Question about Nintendo DS Lite Console
Nintendo DS Original snapped in half
OK, so 4 wires are broken, the ribbon cable which I have ordered a spare part for and then the other 3 wires I need help with.
There are 2 (one black, one red) running from the left board to the right and then another one (black again) running from the right into the bottom half (which has snapped also because the top is completely seperated from the bottom).
Does anyone know the exact wire these are and how I can fix/replace them?
    Problem Solver:
  • 3 Answers
If you can't glue it to gether then go find your receipt and go to the store and buy a new one
Posted on Apr 21, 2009
Blank top screen
This is one of those things that I regret to say but the only way to repair this would be to order a new Flex cable. the flex cable is a small flat ribbon cable that connects the bottom half with the top half. It would be easer to replace the entire thing instead of just the ribbon cable
May 20, 2009 | Nintendo DS Console
Broken in half got new shell don't know how to put together
much of it is pretty straight forward, the only hard part is putting the ribbon cable thru the hinge for the top screen, without ripping it, best thing to say is put the ribbon cable in first, then the wifi and mic cables (black and white), rest is pretty straightforward.
Apr 17, 2009 | Nintendo DS Lite Console
Broken top screen (original DS)
Replying to the first post:
If you have broken the ribbon cable, which is highly likely if you have broken the hinge, then the DS will not work. It does not turn on unless there is a connection to both screens. You will need to buy a new ribbon cable for it:
A useful site I found is: www.consoleparts4u.co.uk
Once you replace this then it should work for you.
Repling to th second post:
I would recommend buying a new case for it at least because the ribbon cable will break if left broken due to the strain on it.
The more expensive but easier option is to buy a new one.
Hope this helps,
Mowcius
Jun 16, 2008 | Nintendo DS Console
Replacing broken nintendo ds screen
there is a little black bar across copper colored connection wires leading into the tan connection box...lift it up ever so lightly by placing fingernail underneath... see http://www.instructables.com/id/SED515GFA0CVIFN/
warning... I have been replacing cover this evening for 3 hours only to find the right hinge piece that inserts into the lighted power tab doesn't rotate.... IE this was what caused the hinge to break in the first place and this torque/force problem causes the left hinge to break which is posted all over the internet and seems nintendo would have replaced all that for free anyway....I was searching this issue when I found your post SSLong hth
Jan 04, 2008 | Nintendo DS Console
Nintendo DS Lite
Well something more appropriate i guess would be my ongoing issue with DS's that have had screens replaced.
if you could describe something for me
as the unit will not power ,,, plug in the charger, if it is as i suspect you will get an orange light illuminate for 1 second, after it goes off the unit is unresponsive until you unplug and replug the charger.
if this describes your problem i would be most interested to hear weather you used the ORIGINAL screen or if it is a replacement screen
thanx
Nov 14, 2007 | Nintendo DS Lite Console
Nintendo ds to screen broken
Hi, replacing the original nds upper screen is a fairly straight forward procedure, you need to remove the 4 x small plastic plugs located in the corners of upper screen, then remove the 4 x phillips screws, the top outer back part of the case will seperate and you can gain access to the screen. Firstly remove the small screw holding down the right hand pcboard to gain access to the ribbon connectors, release the larger flat connector by hinging the clip up, slide the ribbon out, underneath you will see a tiny connector, gently ease the small clip back towards the ribbon, prising a little each side at a time, remove the ribbon and then you can prise the screen from the case.
These guys sell the replacement screens www.ps2laser.co.uk prices are very competitive and offer next day delivery!
Nov 08, 2007 | Nintendo DS Console
DS blinks and will not turn on
Hi
As complicated a console as the DS is, it is not surprising you have a problem after changing a case. Sometime the little snap on wires do not snap on right.  You need to go back in and  make sure the ribbons and snap on connectors are sucured. The ribbon and wire that runs from top half through the hinge needs to roll up one turn before in the transition from the top to bottom half.  You may have the ribbon upside down in the connector.
Oct 28, 2007 | Nintendo DS Console
NINTENDO DS FELL 2 FEET AND WHEN I CHECKED IT THE TOP SCREEN WAS CRACKED IN THE BACK AND CANT SEE HALF THE SCREEN CAUSE OF THE CRACKS SO I NEED TO NOW IF YOU GUYS CAN FIX THE SCREEN OR KNOW A PLACE THAT...
DONT ATTEMPT TO REPLACE THE TOP SCREEN ON THE DS LITE. It is easy to replace it on the original ds, But the ds lite requires you to re-soilder the 4 speaker cables into the top screen's video ribbon cable.
Aug 03, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
95 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
