Question about Nintendo Wii Console
Wii one of my discs won't read in the console....when I put it in it says...unable to read disc.....it looks like the people who used it last may have scratched it up some but it doesn't look bad...i tried some smooth toothpaste....but it still won't read....I don't have a disc cleaner and my boys are anxious to use it...would alcohol work? The other game disc works fine but not this one....
  • lcofone16 Aug 03, 2008
    every game works except the only game i really wanna play, link's crossbow training! i put it in the system then it says error, remove disk and turn off wii console and contact wii troubleshooting! i tried to contact you people and all u wanna do is tell me to get a new wii!! i cant afford a new wii!! this one is brand new!! now please tell me why my game will not work!!!!!!!!!!!!!!!!
  • 752 Answers
Alcohol will CLEAN it, but if it's scratched in the right spot NOTHING will save it. Also be sure to use NON-abrasive cloth to rub with )like cotton, NOT paper towel).
Posted on Sep 22, 2007
SOURCE:
My wii won't read discs
Made a video showing how I fixed this exact problem on mine.
Jan 16, 2012 | Nintendo Wii Console
Wii consol unable to read discs
Wii is probably defected or Lens is screwed up or needs to get clean!  Happened to me!!!
Point number 1: Try getting dust out the fan... or try 2:by a lens cleaner the wii won't probably read it but it will try to so put alcohol or if it already comes with one , on the all brushes of the disc. And put it in your wii let it try to read. and when it saids it cannot read take it out and do what is listed next below which i wrote:
this will probably fix it do that about 3 times.
May 30, 2009 | Nintendo Wii Console
Wii will not play any of my games discs
Made a video showing how I fixed this exact problem on a Wii.
Mar 20, 2009 | Nintendo Wii Console
I got wii fit the disk wont work !!!!!!
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 27, 2008 | Nintendo Wii Console
Unable to read disc
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
188
Dec 25, 2008 | Nintendo Wii Console
Unable to read disk
139
Dec 16, 2008 | Nintendo Wii Console
Wii "unable to read disc"
If Wii gives Unreadable disc, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 04, 2008 | Nintendo Wii Console
Unable to read disc
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Jul 05, 2008 | Nintendo Wii Console
Unable to read wii discs
I had the same problem, I take it you have a modded wii(chipped), if you use a backup disc it is of a lower quality then original discs, the wii gets read errors without you noticing and tries to read those disc areas again sometimes suceeding and the gaming goes on, sometimes it fails, and a disc read error occurs. Over time the dvd assembly will take some damage it will loose it rigidity it once had and the wii stops reading discs. The problem gets worse if you have standing up, so first thing si to flip it down and try. Otherwise you (or someone you trust) will have to open the wii and adjust the lens sled so it wont flap as much up and down. Hope this helps..
Oct 01, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
156 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
