Question about Sony ICF-2010 AM/FM/SW Radio
NO POWER AC OR BATTERIES
CLOCK KEEPING TIME.. QUICK MSG AM ERROR3
  • 494 Answers
May be a bad power adapter solder joint on the side of the radio. Email me with any questions at.... poikaa@yahoo.com
Posted on Feb 09, 2010
Timex number t235 clock radio, how do I set the time
easiest way to set clock time. Remove AA battery's if installed.
Unplug Clock from AC. Wait a few seconds. Then replug clock into AC power. Clock will now flash 12:00. Press hours button until correct time is set PM has led on AM has Led off. Set minutes to correct minutes. Then press alarm reset / power/mode button. Wait a few seconds and display will show correct time. Now you can put the AA batteries back in.
Apr 30, 2014 | Timex T065s Solar Powered- Radio...
Hp nx6110 laptop is power lock what is unlockng process
Disconnected the RTC battery will unlock your system. See the steps below.
The more important it is to protect on's data by a DriveLock (which makes the HDD usuable when the password is not available).
Procedure to remove password
(following CPQ MSGs)
1.) Unplug AC, take out the main battery.
2.) Take out /disconnect the RTC (real time clock) battery for app. Half an hour (the period of 5 min as specified in the MSG normally is not long enough).
3.) Plug in the AC adapter (batteries still removed); computer should boot automatically, if not use the power button.
4.) The machine will boot and show the 162-error-msg "system options not set". Use F1 to save the settings.
5.) Shut down the computer and disconnect AC power again.
6.) Re-connect the RTC-battery.
7.) Install the battery pack(s).
8.) Restart the computer.
Warning: All settings are set back to factory standard.
You'll have to enter a correct date/time and change the settings to your needs.
Note: Pls strictly keep to the sequence.
Re-starting with the main battery and or RTC-battery inserted will spoil the job.
Apr 04, 2013 | HP Compaq nx6110 PC Laptop
I need administrator password for compaq nx6110
2.) Take out /disconnect the RTC (real time clock) battery for app. half an hour (the period of 5 min as specified in the MSG normally is not long enough).
Aug 11, 2011 | HP Compaq nx6110 PC Laptop
The alarm display in the lower right corner on model #RC40-A keeps blinking and will not stop. This happens with both wake 1 and wake 2 options. I fixed it once by unplugging the unit but it this did not...
Hello
Just reinstall the battries and adjust the time once again.
Battery back-up operation
* This clock radio is equipped with
a memory holding system that can
be powered with 2 "AA" batteries
(included). The power failure
protection circuit will not operate
unless battery is installed.
* When normal household power
is interrupted, or AC line cord
is unplugged, the batteries will
power the clock radio to keep
track of time and alarm settings
programmed into memory.
* When the battery backup functions,
the digital display will not light,
however, the function of alarm
still occurs during the power
interruption if remaining battery
power is adequate.
* Normal operation will resume after
AC power is restored so you will not
have to reset the time or the alarm
To install batteries:
1* Remove battery compartment door
(located at the bottom of the radio)
by applying thumb pressure to the
tab on battery door and then lift
the door out and off the cabinet
2* Insert 2 AA batteries (included).
3* Replace the compartment door
Replace batteries every year.
Power is fed to the unit even
when it is not functioning. To
cut the power supply off, the
power cable must be unplugged
OK.
Jul 10, 2011 | RCA Rc40 Clock Radio
I have an Accu-Time Electronic Clock Model #40240. Made in China, but have no idea how to set the time/date/ect. Is there a manual I can download?
It can't be done. The Accutime 40240 has a 3V lithium battery behind the 9V compartment that keeps the time should the clock lose AC power or even when the backup 9V dies. If however the 9V is removed, the AC power is disconnected and the lithium battery drains, there is no way for the end user to reset the time. There is a small data port in the 9V battery compartment which is how they initially set the time IMHO but good luck finding a way to do that outside the factory. Besides, these clocks are so cheap its probably less cost to get another clock rather than replace the batteries
Apr 04, 2011 | Vacuums
Clock not keeping correct time
The CMOS battery keeps the laptop configuration stored in the CMOS chip and the main battery has no effect on the CMOS.
If the date and time drift off, it indicates the CMOS battery is nearly flat and needs to be replaced.
If you had ticked the Daylight saving box in the Time Zone tab in Control Panel - Date and Time setting then the time would automatically adjust for Daylight saving.
Apr 05, 2009 | IBM ThinkPad T40 2373 Notebook
Acer laptop shut of during power outage .
From the Acer website:
Product
Notebook
Issue
Power Issues or Will not Boot
Solution
If the notebook does not power on:
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a ‘power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
Also, depending on whether your power went down "clean" (quick and stayed off), or went down and quickly came back on and off many times. Or when it came back on "clean" (came back on quick and stayed on), or it came on then off many times, your power supply may have been damaged from the power surges Are you having any problems with any other appliances?
Feb 07, 2009 | Acer Aspire L100 PC Desktop
Sony handycam DCR-DVD205: use new ac adapter or reinsert
Remove the battery insert your AC adaptor turn on your DVD CAM if it work fine reinstall the battery set CAM to off position the amber light should be on to indicate battery is charging
You got that msg depend what function you use if the CAM calculated the battery not enough to run or finish this task it display that msg for you to use AC adaptor to ensure no power corrupted such in formating the disc
Some time system control is faulty even you use AC adaptor it still display this msg I hope that is not in your case
Let me kown how you go with this problem
Nov 30, 2008 | Sony Handycam DCR-DVD205 DVD Camcorder
Forgot BIOS password.
Caveat: All settings are set back to factory standard.
Note: pls strictly keep to the sequence.
Feb 19, 2008 | HP Compaq nx9030 Notebook
RCA alarm clock - RP3721 - crystal or AC for time?
They used to use crystals to help the timer ics to keep time but since the development of Micropros. all this is built in to one chip. Now they will use a resonator or a small crystal for the timing clock of the micro but nowdays the manufacture uses that clock to keep all in check. If your gaining time you probably are having problems with your ac duty cycle as this also keeps clocks in check.. This would not affect most devices but could be a problem. But of course a defective Micro could also cause this gain in time And probably is?? Now a battery backup is nothing more then a battery in line with the Microproccesors B+ terminal through of course a diode as well as a voltage limiter resistor to take over the B+ when the units ac supply is absent..
Mar 03, 2006 | RCA RP3721 Clock Radio
Sony ICF-2010 AM/FM/SW Radio Logo
207 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
