Computer audio stopped working
I have been trying to help my aunt with her computer. I know enough to apparently cause trouble. I used crucial to do a memory scan and upgraded her HP Pavillion a1610n to 4GB. I also Installed AVG free, adaware and Norman. I used to device manager to update her drivers. The next day she noticed her speakers had no sound. I spent all day today trying to figure out why. The following is an agonizing list of all my failed attempts at solving this one:
I check all connections. I unplugged power strip and restarted.
I used headphones (installed in the out jack in the rear of the PC)to check for sound
I updated and rolled back the sound drivers
In the Run box I typed dxdiag and did tests for sound under the sound 1 and sound 2 tabs
After indicating I heard no sound saw error msg. 19
I checked the control panel....sound settings normal no mute...turned up
I went to system information and under components selected sound and saw the manufacture and drivers...Status read Okay under both. Realtek and an USB one...C-m???
I went to Hp directly and downloaded driver and did a restart. It did state however, I needed another download from windows (UAA-????).
Upon trying to get this I found it was only available for WinXP SP1, 2, and 4.....she has SP3.
I tried to type mplayer into the run box and was told the file did not exist....
I downloaded WMP 11
I really NEED to fix this for her. I wonder if some program was mistakenly removed disabling the sound???? There must be a simple solution to this short of anything drastic. Please tell me where this went wrong and exactly what I can do or who I can call to fix it. It is a challenge as I now am not in front of the system....but will be able to work at it again asap.....Very discouraged and out of answers! BTW the speakers are HP USB desktop speakers. Thanks in advance for any help provided.
  • Mishell Apr 21, 2009
    Thanks I will try all of this at my next opportunity I did try plugging headphones into front of tower first. There was no sound from there either. Do you think it would benefit me to run a program such as Driver Detective to solve this? And if so are there any that will go from scan to install for free? And when you say reinstall original drivers from HP recovery disc, just to be sure, you mean the original disc used to set up their computer? That may seem a dumb question, I just really am mixed up in all this and am trying to be clear on every level. Thanks again for your response!
    Thank you for the detailed, concise, info. I will be giving all this a run through ASAP. I will let you know what the ultimate cure was for this problem when I figure it out. As I said, thanks for helping me sort through this!
    President:
  • 1,996 Answers
For one thing, there is no Windows xp sp4. It stopped at sp3. So if you needed another download I would check again. Run a custom scan at windows update and see if it offers you any hardware updates, and if so, download and install them.
Then take a look at the following MS KB articles:
You will see from this that error code 19 indicates a corruption in the registry and the suggestion to reinstall the device that is reporting the error. I suggest you use the original drivers from your HP recovery cd and then update the sound after it is working again....Also check the HP support site for your Pavilion and see if there are any reports of known xp conflicts involving the sound card installed in your system.
If this doesn't fix the problem, I suggest you go to Microsoft.com and search "windows xp + no sound" and work your way through the list.
Also have a look at this Vista troubleshooter for audio
(There have been vista/WMP bugs involving USB audio devices, but I haven't seen the same in xp)
Maybe check for sound at the front output jack to be sure you didn't jar something loose when installing the ram.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Apr 21, 2009
  • efs_perpends
    efs_perpends Apr 21, 2009
    It's tempting to use an application like Driver Detective to do the work for you but I would steer clear for the moment, as I have heard some mixed results from "fixes" to peoples systems from such utilities. I haven't used it myself, however...
    You should have a disk from HP called drivers, or a recovery disk that came with the system.
    This will have the drivers for the sound card that were originally installed on your system.
    Here's a link to an excellent online tutorial on updating windows drivers
    (After some further research, I've discovered your HP system has a recovery application program that allows the reinstallation of drivers without the cd, but good to have it on hand just in case..see below.)
    But I just checked HP support for your system and they have an excellent sound troubleshooter online. Have you tried working through the steps there? I would follow their instructions to begin with since it is their installation of XP and they'll have dealt with other similar systems with the same problem to configure the troubleshooter. Click here for a link
    And here's another link to general sound issues for your Pavilion computer
    Work through those HP steps and I'm confidant you'll be able to correct this problem...
    If you still have questions after trying that, please feel free to post back with a comment.
  • efs_perpends
    BTW, no worries, it's better to ask 100 questions than hose her system.
    Read through the links I sent you so you'll have some familiarity with the ground before you actually have to do the repairs. Be patient and take it one step at a time, and then reboot the system and check the results of what you've done to see if the sound is working...If not, proceed to the next step, etc..
Why does my GM5420 Tower appear to start up normally, but it doesn't register my screen?
The motherboard or the video card might be defective. Check on that side. If you have an installed video card, try replacing it.
May 28, 2014 | Gateway GM5420 Refurbished Intel Desktop...
My computer keeps shutting down for no apparent reason... I hasve a toshiba satellite p10...
Possible causes of the problem:
System overheating
- Virus infection
- Power supply malfunctioning
Solutions:
- Check your computer if the fan is properly working.
