Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Dishlex dx 302 heat drying
By beauboy on Sep 22, 2007
hi, i have a problem with the drying of dishes etc through the cycle. there is no heat finishing off as well as no hot water coming through the machine which is leaving the contents wet and cold.
help needed.
Same Problem
Nov 16, 2008
-   I am trying to replace the heating element on the Bosch SHU53 dishwasher. I do not have a repair manual so it is not clear how to get to the old heater. I noticed the blog comments on the circuit board and loose solder points. How do I get to the circuit board? -   heaterfix
Jul 22, 2008
-   Same problem for mine, i first found one of the plugs not pushed on properly to the circuit board on the control module. I pushed this back on and it worked really well for about 3 weeks. Now the problem has come back so today i have pulled the circuit board out of the control unit and found 2 cracked solder joints to what looks like a relay? Have now soldered them and will report back if it works. Nice to be able read about others with the same annoying problems.
-   benno123
Jun 07, 2008
-   I have had the same problem with no heat and I found three dry solder joints on the 12v relay and it fixed the problem. Will update if the problem continues.-   irvs351
May 27, 2008
-   Dishlex 302 WB not heating water,found dry solder joint on 12v relay repaired
worked for two more weeks,now same fault.
Relay OK and works, heating element OK, no more dry joints found.
Could it be water flow/level control.?? (Boy a circuit would be good)
Now thinking of wiring in test points to check as it goes
-   STEWY JJ
Jan 02, 2008
-   Ear peircing tone from Dishwasher when on-   Guest
Best Solution
posted on Jul 12, 2008
Very Helpful)
naominbrock
Rank: Apprentice
Rating: 100%, 1 votes
Our heater wasnt working either, read your comments, pulled it apart and bingo! a dry solder on the 12V relay. Thanks everyone you've saved my sanity!!
Was this helpful?
Yes
No
Solution #2
posted on Sep 22, 2007
Very Helpful)
barnsleymick
Rank: Guru
Rating: 86%, 378 votes
as a normal rule dishwashers inly use cold water to fill and then warms it up, look for a faulty heater element, test with a multimeter
work with safety and unplug when working on appliances
if i have helped please rate me
Comments:
Sep 22, 2007
- sorry i should have said the same heater element is used to dry as well as wash the plates etc
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
we are about to buy new dishdrawer lookin fisher and paykel
Answer
I'm having the same gurgling sound from the drain impellor. I've taken the side panel off and the... (More)
Answer
Kenwood KDW24F Door won't close. It will close about half way and then meets some resistance. I... (More)
Answer
quiet partner ii leaks at motor to tub connection
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dishwashers:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
