Question about Refrigerators
Frigidaire mrt21gngw1
My fridge does not stay cold at all.
  • Refrigerators Master
  • 4,655 Answers
That could be several things. I would begin with defrost timer. May be on floor behind kick plate or inside the fresh food compartment hidden by the plastic control panel. I did look for the model you listed but it had very little information. Turn the defrost timer slowly clockwise until you hear refrigerator stop running. This should put in defrost for about 20 minutes and then come back on itself. Let me know what you find.
seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Posted on Apr 21, 2009
Frigidaire frs26h5asb5
Hi Gary,
If your evaporator is not completely frosting over (top to bottom) this normally means the unit doesn't have a proper charge or the compressor can't pump all the freon as it needs to. I would check the charge, this should read "0", if less not enough, if higher than the compressor is failing. I hope this helps.
Aug 17, 2014 | Frigidaire Refrigerators
Why wont my fridge stay cool?
MAKE SURE THE FAN IN THE FREEZER IS RUNNING THATS THE ONLY WAY THE REFRIGERATOR STAYS COLD DO YOU HAVE AN ICEMAKER IF YOU DO IS IT WORKING OR A DEFROST PROBLEM ANY ICE OR FROST BUILD UP IN THE FREEZER
IF YOU SEE IT ON THE WALLS ITS FULL BEHIND THE WALLS OF THE FREEZER
Jul 11, 2014 | Frigidaire Refrigerators
Fridge stays cold but continuously runs
http://manuals.frigidaire.com/prodinfo_pdf/StCloud/297005500en.pdf TURN TO PAGE FOUR and check the rtroubleshooting guide. Example gasket control setting etcetra
May 01, 2011 | Frigidaire PLRU1777DS Stainless Steel...
Does not stay cold. Even with
Sounds like the compressor, or a refrigerant leak. Being a year old I would call Frigidaire and try to get it fixed or replaced under warranty.
Jan 03, 2010 | Frigidaire FRT21H8 Top Freezer...
Freezer not staying cold
the temp control thinks its cold enough to stay off so you need to have the temp in home warmer so it will cycle / atleast 60 / larry
Dec 12, 2008 | Frigidaire FRT21H8 Top Freezer...
Whirlpool side by side freezer ice cold refridge only at 55
My frigidaire has a flapper valve assembly that opens and lets the cold air in from the freezer as required. The frigidaires are known for the flapper breaking and staying open and allowing too much cold air in to the refridgerator side.. Check yours out. Mine has a shroud at the top of the refridgerator. Remove it and look around, I feel sure you have the same problem.
Dec 11, 2008 | Kenmore 57029 Side by Side Refrigerator
My frdge will not stay cold. the freezer does
yes the fan is running. i cleaned the coils under the fridge and the fan.i just turn the fridge back on
Oct 16, 2008 | Frigidaire Refrigerators
Frigidaire the refridgerator is not cold enough. It stays at 60 degrees, I don't know the model because it was torn off inside the fridge and the owner's manual did not come with the house when we bought...
Have one similar and found out the compressor goes out on them about a year and half after purchase. You can buy another compressor but the likely hood of it going out again is likely. Sorry but we bought bad fridges. Never again will I buy a Fridgidaire.
Jun 10, 2008 | Frigidaire Refrigerators
Fridge on fritz
Did you check the motor and/or damper mechanism that directs cold freezer air into the refrigerator portion. If that is messed up the freezer is ok but fridge is ng. Also look at door seals for proper sealing.
May 05, 2017 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
