Question about Lexmark C524 Laser Printer
Printer leaves look of burn marks as granular shadow over page
While printer works and prints properly, there is a gray sheen looking like brownish-gray "burn" marks over entire page. When printing envelopes, the "burn" pattern is most pronounced over the seams of the envelope -- revealing the envelope flap pattern on the front of the envelope.
  • 363 Answers
If the paper really is being burnt then there is a fault with the fuser roller temperature control. This would also make a smell. If this gray sheen is made of toner then this may be the laser unit not putting out enough power. The optics could be dirty. One thing to try before attempting repair- Reduce the print density to minimum in the printer advanced settings. This increases the Laser power. Good luck
Posted on Sep 22, 2007
SOURCE:
HP 6050 leaving black marks of the back of prints
you need to print clean page two or three times to clean printer path for toner , then check the last page you if there other black market , tell me , what black market looks like , hope that helped you
Mohamed Hejazi
Afaqnama Libya
[email protected]
Feb 25, 2013 | Office Equipment & Supplies
Printing from coreldraw 5 to zebra p330i
Sounds as though your printer is dirty, there are unfortunately no different color matchin schemes for this particular printer. The printer operates on an RGB interface, even though it prints using YMC. As far as the speckled look, this typically is due to dust during printing.
Aug 08, 2012 | Zebra P330i Thermal Card Printer
When we attempt to print it leaves black streak marks. At first it printed all black and when we went to setup under maintainence we chose alignment and clean cartridges. This worked however we still see...
If an inkjet printer gives white streaks where it should be black, it means the ink is very low, or there is dirt under the nozzles preventing it from printing properly, or, in the case of non original cartridges, ink might be leaking which prevents the bubbles of ink to squirt onto the page.
If the streaks are black where it should be white, is sounds like some dust or fluff below the cartridge leaves ink smears on the page.
Aug 23, 2011 | Lexmark X4650 InkJet Printer
Brother MFC-6800 1. Prints with 3/8" blank vertical line down the entire page; 2. Prints with a couple of 1/16" blank vertical lines down the entire page; 3. Prints with some gray shadow...
This solution is unconventional but it worked for me. The black roller on my MFC had irregularities on it and was creating horrible printouts. I pulled out the drum and cartridge and cleaned the large black roller. I used furniture polish to make the roller very smooth. Now it prints really nice.
Nov 29, 2010 | Brother MFC 6800 All-In-One Laser Printer
Brother 4070CDW Shadowing Problem
Check your toner if they are properly installed.
Check your drum if they are properly installed.
Clearn your toner and drum.
Print a test page.
If nothing happens please replace your printer drum
Sep 19, 2009 | Brother HL-4070CDW Printer
Printer won't print from my computer.
CHECK THESE THINGS IN THE CONTROLL PANEL, DEVICE MANAGER, NETWORKING AND SHARING, PROBLEMS AND REPORTS, SECURITY, WINDOWS SECURITY, WINDOWS FIREWALL.
NOT DOING THESE CHECKS IN THIS ORDER WILL BE A PAINFUL PROBLEM, CHECKING EVERYONE OF THESE AREAS, YOU WANT ALL GREEN MARKS, ************* NO
RED, ORANGE, YELLOW MARKINGS, THIS WILL STOP THE MACHINE FROM WORKING PROPERLY.*********************
THE SHARING AND NETWORKING WILL GIVE THE MACHINE AND THE OUT SIDE WORLD A WAY TO COMMUNICATE AND PRINTS AND SHARE DOCUMENTS.
LAST WINDOWS DEFENDER AND FIREWALL, ALSO WILL STOP DOCUMENTS FROM INTERING AND LEAVING THE COMPUTER.
I WOULD TURN EVERYTHING OF AND TURN ONE THING AT A TIME BACK ON UNTIL YOU FIND OUT WHITCH ONE IS GIVING YOU THE MOST PROBLEM. THAN TROUBLESHOOT THAT ON AT A LATER TIME WHEN YOU HAVE ALOT OF TIME TO DEVOTE TO THAT PROBLEM.
THAT IS ONE WAY THE OTHER WAY IS YOUR IS YOUR WAY.
ROD
Apr 08, 2009 | HP Officejet 4315v All-In-One InkJet...
Shadowing/graying with printing
Hi fa1103:
Gray background
1. Do not use media that has already been run through the printer.
2. Try using a different type of media.
3. Print a few more pages to see if the problem corrects itself.
4. Turn over the stack of media in the tray. Also, try rotating the stack 180°.
5. Open the Configure Device menu at the printer control panel. On the Print Quality
submenu, increase the TONER DENSITY setting. See the user guide.
6. Make sure that the environmental specifications for the printer are being met.
try these steps to see if they work for you.
pdouglasss
Dec 23, 2008 | HP LaserJet 2420dn Printer
HP 2420dn printing gray and shadows
maybe the scan unit need to clean first you most sure that the toner cartridge is original and new then start clean th scan unit reflector d9b88f3.jpg
Mar 12, 2008 | HP LaserJet 2420dn Printer
Shadows on prints
Hi, The problem your having sounds like a Fuser . The Fuser will cause printed text to give a ghosting look down the page were it repeats itself.
Nov 30, 2007 | HP Color LaserJet 2600n Printer
Lexmark C524 Laser Printer Logo
706 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
