Question about Dell E153FP 15" LCD Monitor
Monitor not staying on
My dell monitor is tripping off as soon as soon as the cpu comes on
I had this problem with two E153FP monitors. I cracked open the case, yes cracked, there are no screws just two slots at the bottom where you can pry it open with a screw driver. Pry around the edge and it opens up. Then you can disassemble down to the power supply. Find a large 1000uF 16V electrolytic capacitor and replace it. I did not have a 1000uF 16V cap, so I used a 940uF 50V cap. It works and I think the higher voltage rating will make it more reliable.
Posted on Apr 29, 2008
  • 472 Answers
Try this...
Leave the monitor off.
Turn the PC on and watch the hard drive light flicker.
After a minute or two it should stop or at least slow right down.
Turn the monitor on and see if you can see the desktop. (in some cases you may only see the DELL screen before it cuts out again. If so, then just leave it on and use a good torch shining down from the top at an angle to the screen and see if you can see your desktop that way..it will be very feint)
If so, it will still cut out very quickly, but it is a fault in the inverter circuit on the power board in the monitor.
A trip to your local TV technician will have it back up and running quickly and should not cost that much to have repaired.
Posted on Apr 08, 2008
6ya staff
SOURCE:
Monitor stays in "Power Save" mode
if u r reples this monitor pls. call me dear
tek a new monitor from me same model
Nov 27, 2012 | Dell ST2410 Monitor
When powered on led comes on and then off. monitor is now black and wont come on.
Hi. Try to run the diagnostics by turning the computer on, press F12 on Dell logo, select boot to utility partition and press enter.
If it doesn't have utility partition, then try to remove the video card and put it back in... then turn the computer back on.
If it still doesn't stay on, then you might have to replace your motherboard or buy a new desktop CPU.
Nothing is wrong with your monitor though.
^_^
Jun 06, 2010 | Dell P991 19" CRT Monitor
L1718S won't come on
hi
my dear LCD monitor dosn't have power saving mode it's from your CPU
may be you have problem with your Display setup from your CPU
May 17, 2010 | LG Flatron L1750S 17" LCD Monitor
Dell LCD power up issue
I suggets you try your Monitor with another pc and see if its behaving the same if the same then the monitor is bad
Now if there is change ie its showing on the other PC then your pc VGA card is faulty or is not seated correctly on its slot pls check this,
Also swap VGA cards this how you will know its status .
Last get another VGA card
Good luck
Nov 13, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
When I start my computer my Dell S199WFP Flat Panel Monitor does not go on and stay on. It comes on for about two seconds or and switches off. I have to turn it on about 20-30 before it will stay on. While...
Hello
You have capacitors on the monitors power supply that have changed value. Soon they will keep the monitor from turning on at all. Send it to a company like mine or take it to a local repair person.
Aug 02, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Monitor going to sleep
turn off the hibernation mode if it is turned on.
Jun 15, 2009 | Dell Dimension 3000 PC Desktop
Dell monitor 15 inch the green light stays on but no picture
It's the backlight supply tripping out from backlight failure, but the thing still stays on. I got it to act right by switching to factory presets with some fast menu action once, but the general solution is going to involve tricking the backlight into staying on; you can look at the thing in bright ambient light to see that the display is still working, but of course without a backlight it's pretty much useless.
Since $100 buys a better and more efficient monitor, just replace it; otherwise of course you can either replace the backlight (or go for one of the projector mods) or convince its drive circuit to put up with it a bit longer. I spotted a bad capacitor but swapping that out hasn't gone well yet....
Mar 14, 2009 | Dell E153FP 15" LCD Monitor
No signal from cpu
i think you should check if the sync wires are properly connected both on the db15 connector and the main board
Jan 30, 2007 | Samsung SyncMaster 753S 17" CRT Monitor
Dell E153FP 15" LCD Monitor Logo
96 people viewed this question
Ekse
Clive
Clive
Alun Cox
