Question about Toshiba TheaterWide 62HM94 62" Rear Projection HDTV
Powers on shuts off after 10 seconds- red/green flash
We have a oshiba theaterwide 48". About a week ago it started acting funny. It powers on and within about 20 seconds wil shut itself off. There are 2 indicator lights on it. It is red when the unit is on and green as it powers down. We are having BOTH lights flash together. Then when the unit finally stays on there seems to be some change in color and the brightness of the screen. At first we thought the issue was when the input was on something other than satellite. However, now it is doing it whenever it wants, but still not all the time. HELP!!!!
Its probably the bulb. if the red and gren lights are flashing simultaneously, than that means the bulb is burnt amd you need to order a new one and replace it.
hope this helps
Posted on Jul 04, 2008
SOURCE:
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Sanyo pcl-xu50 flashing red power light when i turn on my projector the light goes green it powers up for about 20 seconds then the power light changes to a red flashing one for about 10 seconds then back...
Projectors shut off when they overheat. They overheat when air does not move through the projector cooling it. This happens when the fans are not working or air filters/vents are not working.
Check to see whether the fans are working. If they are working, open the cover and see whether air filters/vents are covered with dust. If so clean them.
Sep 26, 2011 | Office Equipment & Supplies
When tv was ruining main power shut off and after that tv didn't turn on.tv akai pt 46 dl 10.week ago. i didn't try any thing.
The power shut off because it has been a power surge - the voltage on the line grew very high for a fraction of a second. When that happened the protection system at the power station that powers your house disconected the mains, shutting everything down. Unfortunately it hasn't acted fast enough and the power source of the tv has been fried by the surge.
To fix that you will have to dismantle the tv and replace the power source with an original one. If you don't know ho to do it then the only thing left for you to do is to take the tv to a certified repair shop. It will be expensive, so be prepared .
Dec 17, 2010 | Akai Televison & Video
Unit powers up for 5- 10 min good picture....then it goes black power light goes from green to red and flashes once and solid and repeats pattern .........if i go up to unit and push power off and back on...
There is circuit problem inside. For safety reasons power might get shut down! Unless the fault is rectified, this problem will continue. Do not attempt switching ON again & again. Get authorised service center assistance.
Apr 20, 2010 | Televison & Video
Light engine
hold menu and input or device button at same time for 5sec. Let me know what blinking code you get. 3-2 6-1 etc.
May 25, 2009 | Mitsubishi WD-62531 Projection Television
Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
Jul 03, 2007 | LG RU52SZ30 52" Television
Toshiba TheaterWide 62HM94 62" Rear Projection HDTV Logo
125 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
