Question about Philips Magnavox 51MP392H Rear Projection Television
8P6044 Works great on Analog. How will it look as an HDTV Monitor?
    Sergeant:
  • 395 Answers
Try looking out doors, the picture will look that awsome remember that the differance between 480i and 1080i horizotal resolution is 600i lines. more lines better picture. the differance between interlacing and progressive scaning is also a factor. dvd players now have progresive (480p) output but you must set the player to output this to your tv and can only be YPbPr or RGB or HDMI to produce this type picture. S vid or composite vid can never produce this type picture. 480p equates to 960i so it is line doubled. just as 720p equates to 1440i even better than 1080i.
Posted on Sep 22, 2007
Have a Westinghouse HDTV ...using it for a computer monitor only...pc comes in great...but no sound...connected them with a 15 pin analog VGA cable and a stereo mini cable for sound
Have you installed the driver for the monitor? Look for the cd that came with it and install it to your computer. If the driver is already installed, then update it. You can use RadarSync to update all.
David
Apr 02, 2013 | Westinghouse SK-19H210S Television
No signal analog
Can you still see the boot up screen when you start your machine up?
If you do, then restart the system.
As it's booting up, you tap F8 until you get a menu. Select "Last Known Good Configuration". That will help if you installed a bad driver for your graphics.
If that doesn't help, or if you don't get a picture at all, plug the monitor into another computer and see if it works.
If the monitor works and you still can't get a picture after following the aforementioned steps on your computer, you may need to replace the video card on your system.
Jul 12, 2009 | ViewSonic VA721 17" LCD Monitor
Magnavox projection tv model 8P6044 C102 is very
The CRT fluid is cloudy and should be replaced. Goto www.TvRepairKits.com. They have a kit to do it yourself.
Ed
Jun 21, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
No analog signal
Sounds like the graphics card is gone belly up. Try the monitor with another pc or just replace the graphics card.
Hope this helps
Jun 12, 2009 | ViewSonic VX2235WM Monitor
HDTV as pc monitor-no digital signal
Try different Resolutions/DPI and Refressh rates the other possibility is settings on the monitor check the manual of the monitor for use with the pc as in resolution etc.
Newer monitors oftem change there own settings to best suit themselves or act differently if forced to use different settings.
The returning to 16bit seems odd though only other suggestion is trying updated video card drivers from the vendors site.
Mar 18, 2009 | Computers & Internet
Inoperative monitor
Here are a couple things to try.
1. try the input select button on the monitor (The minnus button) without pressing the OSD menu button 1st, see if it changes to analog.
http://support.us.dell.com/support/edocs/monitors/1703fps/en/controls.htm
When the DVI self-test screen is up, it is indicating monitor is in DVI mode.
2. If that doesn't work, try a DVI to analog converter on the DVI port on the monitor and connect the analog cable to the converter. See if you get any video that way.
3. If you can access the On-Screen Display (OSD Menu) perform a factory reset.
Sep 29, 2008 | Dell UltraSharp 1703FP Flat panel TFT 17"...
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
No analog stations on my hdtv 37 inch, have no digal box just regular cable, regular cable works on normal tv
Try an antenna if you want to get analog over the air. I have a feeling that with the way the standards are changing, you will only be able to get digital channels. After February, the analog channels won't be around.
If you are using cable tv you need an HDTV box to get high def.
Jun 13, 2008 | RCA HD52W59 HDTV Projection Television
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
Philips Magnavox 51MP392H Rear Projection Television Logo
74 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
