Question about HP OfficeJet 6110 All-In-One InkJet Printer
Scanner is not seeing the computer
The printer will respond to a print command but when I ask it to scan something to the computer it says that it cannot connect to PC. I'm running a MacBook Pro and haven't used this printer with it before, I had only used it with my older computer. Is there a setting I need to do...
  • 25 Answers
Try this link to see if it will resolve your issue, seems to be a common problems on Macs that have newer operating systems.
Posted on Apr 23, 2009
I have a canon MP730 and it is connected to my HP computer. I can print a word processed document and any material online onto the MP730. However, I am not able to command the scanner from my HP...
Theres a few things you can do, HP normally makes you install a slew of programs with the driver, see if you can find the program called something like "HP Scan" and try to use that to scan things. If that does that work, reinstall the driver.
Hope that helped!
May 04, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
Copy to Dell computer
I guess you was asking if you can use the scanner and make a scanning and than import the scanned image or document to the computer ..yes..this is possible but the scanning has to be initiated from the software that came with the device for scanning ..and command the scan from the software after that will be in the library of the software ...of wherever you save it ..If you do not have installed a software to manage the scannings go to the Lexmark support ..and there choose teh model from the list and download scanner software ..and install in the printer ..(remember this software is something different than the driver ..The driver is just to communicate ..this is to operate the scans from computer and import the result)
Jun 02, 2010 | Lexmark X2470 All-In-One InkJet Printer
My Kodak ESP 3 Won't Scan
Did you install the full software driver for the all-in-one? The drivers are here: http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9103/12666/12667&product=EKN034524
Next try a new USB cable and plugging the unit into a different port. If you use a print server or USB hub, try connecting directly to the computer. Scanners need bi-directional communication with the computer and thus are likely to have issues even if the printer doesn't.
Can the scanning software on the computer initiate the scan? (That is in the full software package. Alternatively Vista came with Paint and File> Import from Camera or Scanner > New Scan.)
I hope this helps.
Apr 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
SCANNER does NOT respond.
You need to have scanning software installed as well, when you press scan a program should open on your computer to accept the scans. Check in control panel then scanners and faxes and see if the scanner is there.
Jul 20, 2009 | Brother Multi-Function Center MFC-240C...
My kodak esp3 will not scan it prints and copies.
I had the same problem and I got it to work. I have Windows Vista and Microsoft Office 2007 on my computer. Here's what I did...
Go to "Start" then "Control Panel".
-Click on "Programs and Features".
-Scroll down to Microsoft Office Home and Student 2007 - click on that and then click on the "Change" link above.
-A box will pop up, click on "Add or Remove Features" and then click "Continue".
-Click on the "+" next to "Office Tools"
-Click on the "+" next to "Microsoft Office Document Imaging"
-Click on the down arrow next to "Scanning, OCR and Indexing..."
-Then, click on "Run from my Computer"
-Next click on "Continue" at the bottom of the dialogue box and your configuration process should begin
Once completed go to the start menu and type in "Scan" into the search box. Go to "Microsoft Office Document Scanning" Once there, plug your scanner into you computer, chose what color you want your scan to be in, and click on the picture of the scanner to the right. To make my scans clear, I had to click on "Scanner..." and chose KODAK ESP AiO as my scanner even though I have a KODAK ESP-3 printer/scanner.
I hope these instructions weren't too confusing and I hope this helps some of you out! My scanner was causing me a lot of frustration for a while!
May 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Can I scan through a wireless network connection?
hmmm...well..that's an interesting point..according to HP site, this is NOT supposed to be an issue. Seems, though, that perhaps, the print server/hub you are using, is not processing the scan command? I'd check that item first, to see if it will handle those commands..
Jul 15, 2008 | HP OfficeJet 7310 All-In-One InkJet...
All in One Printer/Scanner/Copier will not respond to print command.
Pls make sure that your computer recognizes your Printer, if it doesn't it would never respond to any print command you sent
check to see (if the computer recognizes)
1- go to start then select printer
2- select your desired printer - right click
3- go to properties
4- select print PRINT TEST PAGE
5- check the message on your paper
if it doesnt then you might have installed a wrong driver
Jul 14, 2008 | Office Equipment & Supplies
Problem with scanner
Try to get the scanner operating by using a programme such as paint (open file from scanner or camera) or powerpoint (insert picture from scanner or camera). I have used this with success in the past. I have not used the scan button so I cannot advise you on this.
Hope this at least gets you going with scanning a copy of something and once you have it in these programmes you can at least print it and make some changes that you desire.
Hope this helps.
Youre right - they are a great printer!!
Johnca51
Apr 29, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Hp 1350 printer will not scan.
You need sofrware that captures the scan from the scanner. usually comes with the printer, you have to opemn the program and tell it to scan and save.
Scanning by just placing a paper on the scanner and pressing the scan button just tells the printer to scan and probably print a copy, but it doesnt send it to the computer unless theres a program asking for it. Check the installation cd and go through the software that came with it.
Jan 30, 2008 | HP PSC 2355 All-In-One InkJet Printer
CAN NOT SCAN FROM PRINTER TO COMPUTER
New Computer is it? Vista- yes? Big troubles with drivers for scanners from vista. Scanners have a built in processor that runs all its operations on command from the computer. Vista is not speaking the same language the scanner wants to hear. Got onto HP tech support- I don't hold out much hope for you re this.
Jul 08, 2007 | HP PSC 1610v All-in-One Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
125 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
