Question about Dryers
Electric dryer won't heat
My amana electric dryer, aprox eleven years old, does everything but heat. I have checked the breaker, and the air vent, they are good, I have the front off the dryer, but don't know for sure where the thermostat is. I am a widow on a fixed income, and not sure if i can afford to get this fixed, or should i just get a new one. Please help
    Problem Solver:
  • 16 Answers
The problem may be the heating element look for a break in the element most of the time its element be for the thermostat . goodluck
Posted on Apr 21, 2009
    President:
  • 1,489 Answers
The problem is most likely one of the thermal limit switches/thermostats which is bad -- there could be several of them. Or, it is less likely that it is the heating element or a loose/corroded/broken connection to the heating circuit.
I would call for service -- it would be less expensive than a new dryer.
Dryer runs fine not heating up the air flow from the vent is good reset breaker still no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 08, 2010 | Amana NDE2330AY Electric Dryer
Breaker keeps tripping when I use Amana NED5500TQ electric dryer.
Heating element or motor. Usually heating element. Replace limit switch (inside dryer) during repair. Limit switch should shut off before breaker if working correctly.
After repair clean or replace plug/wire. Inspect or replace receptacle in wall.
Sep 28, 2009 | Amana NED5500TQ Electric Dryer
I have a Amana Electric Dryer NED5500TQ. When I
It is possible that you could have a bad breaker in the panel. They will start to trip randomly when they are going bad. If not the dryer is drawing too many amps and the breaker is doing it's job. If the heating element is defective and drawing extra juice that could trip the breaker. Usually replacement breakers are not too expensive if you electrical panel is less then 20 years old and can be purchased at most home improvement stores. I would try replacing the breaker before you try repairing the dryer. If you install a new breaker and the problem continues to happen then you should check the dryer heating element. That component is what draws the most amps and would be the most common one for tripping the breaker.
Sep 25, 2009 | Amana NED5500TQ Electric Dryer
Amana NEW7200TW (1 year old) runs, but stopped heating.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 30, 2009 | Amana NED7200TW Electric Dryer
No hot air
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Jul 15, 2009 | Dryers
Dryer won,t get hot
It's not a circuit breaker your chasing. Check your vent to see if it's clean. You could have a bad element.
Apr 12, 2009 | Amana NDE2330AY Electric Dryer
Dead Dryer
I would say to replace the motor. The only thing I would suggest is see where you have power and where you do not have power. If it is plugged into the wall outlet then you should have power going everywhere including the motor. If the motor has power and will not start up then replace it. But I would check EVERYTHING out and make ksure that it is the problem and nothing else is the problem
Feb 17, 2009 | Amana NDE2335AY Electric Dryer
LG Dryer overheating
check vent outlet out side house is it blowing out air.
Dec 24, 2008 | LG DLE5977 Electric Dryer
Kenmore 64942300 Electric Dryer runs, no heat
This may seem too simple of an answer based on your extensive troubleshooting thus far, but the most common reason for cold air running of any electric dryer is a broken heater coil. This is simply a coil of wire that is heated to warm the air in the fan duct. These often overheat and break if the vent duct is blocked, too long, or has odd bends that can restrict flow. Recommend replacing heater coil and use smooth wall vent pipe. Avoid coil type flexible duct.
Jul 03, 2017 | Kenmore 64942 Electric Dryer
It takes hours to dry small load
dud thermal sensor, the temperature is shuttimg off too low
locate, replace the thermal sensor just 'downwind' of the flame
Mar 26, 2008 | Amana NDG7800AW Gas Dryer
Dryers Logo
63 people viewed this question
Top Dryers Experts
