Question about Cross Infoguard Shredder SX102M
The unit shuts down after using for 4-5 minutes and I smel burnig
I purchase this from Staples, it was fine for first 2-3 use. Now it shuts down after couple of minutes and burning smel starts if I continue to use. What do I need to do? Can someone help? Thanks
  • 23 Answers
Sadly, light duty machines as yours do overheat and shut off. Shredders are rated for run time. An example: 4 min run time with 60 min off to cool down. I could not find your machine's rating. However, given the 10 page volume I would guess the rating close to the 4 min on.
High volume shredders are rated as continuous run. They should never over heat.
Posted on Apr 21, 2009
I have a Staples Shredder model SPL-TXC6A (serial 0809026807), which I have been using a lot lately. The auto and reverse buttons will not function, & neither will the forward button.
If you have used it a lot, it may have tripped the thermal fuse. Normally, these reset themselves. One thing to make sure of,, is that the safety switch under the machine is firmly on the pin in the basket under it.
This is a light duty shredder, you can only use it for two minutes!
6-sheet, light-duty, up to 25 uses/day
Runs 2 min on / 4 min off
http://www.snoopdeal.com/bargain/43085/Staples-SPL-TXC6A
Nov 21, 2016 | Office Equipment & Supplies
What staples does a black and decker electric stapler 9700 take and where can I buy them?
Hi Stephen,
Of course the manual states to use their staples for best results.
However it does at least state it is designed for a wide variety.
Most hardware stores have a range of staples to choose from.
Home Depot, Harbor Freight, Lowes etc. Try a chisel point this may help penetrate the wood deep enough. All staples are not made the same. So again trial and error may be the quickest route. Fortunately you can purchase small boxes for your testing.
The manual for this stapler is here:
(Page 2 talks about the staples to use.)
Black Decker 9701 Instruction Manual Page 2
Good luck and hope this helps!
Jan 04, 2015 | Arrow Tools & Hardware - Others
I can't seem to reload staples into this stapler. I used the staples that came with it and it worked fine. I try reloading and it doesn't staple.
With the stapler sitting a solid surface, turn it 180 degrees so it is pointed away from you, and you are looking at the back. Press down on the plastic extension that you see (about mid-height on the stapler). This releases the staple-holding compartment (it shoots out the front of the stapler). Reload it with standard staples, push the compartment back in place until you hear a click. Voila!
Apr 15, 2011 | Staples One-Touch DX-3 Desktop Flat Stack...
I have a eiki lc-xnb5m projector that seems to be shutting down if it's ceiling mounted, but runs fine on a cart. I know it sounds strange, but, is there some sort of gravity sensor or levelling sensor or...
there is a heat sensor, i had a same problem, and it turned out to be this dumb thing, if projector get's to heated up it shut's down to save the electrical components from burnig out
Oct 29, 2009 | Eiki LC-XNB5M projector lamp Projector...
Staples SPL-770M shredder with overheat light even when cool
Just a FYI: I had the same problem. Nothing appeared jammed. But I took the housing cover off and low and behold the rubber roller that turns the shredders had MELTED to the inside. That's why it wouldn't work. This happened while shredding a single DVD - something I had done effortlessly on numerous occasions. You may want to check to see if the roller melted or if some debris has jammed up inside the unit, like mine did often.
Sep 10, 2009 | Office Equipment & Supplies
Vacuum cleaner makes a burning smell
spark is from brushes not to worry it's normal but you should change the belt
thumbs up
Aug 17, 2009 | Vacuums
My T50M Staple strips break up in the gun and jam after 4-5 staples. This happens with old staples (10+ years) and with new staples that were purchased two days ago. Out of frustration I purchased a new...
The staples are held together with an epoxy. I have used staples that are older than 10 years. The problem is the gun. Check for dirt or a burk in the magazine as well as a bent pusher blade. My gun also had a problem loosing a screw and nut that attached at the blade guide.
Jun 12, 2009 | Arrow T50P ARROW STAPLE GUN
Out of staples
in the menu /control panel choose the single or double sided copies w no staples
Jun 12, 2008 | Toshiba e-Studio 350 Copier
Shuts off itself
My 2720 just starting doing that today. used it fine for past 4 days on a trip, now it is acting up. Less than 1 year old
Sep 03, 2007 | GPS
Cross Infoguard Shredder SX102M Logo
203 people viewed this question
Top Cross Office Equipment & Supplies Experts
Computer Links
Ivan
Ivan
Level 1 Expert
k24674
Are you a Cross Office Equipment and Supply Expert? Answer questions, earn points and help others
