Question about Microsoft Windows XP Professional
Windows will not boot
System keeps cycling back to the same screen.....
safe mode, last known configuration, start windows normally
it has done this before and a friend has fixed it, but he has moved and now I am stuck. We have partitioned the HD so that the OS is seperate from all the other stuff, because of this reacurring problem, but what to do now? One time I just let it run all night over and over and when I checked in the morning it was fine......I tried that this time..........some 24hrs later it was still cycling ???? ANY HELP PLEASE !!!!
  • pranjay May 11, 2010
    have you tried booting with last known good configuration?
    Problem Solver:
  • 5 Answers
Download and create a UBCD and boot that, then perform a hard drive scan. Note that UBCD is a great tool but sould be used with care. DO NOT REINSTALL WINDOWS WITHOUT BACKING UP (IF YOU CAN) YOUR WPA FILES - USE A BOOT USB STICK.
Your problem sound like a corrupt hard drive caused by Microshafts Windoze WPA - it 'corrupts' the hard drive so it renders it unusable (literally wears a hole in it! - it usually occurs after upgrading to SP3.) All had legal product keys as well. Also all units were attached ti the Internet (but were bulletproofed) with Windows Update activated.
Have had six of these beauties - all legal/legit - happen just after SP3 in the same hard drive area (under WPAxxx.dll) and expect a lot more. Different drives/all Dell/different legal keys, now all keys (sold OEM) counterfeit and Microshaft doing diddly squat.
Posted on Jul 05, 2009
    President:
  • Microsoft Master
  • 1,996 Answers
Have you tried interrupting the restart be selecting start with last known good cofiguration and pressing enter? I'd try that to begin with.
As it boots up, steadily tap on the F8 key, and when you reach the startup menu screen, choose that option and start.
Please have a look at this article and see if it applies to your situation. (If your system reaches the logon screen and then restarts the article does not apply.)
If you have Windows SteadyState installed, see here.
Here are a series of links to MS knowledge base article that will help you to diagnose and correct this problem...
And when it get it going again, if you haven't got recovery console installed, I recommend it. See here
Finally, this could be an indication of a malware infection. Do you have active and up to date antivirus program running on your system? Are you current with windows updates? If you get this up and running, I recommend you download and install Malwarebytes AntiMalware on your computer and run a scan to determine if you may have been infected.
Please report back and let us know how this works out...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 21, 2009
  • efs_perpends
    efs_perpends Apr 21, 2009
    What is the make and model of your system? Did you by any chance recently update to SP3?
  • 289 Answers
I would go into the BIOS as yopur machine starts up and set the machine to boot from your CD-ROM (make a note of the original setting). Insert your re-installation/repair CD and shut-down the computer. Restart and watch so you can "Press any key to boot from the CD." Follow the prompts and choose to "REPAIR" Windows. You should not need to perform a full installation. *Remember: Set the boot selection in your BIOS back to the original setting by following the first step.
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
My labtop came to a boot up screen that has the options: safe mode, safe mode with networking, safe mode with command prompt, last known good configuration, and start windows normally. i have windows xp....
Hello xderekhx716, to choose the [least] likely {Mode} in order not to "Lose any Data," you want to choose; "Start Windows in Safe Mode." If an incident 'occur' before this 'window' [Popped-Up], then you want to "Start the Computer in {Safe Mode}. This 'way if you have been "Infected by a 'Virus' or any of the Computers Configurations have been 'changed,' or "Windows Shut Down 'Unexpectedly' than Safe Mode is the 'choice,' because the; least amount" of Operating Systems, applications will be deployed at "Startup," ie. Drivers, Programs... This will 'protect' the System' from further 'damage', if there was any? You will have the opportunity to analyze the situation safely. Next, if the Computer is having 'problems' starting, or the "Operating System is not 'responding' or there is "no change, than a "message" will identify the 'still' remaining problem; "Starting Normally." Then you want to 'choose,' start Windows at the "Last Known Good Configuration" also known as "System Restore." Finally, if this was just a "simple "Shut-down?" Than, "Starting Windows Normally" is OK! Follow all the instructions "carefully" in any of the "Modes" you may need to [Choose]. I hope this information is helpful? Thanks for using FixYa, paul7of9"
Feb 08, 2011 | ASUS Eee 4G Notebook
Received 512 - chassis fan error on HP Compaq dc5100 ff - I replaced the front chassis fan after detecting fan was not working now when I attempt to log into windows - windows screen appears than...
By enforcing the option to return BACK TO THE LAST KNOWN GOOD CONFIGURATION you have nothing to lose. Respond if you have already selected that option with no success?
Bruce
Jan 12, 2011 | HP Computers & Internet
The computer will not boot up, keeps going to the screen that gives the option to saft modt thru start windows normal
Problem :
system wont load Solution :
when you see the SAFE MODE menu select "Last Good known Configuration".
if that dont try to boot on SAFE MODE and do a restore point to previous date
Aug 20, 2010 | Acer Aspire 5520-5908 Notebook
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
My Dell Inspiron 1525 will not start up all the way. It was fine last night but all I get now is a black screen the the mouse showing. I can't turn it off unless I hold down the power button. I don't know...
boot computer when it first starts up push F8 for advance menu. in advance menu select last known good configuration. hit enter . if the computer ges to desk top do a system restore . to before the issue started. if this fails you will need the windows disk to do a system repair. your configuration may be corrupted.
Nov 16, 2009 | Dell Inspiron 1525 Notebook
WHAT TO DO IF MY SONY VAIO WON'T START?
Hi there.
Choose "LAST KNOWN GOOD CONFIGURATION" if it still won't boot up try "SAFE MODE" and perform a system restore and take the computer back a week or so.
Good luck and thanks for using FixYa!!
May 13, 2009 | Sony VAIO VGN-FJ270/B Notebook
Booting problem
You may have to boot from a CD and make a repair.
Once logged in the CD, choose repair option (Recovery Console), and type these three commands:
1) fixmbr (wait til it finishes)
2) fixboot (wait...)
3) CHKDSK (this will take longer than the previous two.
Your laptop may now boot normally. I think your laptop doesn't have an internal CD-ROM so you may use an external USB CD.
Apr 22, 2009 | Computers & Internet
PC notebook will only start in safe mode.
Try doing a System Restore, once you have booted up in Safe Mode, to a time before you had the problem.
Hope this helps
Chris (ziraffa)
Jan 02, 2009 | Computers & Internet
Boot-up
dot.gif How to load last known good configuration. Question: How to load last known good configuration.
Additional information: The "Last Known Good Configuration" option was first introduced in Microsoft Windows 2000 and is available in all later versions of Windows including Windows XP. This feature enables a user to load the last working version of Microsoft Windows. This is a great step to try when trying to fix issues with a computer not being able to load into Windows.
Note: Users able to open normal Windows XP mode and who wish to restore their version of Windows to an date before the last known good configuration may also wish to consider doing a system recovery in Windows. Additional information about how to do this can be found on document CH000589.
Answer: To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key. Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP safe mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the safe mode screen.
Please select an option: Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows. Will running the Last Known Good Configuration delete anything? No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Dec 06, 2007 | Computers & Internet
Microsoft Windows XP Professional Logo
65 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
