Question about Kenmore 24032\24036 Top Load Washer
Tub won't spin
The agitator does not work properly. when the machine is empty the agitator works fine, but when clothes are added and the machine is full the agitator does not agitate. Also, when it comes time to spin, the tub does not spin at all. the machine is making a loud noise at that time as well. is there a way to fix this? I was wondering if the machine has belts that I can replace?
  • randl1003 Apr 21, 2009
    I pulled the couplers..they are both intact. now what?
    I was wrong. this helped..thank you VERY much for the help!
  • Kenmore Master
  • 3,361 Answers
Your direct drive coupling is broken. Follow the instruction in this video for repair.
Posted on Apr 21, 2009
  • steve
    steve Apr 21, 2009
    The loud noise is the motor running and not spinning. Did you remove the direct drive coupling and inspect it for cracks?
    Does it pump out water?
    Are the agitator dogs worn?
    Is the brake releasing?
    Is the lid switch making continuity?
    Is there a pause in the timer after pump out?
Haier HWMP55-918 5.5kg Top Loader don't agitate or move clothes during wash, but still spins.
I would call the washing machine engineer for a quote as we have no spare parts on this site eric
Jan 07, 2018 | Haier Washing Machines
Washer won't agitate
I would start by checking the belt on the motor could be slipping when u put full load in washer. also check that pulleys are not loose.
Apr 19, 2014 | Miele W1903A Front Load Washer
I have a Maytag Atlantis MAV6200AWW Washer agitates and spins. Water sometimes empties. Pump is fine spins freely and the impeller is fine. Could it be the belt ?
You will need to check for an article of clothing stuck between the basket and tub that may be partially blocking the drain hole.
Nov 22, 2012 | Maytag Atlantis MAV6000 Top Load Washer
GE Profile WPRE6100G tub spins while washing
My parent's Hotpoint did the same thing!! The brake on the bottom of the tub is not engaging! It needs replaced!!
May 15, 2012 | GE Profile WPRE6100G Top Load Washer
Agitator won,t work tub will fill, and empty but won't spin and agitator won't work
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Dec 01, 2010 | KitchenAid Washing Machines
Spin cycle problem
I suspect you definitely have a clutch problem. It might be the liner or it could be the transmission seal leaked some oil into the clutch you would know it by the oil on the cabinet74eb356.jpgThats a hint of a clutch problem with leaky top seal. An easy fix.ef45d86.jpgthe newer washer have a square recess you unscrew and lift the top of the agitator off and then you have access to the bolt that holds the lower portion on. The agitator has to come out first then drop the tranny
(3 bolts) Put the tranny on a bench. You can use a pair of pliers and squeeze the spring and the clutch liner comes right out. You can buy just the liner, no need to buy the kit but you can do that too. None of the parts are expensive and anybody can do these repairs.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 16, 2010 | Kenmore 24962 Top Load Washer
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Tub won't agitate (or spin)
That's great, that leaves me to believe that it's the timer. I would recommend replacing it.
Feb 03, 2009 | Kenmore 22422 Top Load Washer
10yr whirlpool toploader wash machine no spin/agitat. but works?
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 08, 2009 | Whirlpool Washing Machines
Kenmors 110 keep spining
The tranny should either spin or agitate not both
Nov 02, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
127 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
