Question about KitchenAid KP26M1X Stand Mixer
525 watt mixers broken
So our mixer was making a high pitched wincing noises and my wife continued to use it against my advice.  Then it finally started grinding and she stopped.  It had no warranty anymore so I took the cover off and saw that the plastic gear housing was broke and one of the bearings fell apart.  I purchased new ones on the net and fixed everything and put it back together.  It's still making an odd sounds and I think it may be in the rotary gears by the attachments.  I can't get inside to take a look and I'm thinking it's time for a pro to take a look.  Who do I call and what do I do?
  • 10,865 Answers
Http://www.kitchenaid.com/flash.cmd?/#/page/customer-service here u go. Customer care will direct you to a certified kitchen aid repair shop in your area.
Posted on Apr 21, 2009
Mixer infected by foul demons makes bad noises
Hi, JSTEWART431, are you sure it’s the motor or could it be the transmission gears where the noise is coming from? Are you sure it's the motor or could it be the transmission?
It 'sounds' like you've got some transmission gear issues. It could be as simple as through normal use the gears have shifted slightly in the transmission and the gear teeth are making different contact, hence the grinding noise. The higher the speed, the louder, higher pitched sound you'll get. Alas, the noise may also be indicative of a potential gear failure, similar to my wife’s mixer where the mixer’s increasing noisiness finally ended with a broken tooth on the bevel gear and the mixer 'froze'.
If you are DITY type person, feel adventurous, and your mixer is not under warranty you can troubleshoot it yourself. Be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM90P, and select the first file listed under Parts List (16) and then check to verify this matches your mixer model.
Turn to pages 4 & 5, titled: Case, Gearing And Planetary Unit for the disassembly and reassembly of your mixer, along with all the parts. Locate Illus. No. 36, Worm Gear Bracket & Gear, including Illus. No. 7, Worm Gear. I suspect this is the weak link in your mixer’s transmission and causing the problems. After clearing all the grease away, check to see if the gear is just loose, exceedingly worn or broken. If it’s worn or broken you can order a replacement part and install it yourself. While you’ve got your mixer this far apart you can check for any other unseemly wear and tear on the on the gears and other components. Besides a replacement gear, and grease you might consider replacing the gasket, too. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call).
The next possibility to check would be with the motor itself, but electric motors are pretty simple mechanisms and generally don't fail. Using the parts list, you can see what needs to be inspected and determine if any motor parts need replacement. (Generally only brushes wear out, but I don’t think that would cause your grinding sound.)
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. You should search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Finally, here’s a link to an excellent site for disassembling/fixing your KA Mixer: http://www.neilcrockett.com/mixer.htm and another link to a site that details the disassembly and replacement of mixer’s grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html
If you feel troubleshooting and repairing is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 05, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
I went to use it for beating egg whites and while it is still rotating it is making a terrible grinding noise. I am very careful with it. While I do use it to make bread I never use it in any speed but 1...
KLIMTJ1123 ? I?m sorry to hear about the grinding noise in your KA mixer. The grinding noise does not bode well for your mixer?s internal transmission. From the symptoms you describe, it sounds like one of the gears may be getting ready to fail. Your circumstances are very similar to my wife?s mixer (the same model and similar usage), but hers ?ground? to a halt in early October. Since it was out of warranty, I decided to troubleshoot and fix it myself. The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, KP2671, and select the first file of the 24 listed under Parts List (check to see it this matches your mixer model). Turn to pages 4 & 5, titled ?Case, Gearing and Planetary Unit?, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts. As far as replacement parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping. Finally, here's a link to an excellent site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. It?s a different model, but I found if very helpful, just the same: http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html After disassembling my wife?s mixer I found that a bevel gear tooth had broken and one right next to it was getting ready to break. I ordered a replacement bevel gear (actually two), a gasket and grease, and reassembled the mixer and now it works better than when we first unpacked it. Fixing your mixer yourself is much easier than shipping it off to a repair center, and you have the gratification of know that you did it yourself. I hope this helps! Howard, Burke, VA If this solution has helped you, please rate it, thanks! - hslincoln
Nov 30, 2009 | KitchenAid KP2671 Professional 6 Series...
Noisy, high pitched whirring MUM6622UC/01 Bosch Universal Mixer
My wife's bosch mixer had a similar problem but it was a very loud grating problem. I talked to the bosch dealer in Utah, sorry, I've forgotten which one-- the one that does the repair. This is typically what happens: the seal on the blender wears out, which results in fluids from the blender dripping into the motor, onto the upper motor bearing. So, the upper bearing corrodes and is what is causing the bearing failure and the loud noise (needed hearing protection to operate it). I was lamenting the cost and time it would take to ship the mixer both directions (not actually that much compared to the price of the mixer), and he said he would sell me the bearing and the bottom replacement part of the blender that was leaking. So, I did the repair myself, but it took awhile, and I had to build a puller for the bearing to get it off the shaft, modifying a harbor freight gear puller. But it now is back to new. So, it was a success for me, but i would recommend anyone who isn't very mechanical to just send it off to Utah (again, I forgot the place, I think they talk about the shop in one of the other posts), and you will have a better than new machine.
