Question about Polaris 380 In Ground Pool Cleaner
Polaris hangs in the deep end
My polaris seems to clean only the deep end. Rarely will it clean the shallow end.
    New Friend:
  • 77 Answers
Check to see if one of the drive belts is broken. You'll need to pull the wheels and separate the housing to inspect. Also make sure that the thrust jet is centered and pointing towards 12:00. This unit should back up after 3 minutes and reposition itself.
Posted on Apr 22, 2009
I have a pb4 polaris booster pump that doesn't seem to put out enough pressure to run the pool sweep.
Check your in line screen and wall fitting to make sure they are right. Sometimes the over pressure button on the wall fitting will blow out.
Also, your local pool store should have a pressure stick they will lend you. It connects the end of the hose where the Polaris would be. You should be getting a least 28 psi. If you are getting less, you may have a clog in the booster pump's impeller. If you have that or more, the problem is internal to the Polaris. Verify that the backup valve is working properly as well.
Mar 21, 2013 | Polaris Pb4 - 60 Booster Pump
Polaris 360 belts in tact and fall off
see if inside unit debris obstructing paddle wheel or belts loose
Jul 09, 2012 | Polaris Pool & Spa
The polaris keeps toppling over. Float is ok no
on the rear of the polaris the jet is a swivel, it propells the polaris set it a 11:00 o'clock and it should travel level.
Jul 05, 2010 | Polaris 280 In - Ground Pool Cleaner with...
Polaris 380 stays in the deep end only. What's wrong.
Make sure that you have enough hose to reach the entire pool. This sounds simple, but this is a common problem with these pool cleaners. Make sure all three thrust jets of water are working on the bottom of the pool, also.
May 24, 2010 | Polaris 380 In Ground Pool Cleaner
Polaris 380 In Ground Pool Cleaner Logo
954 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
