Question about E-Machines eMachines Desktop PC
Fans work but pc wont power up
PC will not power up,,,I have changed the power pack, power switch.I disconnected the modem then fans came on.. one time the fans would only do 1/4 turns then later went on fully..the hard drive just makes a skipping noise and the lights on keyboard blink..and monitor does not recieve signal..
  • 2 more comments
  • jrmk61 Apr 21, 2009
    okay that worked,,hard drive is running, fans, etc. but my monitor still says no signal....I tried another monitor and the same. and I also put another video card in and the same thing.. any ideas? and also keyboard still blinking..
    oh one more thing, the pc only comes on by unplugging and plugging.. the power switch does nothing and that was replaced to.
  • Anonymous Apr 21, 2009
    hard drive & fans work but but green light is not on
    everything works now but keyboard, mouse, and monitor
    President:
  • 1,383 Answers
Refix ram and reattch all connection to mother bord.
ASlo remove cmos cell for 15 minutes from mother bord
also check smps is working fine
Posted on Apr 21, 2009
    Scholar:
  • 172 Answers
This fault is none of the answers you ahve been given. It is a motherboard problem which can be cured by replacing it.
contact me at 07926-106150 or compdoctor2005@btinternet.com
Chris
Posted on May 03, 2009
Wont power up
My wont turn on too, There is a orange light on the tower, Green on the left, Battery ovel, If I push the restart button, also switch the power supply switch in the back, also unplug from it, Sometimes does it, Do ou know whats causing this to happen, Please let me know Thanks
Jan 26, 2013 | Asrock K10N78M Motherboard
Usb hub powering up mt pc fans??
the switching system of your mainboard is not working properly try to change the resistor and capasitor near the control panel. good luck
Apr 23, 2010 | Computers & Internet
Cleaned cooling fans on hp pavilion desktop now is beeping and wont boot up
This may be your bios setting also like case is removed so go to bios setting and disable the alert or you can try with fixing the ram make sure while you was cleaning you not touch to ram .may be you troche them .do 1 thing remove the ram and clean it and install it again.
Nov 10, 2009 | HP Pavilion (PN153AAR) PC Desktop
E-machine wont boot up. It has power,feels like
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Sep 28, 2009 | E-Machines eMachines Desktop PC
I have a xps 730x and it wont power up
Always eliminate the most obvious possibilities first.
Make sure it's plugged in to a working outlet in the wall.
Make sure that the switch on the back of the power supply is set to 110 and not 220.
If neither of those things fix the problem, we're going to need a bit more information about what else you've tried to do to fix the problem to troubleshoot further.
Sep 27, 2009 | Dell XPS 730X Desktop Computer
The Computer will not power up. The start light is lit but there is no fan or other power. The power supply tests good. Checked all connections. Can you help?
Pull 1 of the memory sticks out, then try to start, switching each time the memory position till all options are run out.
Sep 16, 2009 | Gateway 500XL PC Desktop
Cannot load driver for dsl 200 modem on xp home service pack 3
try this:
http://www.xpvistasite.com/dsl_200_driver_27843.htm
Jun 03, 2009 | D-Link DSL 200 (DSL-200) Modem
PC powers up but wont boot
I would start with a new power box, then a motherboard. then the hard drive.
Dec 23, 2007 | Computers & Internet
Power up problem
Hi, you most probably have a sticky on/off switch on your case. Turn the power off. Remove the side cover, trace your wires from the front switch to the mobo, identify witch is the power switch [this is usualy marked with PWR or PWS on the board and also on the wire from the switch. Disconnect this wire then turn on the power and use a fine screwdriver to bridge the two pins on the board, if all works properly then replace the switch Regards mistyman
Sep 06, 2007 | E-Machines eMachines T3830 PC Desktop
E-Machines eMachines Desktop PC Logo
163 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
