Question about HP Pavilion dv2000t Notebook
Solve prob PLZ
THIS WAS MY PROB: my laptop all the sudden has no sound what so ever...it says "no audio output device is installed"...how do i fix this asap...its was working just fine since i bought it brand new march this yr untill now... plz help fix asap PLZ cheers THIS WAS YOUR SOLUTION: You can try bringing the computer to an earlier point by using a restore point. Make sure that you dont have your audio muted. Go into your device manager and go to sounds and audio devices (xp; its different for vista). If everything is 'drayed out'... go into start/run/ [then type] msconfig Under the tab 'services' look for something that says sound or audio on the far left column. On the far right column make sure it says 'running' if it says 'stoped' thats your problem. If you cant find anything, go to hp.com and download updated drivers. NOW: I FOUND THE PROB USING WHAT YOU TOLD ME...BUT NOW WHAT...HOW DO I FIX THE PROBLEM...NOT VIEW IT...I NEED MY SOUND BACK :( IF YOU CAN HELP ME DO THAT, THATD BE GREAT...THANK YOU :)
  • jimbowyer Jan 10, 2009
    I have the HP Pavilion Dv2000 Laptop- suddenly the sound stopped working through the in-built speakers but still outputs through the headphone jack. No sound outputs at all through the speakers- no windows prompts, iTunes, error beeps etc- deleted and re-installed the Conexant audio drivers ( 4 different versions) and even the generic Microsoft audio drivers- still no luck. Have gone as far as re-installing the OS from a fresh install and still no luck. The thing is the speakers emit sound when I load the BIOS settings and hit a key that produces an error sound- so they definitely still work! I'm at a loss- any help would be appreciated as I've tried everything I can think of- booting into safe mode,trawling through RegEdit files, un-installing media/torrent/music programs and codec packs to see if there was some conflict- and still no joy!
Go to www.hp.com and then support and download drivers. Put your model number in SEARCH box and a list of drivers for your model will show up. Select the audio driver and do a complete fresh install. That should solve your problem.
I tried so many other suggestions and this is the ONLY one that worked-my problem was solved in less than 3 minutes. Thank you
Posted on Jul 29, 2008
  • tikun Oct 29, 2009
    I have aHP 530 laptop windows vista and I did an windows upgrade and lost sound. I followed the instructions above and I got to downloading the audio necessary for my laptop only to get an error page -that the site does not exist. Any suggestions
    Pnina
  • 89 Answers
Posted on Sep 23, 2007
  • 35 Answers
Go into start, control panel, system management, services. There locate "Windows Audio" and select start on the left side
Posted on Sep 22, 2007
Just installed into my T41 2373 -XP with audio device /soundMAX digital audio/, all volume up-not mute, but not coming anysound? Sound card solve how? Problem solve plz?
Set your output device to Speaker out or Headphone, maybe it goes to your digital output line.
Hope that gives you an idea...
Jul 20, 2011 | IBM ThinkPad T41 2373 Notebook
I hav compac 301tu laptop the prob is usb dosnot work
Make sure you properly install all drivers, like your processor, chipset, graphics, sound, modem, and ethernet drivers from the manufacturer's web site
Mar 13, 2009 | Compaq Computers & Internet
AUDIO O/P SOUND CHANGED SUDDENLY
How about trying with its internal speakers ?
if it works fine then the sound output jack-port have a problem.
If not working then try to re-install your audio drivers.
If still not having good result even if you re-install your operating system, you should go to repair center since you have a hardware failure.
Dec 30, 2008 | Dell Inspiron 1300 Notebook
Cannot record sound
Normally every Lap is coming wit internal mic; so
1- Simply check your mic is mute or not
2 - Check your mic volume
3 - Use sound recorder that comings with windows (just record & play)
4 - Use an external MIC (known as working) with sound recorder
5 - Check in control panel->sound and audio device --> default recording device and Voice recoding device as your system’s built-in audio device (some times it’s changing when we installing b-tooth deice)
6 - Check device manager --> under sound audio controller for any issues
7 – Uninstall & install completely your Audio Device driver with default settings.
** If you didn’t solve your prob; my advice is take your lap to a good technician with component level Repair skills.
Thank you & Best Regards
Dinu..
Dec 20, 2008 | Toshiba Satellite A215-S4697 Notebook PC
Compaq presario V3777TU with win xp
go to control panel , sound and multimedia, there is a option for checking the hardware , just check it
Oct 05, 2008 | Compaq Presario Notebook
No media device found fr sound driver
either your sound device is defective already..
May 25, 2008 | Compaq Presario 700 470024-192 Notebook
You do not have suitable driver to work smoothly. you can download latest driver from manufacturers site.
May 25, 2008 | Edirol UA-4FX External Sound System
No sound
Sep 20, 2007 | HP Pavilion dv2000t Notebook
HP Pavilion dv2000t Notebook Logo
104 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
