Question about Panasonic PT-51HX41 51" Rear Projection Television
TV Won'T Turn On
I turned on my T.V. heard the click red light came on to show it powered on, than click it turned off. Pushed power button and nothing. I pulled the plug out of the powers strip, plugged it back in. Pushed the power power button, click red light came on than click it turned off. Etc. etc....Is there a reset button or fuse. Any help ! Thanks!
  • Anonymous Mar 24, 2014
    i plugged the tv i and it will not let the power button turn on the tv
A fuse is not your problem. this TV has a safty feture that when it senses a problem it cuts the power to prevent any fouther damage, when you un plug it the TV resets and it will turn on agian. I have the same TV Check the CRT light guns there are 3 of them. If one goes bad it will cause your problem.
Posted on Dec 18, 2007
    New Friend:
What is crt light?
Posted on Mar 21, 2013
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
My tv won't turn on when the on button is pushed, but the power light blinks 5 times
5 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Jan 28, 2013 | Panasonic PT-56TW53 56" Rear Projection...
Tv will not turn on, it has a solid red light
Mine too. I pushed and held the power button in at which point the red light turned off. I then pushed the power button and the tv came on and is working fine. I hope this helps you. Good luck.
Jan 03, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
Tv won't turn on
Replace the power supply board the blinking power indicator is usually indicating the power supply needs replacement or repair. You can get the replacement power supply boards from www.tvcircuitboards.com
Oct 20, 2012 | Samsung LN-S3241D 32 in.LCD HDTV
Tv won't turn on only a red timer light appears when the power is pushed on
First press on the power button on the tv remote control. if it is also not solved then i think your tv has a internal hardware problem which may be failure of some electronic components. It will be better to take it to nearest service center
Oct 16, 2011 | Televison & Video
42" plasma worked fine this
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Sep 15, 2011 | LG 42PC3D 42 in. Plasma Television
RCA 27v520t will not turn on
That's because somehow the lightening caused a fault in the power board.
Ypu can try an unplug for 2 hrs and then reconnect and start again If that dosn't work you will require intevention to replace the power supply
Aug 17, 2009 | RCA 35V432T 35" TV
Click and light on front flashes!
This showing the tv have power. Maybe when you pushed the power button it clicks and shuts down then show the red light bliking showing one code. Some shurt on horizontal board or loose some voltage from power supply. This is not easy if you don't have experience with electronic. I'm sorry still tring
Sep 07, 2007 | Sony KV-35S66 35" TV
Panasonic PT-51HX41 51" Rear Projection Television Logo
223 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
