Question about Konica Minolta Office Equipment & Supplies
COF36 error on a Bizhub C350
Machine keeps coming up with this error. The PWB checks out, and the toner motor has already been replaced. Any ideas?
    Brigadier General:
  • 8,619 Answers
Hi
C0F36 error means abnormally low toner density detected Black ATDC Sensor. Check for the black toner and try reinstalling the cartridge if replaced already. And if the toner crtridges are empty then replace the cartridge.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Apr 21, 2009
Hello , I have kyocera taskalfa 6550ci with c2810 error code we replace the waste toner motor and PWB, drive shaft is working too but still the problem is there . any help please
Which PWB did you replace? Check the long PWB in the front of the machine. If the waste toner motor plugs into it you may need to replace the board.
Aug 10, 2017 | Kyocera Office Equipment & Supplies
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
How to fix C-0500 error for BIZHUB C350 konica minolta printer
Open the front door with the machine on, get down on the floor and look up on the right side of open area there is a slanted section in that slated section is a small hole you will not see it standing! With a small screwdrive gentle push the small switch located in side the hole that will reset the code if it comes back DO NOT RESET the copier is telling you something is wrong with the FUSER UNIT the HOT part continued reset might catch the machine on fire and that would ruin a perfectly good day. Have a qualified Tech look at it from Konica Minolta.Check this web site out for a rough idea of cost to replace the fuser.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jan 31, 2012 | Minolta Office Equipment & Supplies
Konica minolta Bizhub C350. Following message appeared on my printer: Malfunction detected. Please call your Technical Representative and provide code: C-0F36 What does this code mean?
Hi katienash,
C-0F36 on the bizhub C350 means the machine has registered a really low toner density in the Black
Imaging Unit. I'd take the unit out, give it a shake and pop it back in. Also worth checking you have some Black Toner in it.
Good luck
Regards
m-press.biz
Jan 25, 2011 | Konica Minolta Minolta Printer stand...
C-OF34 error code?
this error code means there is a low toner to developer ratio in the yellow developer the common causes for this problem is the pwb-mc board needs to be replaced or the yellow toner motor needs to be replaced or or the toner motor one-way gear has failed to reset the error code leave the machine on and open then close the front door if the error code comes back check and or replaced parts listed above.
Dec 02, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub C350 gives error code C-OF36 while making duplex copies . M achine will produce half a dozen copies, then return the error code.
that code means low toner density in the black developer unit so you either have a failed pwb mc board or a failed black toner motor
Sep 23, 2009 | Konica Minolta Office Equipment & Supplies
Bizhub Copier C350 quit "printing", no error codes
CAUSE: A failed PWB-MC board.
SOLUTION: Replace PWB-MC (p/n 4036-7811-01).
try and unplug the machine while its on first wait 5-min and plug back on if that won't help you will need the above board
good lock
Mar 11, 2009 | Office Equipment & Supplies
ERROR CODE C0096 - BIZHUB C350
2.6.19 C0096: Image Transfer Belt pressure/retraction failure
2.6.20 C0098: Fusing Pressure Roller pressure/retraction failure
Relevant Electrical Parts
1st Image Transfer Retraction Position Sensor (PC12)
1st Image Transfer Pressure/Retraction Motor (M11)
Control Board (PWB-MC)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical
Component)
Check the M11 connector for proper connection
and correct as necessary.
2 PC12 I/O check PWB-MC PJ3MC-6B (ON) 6-B
M11 operation check PWB-MC PJ5MC-1~4
(Pulse Output)
6-C
4 Change PWB-MC
Feb 18, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Erroe code
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code.
In Bizhub C350 that code means:
C12C0: Hard disk recognition error
You have the following options:
- reinstall the hard disk
- change hard disk
or as a last chance change PWB-MFP
good luck
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
1,305 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
