problem, it could be timer shorted or the drive motor has gone bad.
Oct 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Will not drain or go into spin cycle
Definetly the lid switch has been knocked out of place or has gone bad.
Aug 26, 2009 | Whirlpool Washing Machines
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
Whirlpool Stylemaster 4217141 tub not moving wash/spin cycles
Sounds like the drive belt is broken or very loose. Take off the back and check the belt. If loose or missing, tighten or replace. This is usually done by loosening the motor support bolts and moving the motor until the belt is tight, then re-tighten the bolts. Replace belt in the same way.
Apr 22, 2009 | Whirlpool Washing Machines
Whirlpool stylemaster 4217141 REV A Agitator/spin cycle broken
I have exactly the same problem as Jonthan, what's the solution?
Dec 24, 2008 | Washing Machines
Washing Machines Logo
414 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