Nov 08, 2009 | Bosch 700 Watts MUM6622 Universal Series...
I have a 6qt professional kitchenaid mixer and that I bought last year and have just recently started to use it but it make a high pitched squeal that makes it almost unbearable for me to use. If anyone...
Diane,
It appears that you've got some internal transmission gear issues, and a situation similar to my wife's mixer, which we got new in Dec 2006. It could be as simple as the gears have become loose and are making different contact, hence the noise. The higher the speed, the louder, higher pitched sound you'll get. It may also be indicative of a potential gear failure (after all our increasing noise, the bevel gear broke and the mixer 'froze'). If your mixer is under warranty, contact Kitchenaid. If it's out of warranty, then take it apart and do a diagnostic exam of the gearing. Whatever you find you should be able to fix yourself. Be sure to have the Kitchenaid Part Manual (Part No. 8212278 Rev D) on hand if you attempt to disassemble yourself. It also lists all the parts so that you can determine, which parts, if any have failed. You'd think that the Kitchenaid name would warranty their mixers for a lifetime... but alas they do not. So much for quality in America today!
Nov 02, 2009 | Food Mixers
Kitchenaid mixer motor makes loud grinding, squeaking noise.
lgardash, Are you sure it's the motor or could it be the transmission?
It 'sounds' like you've got some transmission gear issues, and a situation similar to my wife's mixer, which we got new in Dec 2006. (Within a week of her first using it, she contacted KA Customer Care and the only 'care' they offered was an explanation that the new KA Pro Mixer gears are all metal and to expect it to be louder than previous models that used a plastic gear (to fail). Well, there's an acceptable level of noise, and an unacceptable level (you don't need to be a mechanical engineer to know when something doesn't sound right) and it seems that my wife's new mixer's operating noise level was always unacceptable. It finally 'died' this past October.) OK I've vented enough on KA... now what might be your problem(s)?
It could be as simple as thorough normal use the gears have shifted slightly in the transmission and the gear teeth are making different contact, hence the grinding/squeaky noise. The higher the speed, the louder, higher pitched sound you'll get. Alas, the noise may also be indicative of a potential gear failure (after our mixers increasing noisiness, the bevel gear broke and the mixer 'froze').
If your mixer is under warranty, contact Kitchenaid. If it's out of warranty, then take it apart and do a diagnostic exam of the gearing. Whatever you find you should be able to fix yourself. Be sure to have the Kitchenaid Part Manual (Part No. 8212278 Rev D) on hand if you attempt to disassemble yourself. It also lists all the parts so that you can determine, which parts, if any have failed. You'd think that the Kitchenaid name would warranty their mixers for a lifetime... So much for quality in America today!
I hope this helps, and good luck! - Howard, Burke, VA
Oct 13, 2009 | KitchenAid KP2671 Professional 6 Series...
I have a KitchenAid Pro 600 stand mixer, and it makes a loud whining noise which gets louder and ear piercing the faster the speed setting. I did not make this noise when I first got it, just a gentle...
It appears that you've got some internal transmission gear issues, and a situation similar to my wife's mixer, which we got new in Dec 2006. It could be as simple as the gears have become loose and are making different contact, hence the noise. The higher the speed, the louder, higher pitched sound you'll get. It may also be indicative of a potential gear failure (after all our increasing noise, the bevel gear broke and the mixer 'froze'). If your mixer is under warranty, contact Kitchenaid. If it's out of warranty, then take it apart and do a diagnostic exam of the gearing. Whatever you find you should be able to fix yourself. Be sure to have the Kitchenaid Part Manual (Part No. 8212278 Rev D) on hand if you attempt to disassemble yourself. It also lists all the parts so that you can determine, which parts, if any have failed. You'd think that the Kitchenaid name would warranty their mixers for a lifetime... So much for quality in America today!
Jun 08, 2009 | KitchenAid KP26M1X Stand Mixer
Whining noise in all three speeds.
There is only one bearing in the back a an A200, the rear motor bearing. Page 12 -- Otherwise I'd look for something rubbing the motor. (wire, capacitor shield) The two back side covers are easy to remove, two screws each.
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/57866D624A678E7385256CB0007232DA/$File/F-19357%20(05-95).pdf
The timer is also in the link. The part is not cheap, but easy to install.
Jun 20, 2008 | Hobart A200 Stand Mixer
Kitchenaid mixer mades a high pitch squeak when mixing
Take it to a local repair shop and they should be able to fix it in no time.
Jan 28, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Food Mixers Logo
225 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
