Question about Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio
I can't find a download for the Motorola Talkabout 250 manual
I have been looking for this with no results. I need to change the batteries and can't figure out how.
Grasp the black bottom sides of the radio and tug it hard. No screws to loosen. The bottom slides off. The battery placement will be in there.
Posted on Aug 29, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Motorola TalkAbout 250 Radios run on three AA batteries.
Also see this link for user manual--
Motorola FRS manual
Please see the manual for a similar model from this link---
Motorola 2-Way radio manual
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Apr 21, 2009
    Brigadier General:
  • 5,158 Answers
Remove the clip from the back... the rear cover should slide off.
Robert
Please take a moment to rate this solution thanks
Manual motorola 250 talkabout
Here is a link to the user guide http://shop.giantintl.com/Manuals.asp Choose T280 from the pulldown. It is the closest to what you have.
Opening the battery door is often a question. The U-shaped sides are connected to the battery cover. Pull down firmly on the U-shaped sides and the whole black portion will slide down and off the radio.
Feb 17, 2014 | Motorola Talkabout FRS 250 (14 Channels)...
How can I replace batteries in motorola talkabout 250
See thoroughly your Radio and you will get the place from where you can replace the batteries or you send me pic of your radio.
Jan 19, 2014 | Motorola Talkabout FRS 250 (14 Channels)...
I changed the batteries on my Motorola Talkabout 250 .......shows full power...both are set for the same channel and code.......but they aren't communicating. Please help.
Remove batteries from both. If there's a "factory reset" option try that. Re-check that they are REALLY on the same channel and code. Also be sure there's nothing stuck in the external headset jack.
Aug 11, 2013 | Motorola Talkabout FRS 250 (14 Channels)...
I need a user manual for motorola talkabout 250
The closest user guide we have located online to the T250 is a step newer, the T280. Here is a link: http://www.motorola.com/mdirect/manuals/T289_User_Manual.pdf
Best regards.
Dec 30, 2012 | Motorola Talkabout FRS 250 (14 Channels)...
How do you change batteries on a motorola 250 talkabout phone
The U-shaped sides are attached to the back battery door on this style radio. Grasp the U-shaped sides and pull down. The entire section will slide down and off the radio.
Best regards.
Dec 20, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
When I press the push to talk button on my Motorola talkabout 250 there is a constant beeping noise and I cannot transmit
Generally a constant beep is the sign of a low or bad battery. However, it is noted the TalkAbout 250 is operated with AA batteries, and it is likely you have considered this and changed batteries. You might check your battery contacts, and clean them with a pencil eraser to assure they are making good connection. Otherwise, you may have a failing radio.
Best regards.
Nov 02, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
Antenna for a Motorola Talkabout 250
Get a plastic tube (3/8 PVC will work) and use it as a mould. Pump it full of black RTV silicone. Fixed!
Mar 25, 2009 | Motorola Walkie Talkie 2-Way Radio
Motorola 250 manual
I was made to understand that the 250 together with 270SLK, 280 & 289SLK all came out sometime last quarter of 1998. To my knowledge, all share the same basic features. The only difference is that the high end models feature built-in VOX, available colors, power/battery condition indicators, some other frills.
Like you, I couldn’t find any manual for a 250 but the user’s manual for a Motorola Talkabout T-289 is available here. Since most features are presumably the same, you can probably try winging it from the 289.
Here and here are nice articles about the 250.
Hope that this be of some help. Pls post back if this is of any use to you or should you need further information.
Good luck and kind regards.
Nov 08, 2007 | Motorola Talkabout FRS 250 (14 Channels)...
Motorola Talkabout FRS 250 (14 Channels) 2-Way Radio Logo
2,877 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
OBHighflyer
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
