Fuses check ok, dead no power
53uwx10ba hitachi. Was doing a convergence alignmemet, turned on off to put in memory, lost picture, then lost sound. Dead
  • imustang Mar 04, 2008
    I have the same problem with my Hitachi 43fdx01b. Was doing convergence alignment when tv clicked off and have been unable to turn back on. The power light on the front turns on but no picture or sound. There is a clicking and chirping like sound and the dp37 red led light dims with the sound. Any ideas.
    Problem Solver:
  • 19 Answers
It could be high voltage cap located by flyback,if you have back off of tv and turn tv on,you will see green led's turn on,(on the board)if they turn off there is a small blue high voltage cap hidden under glue(i believe it's a 102 cap)that would be the one change,99% of time that is what will fix problem
Posted on Sep 22, 2007
How do i get my hitachi 53uwx10ba into convergence mode?
This should be a menu option in the video portion or initial set up area of your menu. If you have auto converge it will do it for you otherwise it will put up a screen with color patterns for you to manually converge.
Sep 28, 2012 | Hitachi 53UDX10B 53" Rear Projection...
Hi there i replaced my hitachi 53uwx10ba convergence IC (2) stk392-120 and now it won't turn on and just flashes at the front panel 7 times, can i get some help pls
Did u check the pico fuse and all those resistors on the tv convergence board to make sure with ones are good resistors which are not good resistors and replace all them resistors too?U didn't do that should get it tested and replaces all those dying resitors.Try website like Tvrepairworld.com look up ur Hitachi tv model what resistors and pico fuse u require to check.
Aug 20, 2011 | Hitachi 53UDX10B 53" Rear Projection...
I have a Hitachi 53UWX10BA tv. The picture colors are off and blurry. I ran magic focus and it showed a 4 on the bottom of the screen
Ur tv have a problems known as a convergence problems,it dead.Tv have corlors R,G,B lines mis alignments,have colors shadows picture or 3D picture look alike?Yes.The tv convergence board is dead.The convergence board must change 2 STK convergence ICS and some or all of it resistors to fix the convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Feb 28, 2011 | Hitachi Televison & Video
Hitachi 53UWX10BA HDTV with convergence problem for blue
No there are no quick fix options for this fault. The convergence amplifiers operate similar to a high power audio amplifier, so if there is an impairment anywhere in the system, it will result in distorted audio, or in the case of television convergence amplifiers, a color won't align. The convergence power pacs need to be replaced and the out of tolerance precision resistors located near the power pacs need to be carefully checked and replaced as necessary.
It is also possible that there are root faults that cause the amplifiers to go bad which include bad connections or a bad digital control module. This repair is possible for anyone having basic electronics knowledge and soldering skills.
Apr 28, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53uwx10ba turns on & off when off red flashing light/clic
Same problem. Replaced both convergence ICs about 5 months ago. Worked fince since then and just recently no sound, no video, blinking red on front panel and clicking sound. I suspect that the ICs went bad again and blew a resistor or two. I used cheap Chinese ICs instead of the Sanyo ones and thing this is why. I'll be looking at it again and post solution.
Jan 21, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Convergence issue Hitachi HDTV Model #53uwx10ba
you have a sensor problem to start magic focus is the last step in this repair done normally after replace converge outputs did you do this? if so a manual alignment is needed then you may write it into memory if you get a solid green screen after just briefly you have done it wright if you get a red screen after wards you need to try again it will stop on red if all is not well
Oct 08, 2008 | Televison & Video
DP23 LED not lit on deflection board no picture on tv
Good Day, Gil;
Your problem is in deflection circuit (115+v) check these: FP05, DP15, Q777, QH01, TH01, T701, etc. BUT suspect C707 1k pfd, 2kv, and check all the pico fuses (brown) 2" to the right of cap. Good Luck, big IRISH.
Jul 19, 2008 | Hitachi 53UWX10B 53" Rear Projection...
PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53uwx10ba no sound/picture flashing power light cricket sound
Possible shorted cap C702 ? Open E994 pico fuse.....check
carefully with ohmmeter...all fuses and let me know.....T.
Mar 05, 2008 | Televison & Video
HITACHI 53UWX10BA
Hi there, Check IC601, C603 for leakage, I601 and vertical pulse detector QN05 for poor convergence check RK42 for open circuit. Best regards, Arpi
Jun 16, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Televison & Video Logo
314 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
