Question about Dell E173FP 17" LCD Monitor
My screen isn't coming on, stuck in power save mode
It's connected okay, button is green for couple of seconds then changes to orange. It's been happening over last couple of weeks, normally comes on after a few minutes with turning it on/off etc but yesterday and today took over an hour before the screen appeared. It's driving me mad!!! any ideas would be welcome
  • 89 Answers
I had another person say the same thing your not the only one what you have to do is unplug the computer and unplug the screen from the computer and the socket then plug the computer back in and not the screen turn the computer on and then plug the screen into the socket first then into the computer. And if that doesn't work then try a different screen in the computer and check the pins at the end of the screen lead are all straight if that doesn't work then i have not got a clue.
please rate my help to you and how fast the reply was ok .
thank you very much.
Posted on Apr 21, 2009
My dell gx260 ligth come green if i turn it on but for a few mins time it turn orange why
Do you mean the monitor's power light starts green and then turns orange when you turn it on? Most monitors will go to a power saving mode when they do not get a signal from the computer.
The Dell GX260 has a green power light when on. When the computer is off, the light is off. If it is green and blinking, then the computer is in a power saving mode.
Diagnosis: start with the obvious: is the monitor cable plugged into both the computer and the monitor (if not permanently connected to the monitor)? Are you connected to the active port? (You can add a video graphics card in most desktops. The motherboard video port usually needs to be disabled to use the card ports. If you plug in the monitor cable to the disabled port, it won't work.) Is the monitor set to the correct input? (This applies if the monitor has several ports. In that case, there will be a Source or Input button on the monitor.) Is the computer on? The GX260 has the power button on the front. (Other computers have the power button on the top.) There is also the power supply switch on the back which needs to be on.
Next try a different data cable between the monitor and the computer (if you can). Try a different monitor. If a second monitor works, than the monitor has a damaged main board. If the second monitor doesn't work, then the video graphics adapter has probably failed. Replace the add-on card, if in use, then boot in the safe mode to remove the old graphics driver. Then install the correct driver for the graphics adapter.
Note: the computer and the monitor should both be off when you connect the cables. Then turn on the monitor first and set it to the correct source before turning on the computer.)
I hope this helps.
Aug 21, 2011 | Dell OptiPlex GX260 PC Desktop
My printer is coming up with the error code 3 which is flashing. can you help please
Clear error codes
First make sure that there isn't anything keeping the carriage from moving freely.
Then follow the instructions below:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Codes:-
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Jul 22, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Tried unpluging and nothing tried al buttons nothing the computer was at a shop to BE FIXED AT SHOP OK CAME HOME STUCK IN POWER SAVE MODE BUTTON ORANGE ON MONITOR HIT GOES GREEN SAYS PAWER SAVE MODE HIT...
Press and hold the power button for 5 seconds this will turn the system completely off wait 5 seconds then turn it back on as soon as it boots up go into power options in the control panel and click the option from power saver mode to do nothing as there is a fault with some computers that it gets stuck in power saver mode
Jun 27, 2011 | Computers & Internet
How do I change the Waste Ink collector on a Pixma MP170?
Cleaning or changing the pad is a messy project. This ink pad reset will reset the printer ink use conter to new status and your pad full message will be gone. This is a common occurance with Canon printers and the fix causes no harm. I reset my own MP470 about two years ago without incident.
This reset has been sucessful on many MP150 and simular units and should work on your MP170.
The second works on models with different control pads simular to theMP470.
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
Waste ink full reset
These are the instructions which worked for me on my Canon pixma mp470:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Mar 27, 2011 | Canon Office Equipment & Supplies
My computer turns on, the green light is on and the orange light is blinking but screen doesn't show anything
I may be in low-power mode. Try jiggling the mouse, pushing enter on the keyboard a couple times and just pushing the power button once.
If none of those work push and HOLD down the power button for about 10 seconds and the computer should shut off.
As an absolute last resort pull the power plug, leave it out a few seconds then plug it back in and power it on.
One of these methods should at least get the screen back up.
Jun 07, 2010 | Smart Modular SV3170A
Printer not loading paper to print / error #3
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
button pressing
LED Function Remarks
5) Turn off the printer.( it must be turn off)
then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter
the "service mode"
Try it
Jan 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My Acer AL1714 monitor was given to me, the person that gave it to me said last time the last time it was connected it work but the monitor had been stored for about 2 years. So I bought a 19V-2.3A power...
mccampbell71 Probably a failure of inverter circuit(dc to ac 600-1100vac) to light-up (sustain) "cold-cathode-fluorescent lamps" causing the "switch-mode-power-supply" to go into full or partial SHUTDOWN mode. Black Screen of Death strikes again!!! The Question I have is why did you BUY a "black-brick" supply? Did the other one fall out of the car or get run over by a train? Only you will be able to make the decision of to REPAIR or Trade-in for new. You are no different than 5000 others worldwide (all brands) who have monitor's with BSOD! Yes, some (75-90%) can be saved to work 1-3 more years! Read some of my other responses in my profiles (12fixlouie aka louie12fix) to learn of the options you have open to you. Bye for now 12fixlouie If this info was of some use please rate on fixya.
Nov 13, 2009 | Acer AL1714 17" LCD Monitor
One page jammed after switching off when 1 page printed. Orange light on
Hi ,
First off all u switched off the printer and on switch off mode press the green button and on pressing the button switch on the printer hold that button for 5 seconds and then release the button whenever u realese the button the printer start migrating . After migrating if the printer have same problem then u reinstall the printer driver and again reinstall the driver, after reinstalling the driver the printer will working fine .
May 26, 2009 | HP LaserJet 1010 Printer
LG Flatron L1710S Monitor stuck in Power Save Mode
Try wiggling the Cord on the backside of the monitor.. Not the Power Plug Cord, The Other Cord that attaches to the PC. Do this once the monitor turns off , grab ahold of the cord about 2 inches from the back of the monitor, then bend the cord to the right, keep bending from the right to the left a couple times to see if your screen comes back, if it does, than you have a Loose connection and this sometimes causes the Symptoms you are receiving.. Hope it helps.
Jun 02, 2008 | LG Flatron L1710S 17" LCD Monitor
Canon printer mp150
can you try to reset, here are the steps
Mp150
Reset Counter
Service mode operation procedures -
button pressing
procedures below.
procedures below.
Feb 08, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Dell E173FP 17" LCD Monitor Logo
124 people viewed this question
Alun Cox
