Question about Gigabyte GA-8SQ800 Motherboard
Screwed up bios update
I reinstalled Windows XP. I do not have the original disks for the motherboard. Windows would not accept the fact that there is a ethernet port nor would it allow me to use the USB 2.0 to set up a network. So, I had no way of updating the computer. Using another computer, I downloaded some update BIOS from somewhere. Yeah, probably screwed that up. After running the update program, it won't register my harddrive. So, I have nothing but BIOS and a CD Drive. No harddrive No accessible OS. How can I fix the bios? Where can I get the most recent BIOS? I couldn't find anything that worked from Gigabyte's website. Please Help
  • 293 Answers
Re: Screwed up bios update
Download the bios file only here and not other sites Gigabyte = then DOWNLOAD HIREN BOOT CD, WRITE IT TO CD THEN BOOT FROM IT and use the bios programming tools
Posted on Sep 22, 2007
0 characters
3 Points
P4m800pro-m v20 random reset I have windows 7. I
Your not going to be able to update the BIOS without having XP installed on the computer.
I had the same problem myself as a motherboard i had would not update with Win 7 installed.
If you have a spare hard drive and an XP install disk then i recommend installing XP on that and then download the exe BIOS update file and run it from within Windows to update the BIOS.
After that just turn the PC off, put back your Win 7 hard drive and your good to go.
Jul 02, 2010 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Original motherboard sound drivers from MB disk don,t work.
Here is a link to the driver page for your board.
updates and see if this is
You could try downloading the driver from the site..Maybe there is a problem with the one on the disk. Also check the BIOS updates and see if this is a known issue. They may have a BIOS update to fix this issue. Before installing the driver/software I would remove the current audio software and remove the audio from the device manager and then re-boot the computer. Then install the downloaded software and see if that works.
Sep 08, 2009 | Biostar TA790GX Motherboard
Want the best bios for Asus M2N68-LA motherboard to run on win xp
You don't need to change the bios to do that, you already have the best one.
Mar 14, 2009 | ASUS Motherboards
Bios not detecting bootable harddisk
Repair windows xp using bootable windows xp cd..
Mar 09, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
I cant install windows xp because of... i dont know!
Here is what you should do, go to a computer store and buy a 40G HD. Try installing on that. It could be the size, but most likly not. Im going to guess and say take a look at the bottom of your reinstall disk. If it has any scratches, there is your problem. NTLDR is your boot sector on you HD.
Mar 04, 2009 | Intel Motherboard
My Hard Drive is 250 GB but I only see 137GB
Windows xp has a max Hard drive limit of 137GB, so what you see is totally right.
Windows XP did not support 48-bit LBA for ATAPI disk drives, which is what larger drives needs.
The service packs do address the problem but you need to have a copy of windows xp which includes at least service pack 1 on the installation.
The problem is when you install from your original disk, it doesn't include the service packs, so by the time you have got the system up and running the hard disk space has already been allocated.
Bios update wont help
controller card won't help either
Possible solutions:
If you can get hold of a new version of XP which includes at least service pack 1, you can re-install with this disk and it should find all your hard disk space
You can do what is called 'slipstreaming', this is when you burn the original XP disk and the service packs together on one disk, but it does take a bit of working out.
here are a few links which may help you more:
hope this al least sheds a little light on the problem
Feb 02, 2009 | PC Chips MB PCCHIPS M863G V5.1C w/XP2400+...
Windows could load installer for disk drive
Change the bios seting to default, check the event and see what it is say about that error and post it here.
Jan 16, 2009 | Asrock 775VM800 Motherboard
Need original bios
you should enter your motherboard manufacture website and dawanload new version
Jan 12, 2009 | Intel D845PT (KD845PTPAK10) Motherboard
Have you flashed the BIOS with either the original factory settings or a recent update? Take careful note of exactly where the computer restarts, either upon Windows start-up or from a cold restart. If the former, then there is no substitute for a reinstall, which is also a good time to make all the settings in Windows just the way you like them. I have reinstalled Windows at least 20 times and always have had changes that I learned from the previous installation. If the computer is restarting before Windows boot, then it is in the BIOS. Reflash from the original or update based upon your needs which can be found in the revision notes for each update. There is only one other suggestion. If per-chance, you have an AMD based machine and have recently tried to install Windows XP SP3, you have been caught in a freakish occurrence. Allegedly, Microsoft has been working, endlessly it now appears, a fix but I would not wait for them. f you can, back up your data and attempt to remove the Service Pack (3). If you cannot remove it, go ahead and reinstall. Pray for a working backup or successful backup attempt. I would suggest both knees.
Jun 24, 2008 | Soyo Motherboards
SL 67FV!
Use original disc installation maybe the installation disc is not compatible. if your system is branded you need only the windwos recovery disc. but if you try this already maybe you can try updating the bios but im not convence in updating the bios.
For now i will suggest you to change the CD ROM disk maybe this can cause failure installation.
Mar 19, 2008 | Intel Motherboard
Gigabyte GA-8SQ800 Motherboard Logo
133 people viewed this question
Top Gigabyte Motherboards Experts
Brian Sullivan
Brian Sullivan
Are you a Gigabyte Motherboard Expert? Answer questions, earn points and help others