- Scan your computer for viruses
- Check your computer power supply by a qualified technician
- Reinstall your computer operating system
Try this also:
From the run box you can type shutdown -a and that should stop it from shutting down long enough for you to fix the problem.You need to look up how to remove msblast from your computer.
Nov 17, 2009 | Toshiba Satellite P105-S921 Notebook
My aunt moved, and I was helping her set up her computer, and we think we have it all hooked up, but there is NO sound coming from it whatsoever! Help!
If previously it was working then there are a problem with loose connection pls check the audio cable connection from monitor to CPU might be its loose or not connected
Nov 16, 2009 | Hyundai ImageQuest L70S 17" LCD Monitor
How do I make the ring tone louder on my bt freestyle telephone?T ringhe set belongs to my aunt. She is 90 and cannot hear
Sir,
You are suggested to use the software FormatFactory on Computer from convert any audio File to Mp3 and before start converting increase the Hz of the sound it would get Louder and it would be easy enough to Listen for any person setting 80 fts away from mobile
Oct 30, 2009 | Lands Phones
Cannot access network resource error when trying to load from cd
Just Simple.. You can try System Restore in Vista.. Cause in Vista can't not read automatic like vista. if your dont have Nero Disk try restore in good Condition before Software Crash..
Oct 26, 2009 | Computers & Internet
Can't see the other person.
the reson is that in the way from your grandma to you the bandwidth of the net is not enough for the cam so skype program feels it and stop the cam.
when the situation is changed the cam will work.
i dont think you can do a lot. this situation that you described is well known. (another proof is that your aunt can see her )
daniel
Aug 06, 2009 | Skype IM
HI.I was watchinglive streaming but there is a eror sudenly.this eror:rtsp://78.129.143.64/broadcast/pull/81.31.32.47:2030/broadcast/pull/81.19.7.50:3051/stv3.rmvb Can you help me...
Streaming audio/video quality can be affected by connection rate and Internet congestion. Many types of interruptions between your computer, your player, your computer's OS, your local network, your ISP and a streaming server can exist and cause trouble....
When you listen to the live audio/video stream, the sound or video skips, cuts out or buffers if the player doesn't have enough network bandwidth, it will buffer. Try increasing your player's buffering setting.Also:
  • Make sure you are choosing the appropriate bandwidth version of a media stream based on your Internet connection.
  • Make sure you are choosing the appropriate bandwidth settings in an Internet media player or streaming audio/video recorder.
  • Make sure NOT to download applications or files while watching/listening to media streams. Your Internet connection is shared between all open applications including your web-browser, your download manager and your streaming player. Closing applications that use your Internet connection simultaneously with your streaming player may reduce buffering.
  • Close other unnecessary applications that may be open on your computer. Reboot your computer. If you have lots of other programs open, they may be using too much processor time and/or RAM for the player to work properly.
  • Make sure your Internet connection is fast enough to reliably listen to streaming audio and/or watch streaming video online. High speed Internet connection is recommended.
  • Make sure your computer is fast enough. If your computer is old, it might be too slow to play an audio/video stream regardless of what else it's doing.
  • Update your media players and streaming audio/video recorders regularly.
Internet congestion can slow down the delivery of the stream, make it difficult for you to connect or cause buffering. Often the interruption is temporary. Please try to connect a few times at different times of the day, if possible. If you repeatedly have problems connecting, please notify your ISP - there are often quick fixes they can make when they learn about your issue.
Try the above steps you will find a solution to your problem....100% it will work.....
Sep 18, 2008 | Computers & Internet
Computer stopped recognizing speakers
This is due to your Drivers for your sound device are unavailable plz make sure that you have installed all your audio devices driver! try to reinstall it! it will help you
Dec 07, 2007 | Polk Audio AMR50 Computer Speakers
How to know what RAM works for what MB?
you should go to a web site called crucial to scan your system to see which memory fits your motherboard, but be aware that not all makes of memory will work in your pc, it's best to try and get the same make or type as you already have fitted, click link below: http://www.crucial.com/systemscanner/
Sep 16, 2007 | Select Brands Matsonic mATX 800Mhz s775...
Can I connect a mini plug DIGITAL audio source into these?
Hello bobbobbob, These speakers would work great. First question is: Do you already own these speakers, or would you be buying them? If you already own them, then yes, use them, if not, a more economical solution would be the Bose Companion 2 speakers here: http://www.bose.com/controller?event=VIEW_PRODUCT_PAGE_EVENT&product=companion2_multimedia_index These are about half the price, and have exceptional clarity for someone like your aunt. They also will allow her flat panel TV to plug and play very easily. Please let us know if you need any additional information. Best regards and kudos for helping your aunt out! nightdiver
Sep 04, 2006 | Edirol MA-20D Computer Speakers
Computers & Internet Logo
169 people viewed this question
David Payne
David Payne
