Question about Garden
My featherlite weedeater will only turn up on half choke?
  • Gabriel Figueroa
    Gabriel Figueroa Apr 22, 2009
    I have a Homelite that turn up on the full choke and run but when I move it to half choke or to the Run position, it won't run.
You have to adjust the h or highend carb screw. start up your engine on full choke adjust the screw up or down untill u can run it without choke
Posted on Aug 17, 2009
3 Suggested Answers
riceski
  • 1851 Answers
SOURCE: have a featherlite 25cc weedeater. can not get it
clean the carb - remove - clean and re-install it.
Gary @ Fix Ya
Posted on Jul 15, 2010
  • 32 Answers
SOURCE: I have a weedeater featherlite 20cc, and every
Look on the carb for two spring loaded screws, they may have a plastic cover over them. look where these to screws go into the carb, you should see an "H" by one, and an "L" by the other, stamped in the carb. Open the "H" one about 1/4 turn at a time with the engine running, that should fix it.
(you may need to remove the plastic covers to be able to turn the screws, you can throw that away)
Posted on Sep 20, 2011
My murray weedeater want run off choke why?
Carburetor needs to be rebuilt. I won't even think twice about. the diaphram is on it's way out.
Aug 29, 2017 | Weedeater Garden
I have a weedeater featherlite 20cc, and every time I start it it will only run on full choke, but of course that is not enough to power the line. I can slightly pull the choke up to the beginning of half...
Sep 20, 2011 | Husqvarna Garden
I have a featherlite FL20 weedeater that will start but will stop running as soon as I move it from full choke to half choke. I didnt have any problem until I ran it out of gas a week or so ago. Do you...
It seems like it is the carbaretor. There is a diaphram in there which is rubber. After awile it tends to get a bit hard so it will not pump the fuel into the carb. There are a few gaskets too that get worn out. If you buy a carb kit everything is included. The carb is probly a bit dirty too. I hope this helps you out.
Jul 15, 2011 | Garden
Will not run without choke on
wspring2, this is common with these machine, check you're carb adjustments. Low speed (closest to engine ) 1 and a quarter turns out, high speed 1 and a half out counter clockwise. You may have to put diaghram kit in carb. But if you have gotten a season or 2 out of it, probably not worth repairing. Sorry, hate to be the bearer of bad news, hopes this helps ya.
Dec 08, 2010 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
My Weedeater FL1500 blower starts set at full choke(stop position) but stalls at half choke. I replaced the fuel lines but have not attached the fuel filter, which I thought might be clogged.
The featherlite is notorious for the intake seals to leak, Thats the one behind the little plastic manifild. This machine vibrates terribly and usually shakes itself to death. JUst test by shaking the carb while its attached to the engine, any movement shows there is a leak. The engines are like people they allways look for the easyiest way, therefore if there is a place to get air, it will pull it from there, causing it to run lean
Nov 01, 2009 | Poulan Garden
Echo trimmer won't start, gasoline flows out of exhaust
look at choke and air filter. ensure choke is operating and clean air filter.
May 24, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
What is the gas/oil mixture ratio for the featherlite gas weedeater?
its a 40:1 ratio. remember to never tap the tap-n-go too hard or it will bend the shaft, and make the head hot to the touch, and eventually will melt the inside. And always keep fuel stabilizer in the gas, because if you dont, especially in winter and fall, it will clog the carb so you have to keep pumping the throttle to keep it running and you have to run it on half choke all the time
good luck!
,devin
Apr 25, 2009 | Poulan Featherlite Gas Blower, with Low...
Garden Logo
875 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
