Question about Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer
What stacker wash dryer has the least problems and out lasts the others?
  • steve
    steve May 11, 2010
    None are without problems. Different brands express different problems.
    What problem are you having? It can be fixed and maybe suggestions to prevent future problems.
  • 1,889 Answers
Maytag
Posted on Apr 21, 2009
Any particular problems with installing whirlpool stacker washer/dryer in RV
the main problem is how stable the foundation is for the laundry center when it goes into its spin cycle.
Sep 11, 2012 | Whirlpool LTE5243D Top Load Stacked...
Water is not draining?
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | GE WSM2480DWW Unitized Spacemaker Washer...
Water does not come into machinetub -front load stacker
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
Changing dryer belt for lse7804ade washer dryer stacker
If the washing machine / tumble dryer / spin dryer seems to be making the right sort of noises, but the drum is not turning, unplug it, take the rear cover off and check to see if the drive belt is still intact and on the pulleys.
Mar 09, 2010 | Washing Machines
Hi there. My stacker frigidaire model mlc275cw5
You have to take the front off and remove the drum. Our local appliance parts shop had the element in stock.
Oct 14, 2009 | Frigidaire FPDW1 Top Load Stacked Washer /...
Water leaking from stacker unit
No parts are replaceable within the pump. Buy a new pump.
Jun 22, 2009 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool stacker washing machine works dryer doesn't
The problem is probably with the outlet. The washing machine motor is 120 v and the dryer is 220 v. If one pole of the two pole breaker is bad you could end up with the symptoms you have. I have seen this happen before. go to the circuit breaker and push it all the way to off (it may feel like you are crunching something inside...don't worry) then turn it back on and try the dryer. If this doesn't work, unplug the unit and test the outlet with a voltage tester. you should read 220-240 volts across the two slots and 120 volts from each slot to ground. If not, it is time to call an electrician.
Jun 22, 2009 | Dryers
Won't run
sounds like your lidswitch.when you close lid you should hear or feel it click on and off.located on back side of lid in center.
Mar 10, 2009 | Maytag LSE7806A Top Load Stacked...
Model SE9900 Maytag Stackable Washer/Dryer - 9E Error
According to my data, a 9E error indicates door latch malfunction.
Apr 21, 2017 | Maytag Washing Machines
Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
104 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
