Question about Coby DVD-514 DVD Player
Dvd 514 tray wont open
I removed the cover and found that the belt had broken. Can I get a replacement belt?
3 Suggested Answers
ravichetty
  • 158 Answers
SOURCE: coby dvd 514: My dvd tray won't close. I've taken
TAKE IT TO A TECH FOR ALIGNMENT
Posted on Aug 03, 2009
jhinsincity
  • 616 Answers
SOURCE: my coby-514 dvd won't open up when the open/close
disc is stuck, remove cover screws and carefully remove the disc, do not force the unit, once the disc is out use the remote to close the unit, then use remote to open and use a different disc press play and hopefully it will work, try to avoid not using the remote for all functions,including open-close. do not push tray in manually.
Posted on Dec 10, 2009
It won't open
i bet t is the belt for the tray motor, mine hs the same issue, i took it apart ad found the broken belt, jut have to find the replacement
if you remove the steel cover from the top of the unit you will see the disc, there is a bracket above it which can be removed with two screws and take the dvd out easily
May 19, 2012 | RCA RTD315 Theater System
Disc tray will not open. I've turned on &off several times and it won`t open the tray. tries to but won`t open
This problem is caused by a loose drive belt in the eject mechanism, you need to open the ps2 and replace the drive belt...
Take off the top cover, then take off the cover from the top of the dvd drive mech... then carefully remove the disc tray and you should see the belt near the front. Replace that belt and it should work fine again
On a couple of rare occasions the drive motor has been found to be faulty, but usually replacing the belt will fix it
Jan 25, 2011 | Sony PlayStation 2 (PS2) Console
My Coby DVD-514 will not open. The display reads 'open' but the drive does not open to insert a DVD
you have to unplug the dvd player open it up then remove the face, it should have two screws on each side.after you have done that look under the dc draw you will see a gear spin it counter clock wise then the tray will come out.when it reach aout half way lok inside wher the try was ther should be a belt replace. if it looks ok just pull the tray all the way out and back in shoud set it good luck
Aug 01, 2010 | Coby DVD-514 DVD Player
Can not get DVD out of Blue ray player (insignia) wont open
You should be able to remove the case and retrieve the dvd from the player. You may or may not have to apply steady, gentle pressure on the dvd tray to force it open a bit if you can not remove the disc due to a covering. Make sure the device is unplugged before you remove the case.
There may be a few things that may have caused the problem to begin with. The first thing is that dirt or some sort of debris has cause the gears, tray track, or tray drive to jam. A close inspection with a flashlight should be enough to see anything that may be causing this. If you see anything, try removing it with tweezers if it large enough to grasp and then spraying the inside out really well with a can of compressed air.
The next things are that the disc tray gears or the gear belts have broken. you will also be able to see this with a close inspection. The following is a picture of what parts to look for:
The next thing could be that the disc tray motor has malfunctioned in which case would require replacement.
Another thing that could cause the dvd tray to not open is that the push button switch has malfunctioned either in the electrical circuits or the button itself has broken.
Other than cleaning out the inside of the player, I would suggest having a qualified technician replace any parts with the exception to the little belt, which in most cases you can do yourself easily if it is accessible without having to remove other parts (some models it can be reached easily and in others it may take removing overlaying parts).
I hope this helps give you and idea of how to solve the issue. Feel free to ask if you need further assistance.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You
Feb 07, 2010 | Televison & Video
Dvd drive wont open , can hear motor working but drive wont come out. we believe the cd holder isnt shifting up/down to allow the drive to activate & open
Turn the computer off,Remove power cable.Use a peper clip insert it through a hole infront of the dvd drive this will eject the door.Make sure once this is opened the tray is aligned properly,slide it in and out.Push it in all the way then power up the computer.This may work for a while,before it goes again,so you might have to replace it.
Good Luck
Jan 17, 2010 | Lite On SHM-165P6S DVD RW Dual Layer...
Jvc player deck wont open - can I use screw driver to force it out so I can retrieve disk that is inserted
HI,
You don't have to use force here u just open top cover detach the dvd compartment and replace the loading tray motor belt they do expand after a period of time thus making the cd tray to open.
This is where u can use your screw driver to remove your cd by opening the screws on the cd cover compartment .
Good luck
Dec 19, 2009 | JVC SR-DVM600
My coby-514 dvd won't open up when the open/close
Dec 10, 2009 | Coby DVD-514 DVD Player
Toshiba sd 4800 dvd plater not opening and playing
There is a small belt that has become worn or has broken. Open the DVD palyer, press the open key push on the silver disc, the tray will open, . On the tray pul the two tabs up gently, remove tray. Belt is located there
Oct 04, 2009 | Toshiba SD-4800 DVD Player
Drawer won't open. Says "blocked".
I had the same problem with a comparable device. It turned out that the drive belt that operates the ejection mechanism wears out or breaks.
To get at it you need to do the following:
1. remove device cover
2. remove the identification cover on the front of the DVD tray. This may be tricky if you can't open the tray. You need to find a way, because otherwise you can't remove the DVD unit, at least not on my unit.
3. remove the DVD unit by detaching the cables and removing four screws.
4. remove the two top screws on the DVD unit
5. remove the front top cover of the DVD unit by pushing the two tabs on the top of the unit, near the front.
6. Now remove the tray, by pulling it out as far as it goes and then pressing two tabs on either side of the tray. These tabs look like this:
7. Now you get at the drive belt. Originally it was black; I replaced it (temporarily) with a red one in the picture below:
8. Now put everything back together.
May 31, 2009 | Philips DVDR3450H DVD Recorder/HDD...
Disc Tray will not open
DVD door is opened by a small pulley-belt system. Disconnect the power cord and remove cover on R6740 (one screw on each side and 3 in back). Remove top cover on DVD drive (4 screws on top). Manually open door; you will see a small "O" ring sized rubber belt (they stretch and lose flexibility with time, which is why the door stops working). Remove and replace belt. I found a 11/16" X 1/16 belt at Lowe's in the plumbing dept @ 2 for $.59. Its not a perfect fit, but the door works now!
Nov 05, 2007 | GoVideo R6740 DVD Recorder
Coby DVD-514 DVD Player Logo
27 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
