Question about Konica Minolta magicolor 2300DL Laser Printer
Service Call: 17H Call Technical Support
The printer makes a noise and stops printing. The screen shows a red wrench in the printer, and the above message appears.
    President:
  • 1,383 Answers
Refix ink cartridge and check there is not paper jam .
Posted on Apr 21, 2009
Brother Mfc9840cdw (except for fax send) has been very good. During print job (2nd computer sent job during print from 1st computer), red light suddenly came on. everything stopped. No sign of a jam. No...
the machine is nearing service time.. Normally this is maintenance and resetting the print clock..
  • press both 3 and 9 buttons at the same time and hold
  • select each item 1 at a time and press ok
  • press 1 to reset it..
  • do this for each item in the list
  • repeat for each item.
Apr 05, 2010 | Brother MFC-9840CDW Laser Printer
Non responsive printer
the noise can be caused by a problem with the ink carriage or the scanner.
Try this:
Follow the steps below in the order presented to determine the source and resolution for the noise
1. Check the scanner (if it has a flatbed)
  1. Open the scanner cover.
  2. With the lid open, press the Start Copy button to make a copy. The scanner mechanism should move down the glass.
  3. If the scanner mechanism does not move and noise is present, contact HP. If the scanner mechanism moves without noise, continue with Step two below.
2. Check the print mechanism Check this knowledge base from hp Step three: Service the product If you have completed all the steps listed above and are still experiencing a problem you may have to contact hp to have them service the product.good luck
Jan 16, 2010 | HP PSC 2410 All-In-One InkJet Printer
Both the green light and red light on the top of printer are flashing. There is ink in the printer but it will not print
1 st clear all pending print jobs by In run window type services.msc and the go to print spooler option just stop and restart the service.
make sure there is no paper jam or out of paper massege coming.and when you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center
Nov 24, 2009 | Epson Stylus C46 InkJet Printer
17H Service Required
Please follow the solution in the link below. Also as you putting in the cartridge always check for loose toner in the area and on the cartridge itself as this can block the sensors.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=74,E=0000000001343666831,K=8485,Sxi=0,Case=obj(3510)
Niallbt
Mar 29, 2009 | Xerox Phaser™ 6115MFP/D All-In-One Printer
I have a Konica/Minolta 2490 copier that has a service code 17H what is this
17H is an error for the toner , either they are not in all of the way or the latch is not closed....to fix it simply take out the toner and put them back in making sure the latch is closed all the way :-)
Oct 03, 2008 | Minolta Office Equipment & Supplies
ERROR EE2 WARNING
one bad toner has jammed or toner drive clutch has fault. open right cover and you can see witch clutch makes noise. or toner drive moter has problem.
Sep 05, 2008 | Brother HL 2700CN Laser Printer
Where are the toner cartridges in magicolor 2300 dl
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing
rack rotation
open door, remove waste toner box then you have to find a small switch in left side and push it wit screwdriver or something, then you can rotate the toner rack manually. then install the waste toner box again and power up printer.
Sep 01, 2008 | Konica Minolta magicolor 2300DL Laser...
Panasonic FP 1780 Copier. The copier has a flashing wrench that will not reset. I need advice on resetting the wrench.
Hold down 3 buttons in this order:
Paper Tray (Oval button), Recall (Diamond) and #3.
You should see an F2 in the display.
Enter #5 (Display should be showing F5)
Hit the Print Button. (Display should show C00)
Enter 70. (Display should show C70)
Hit the print button. (Display should show probably a 7 or 8)
Hit the print button again. The print button should go Red for a second and then back to green.
Wrench should be gone.
Next to get out of service mode
Hit Clear / stop button until the display shows F5
Then hold down 3 buttons in this order:
Paper Tray, Recall and the Clear Stop button.
You should now be back to working order.
If you have any questions or need parts, feel free to ask.
Have a good day.
Good luck.
Please remember to leave your rating if I have helped you.
Mac
Apr 15, 2008 | Office Equipment & Supplies
Minolta 2300 dl laser printer fatal error 17H
had printer for approximately 2 years. Used daily in office setting. today the printer tried to print, then just stopped and it said fatal error 17H in the window. We cleared paper jam and rebooted, gives the same error message. Anything we can do?
Apr 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
104 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
