Question about TruTech PLV1615T 15 in. LCD Television
TV flashes very brief image and goes off when attempting to turn
Can hear a very faint sound at rear of TV when set is plug in. Sound is not present when set is unplugged.
    Champion:
  • 367 Answers
Did you get this fixed yet?Please let me know.Thank You very much!
Tyler
Posted on Oct 06, 2009
Toshiba 37AV500U damaged thru HDMI input.
The lightning stroke has been effected to the main digital board to your TV. It will be best to replace the main digital board as card basis, rather than trying to repair it. Before replacing the board, a through checkup should be done. Contact any expereienced service technician for help, as this work is a very skilled one. No body can predict about the damages to a lightning stroke, as there will be trillions of voltage present for every stroke, and even a slightest voltage can damage so many components in a TV like equipment, as it is designed to work for 110 or 220VAC.
Jul 07, 2012 | Toshiba 37AV500U 37 in. LCD TV
My tv toshiba 51'' rear projection wont come on, no sound or image but i hear a click when turn on and off.
most common reason is convergence problem--unsolder both chips and see if set will power up with them out of the circuit.
May 02, 2012 | Toshiba 51H94 51" Rear Projection HDTV
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
Whenever i plug the unit in i hear a clicking sound from the back of the television it is for about 3 seconds and it usually takes 2-5 seconds before it starts the noise. The power light only comes on for...
Ur tv turn on now,hear alot of clicking?The tv LED light "lamp" on front panel flashes or light up?The tv projection lamp is dead.The Ballast board dead too,if hear alot of clicking?The ballast board help to ignite the projection lamp.
Jul 16, 2010 | JVC AV-56P575 56" Rear Projection...
Panasonic LiFi model number PT-50LCZ70. Have red lamp light flashing on front 2 times. Have tried to turn it on and get no picture and no sound at all. I checked and the fan is running. What now?
After the red 2 flashing starts, press the power button on the front of the TV and hold pressed down for ten seconds.
You will hear a faint click comming from the back of set.
After 10 sec release the button and wait 10 more seconds then press the start button and release right away.
The green light flashes and the bulb attempts to start.
I found my picture will turn on on the third attempt of the bulb restarting.
When you do this and the room is dark you can see the bulb attempt to restart, My bulb has restarted on the third restart every time.
(note: The three start attempt happen after I do the button pressing
1 time and I do not need further button pressing restarts.
I think panasonic needs to let us know what the problem is.
I called Panasonic and they told me to plug it into a wall plug by itself.
I have it plugged into a multi plug adaptor now and have not tried this yet.
Nov 06, 2009 | Panasonic PT-50LCZ70 50" HDTV
No sound when the tv is on and the mute is turned off
I still am unclear as to your hook up but lets try this, if you have your DVD/VCR plugged into the TV audio and video and a audio cord from the tv monitor out to an input on the reciever, this way you should hear the sound at the tv and reciever.
However if you have your DVD/VCR plugged into the reciever first audio and video connections made at the reciever you should just have a video cord fromthe monitor out of the reciever to the tv and your audio will come from the reciever
Feb 25, 2009 | Panasonic PT-52DL10 52" Rear Projection...
No image and sound on the rca hdtv 50' power button flashing
sounds like a fly back problem
have a qulifyed tech check this out its high voltage leaking you are hearing.
esp if its a sqweek hiss sound.
Jan 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
No Picture No Sound
I think you have a short somewhere inyour set most likely the horizontal output transistor which may have shorted by the high voltage transformer going bad. The faint ticking sound that you hear is the power supply trying to start but the shorted load won't let it. Stargazer
Apr 22, 2007 | Samsung TSL3099WHF 30" TV
TruTech PLV1615T 15 in. LCD Television Logo
78 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
