Question about Acer TravelMate C100 Notebook
Acer laptop does not boot up but gives no errors
1) Unassembled the system and checked
a) Harddisk.
b) RAM
c) with USB keyboard
d) Removed CMOS battery and put it back
All are ok and the problem still exists !!!
2) When system starts up, it will jus stop after saying "MOUSE INITIALIZED
3)THe only thing I did was restarted the machine after i said to the acer 3200 travelmate laptop (3202CXI) to change to default data in the bios section. Never boots, but does not show any errors too.
  • rohira Apr 21, 2009
    I am not sure if I can update the bios thru the boot. My keyboard does not work. I have a USB disk floppy drive which gets detected. But no keyboard to work with.
    Even my usb keyboard does not work
  • 741 Answers
Go to the Acer Website and see if you can update your BIOS. That's where the problem lies, in the future it is a good troubleshooting tip to either use a digital camera to take a picture of all your settings in case you need to revert back. You will have to go thru each section of the BIOS and change one thing at a time, reboot, and continue process until you find the error.
Pls rate this solution
Posted on Apr 21, 2009
  • Randall  Trahan
    Randall Trahan Apr 21, 2009
    Ouch..you don't get any errors because you never make it for enough in the boot processs where a utility can send an error to your monitor...or it does not boot up for enough for the monitor to output it...I'll bring your problem up in a really good Tech forum I belong too that are all PC Repair Business Owners see if anyone has dealt with this before...let me clarify first...No boot, no boot errors, BIOS was attempting to be changed then it all went south correct?
  • Randall  Trahan
    Ok you need to reprogram/reflash your BIOS chip..its not a pretty thing to do and you may need to get a PC repair to do it but here are the instructions..good luck let me know how it goes...
    If your BIOS is now corrupt you will be unable to reboot and try the BIOS flash again, not easily anyway.
    If the motherboard is an older one the only way you can recover the motherboard is to get the BIOS ROM reflashed using a ROM Burner/Programmer which some Computer Stores may have (you may need to call around) or you can buy your own.
    In newer systems the flash ROM is soldered to the motherboard and cannot be replaced. However this doesn’t mean you will need to replace your motherboard, a lot of newer systems have special BIOS recovery procedures that can be done. You will need to consult your motherboard manual or motherboards manufacturers’ site to get these steps.
Why does my dell inspiron m5030 laptop give me a series of 5 beeps and wont boot when I try to turn it on?
Please read this:
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Jan 12, 2013 | Dell Inspiron M5030 Laptop
Dead
Hi
THe most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
pls rate as fixya if it helps. thanks
Jul 04, 2008 | Acer Aspire 5100 Notebook
While i am booting my pc , it is getting bootable...... But problems are , 1. there is no display getting to monitor(Where i checked with so different monitors and CRT , LCD) 2.In booting time power is no...
1,Check your Ram (Whether it is working or not)
2,Clean your Ram slot by a brush(Remove dust)
3,Rub your Ram golden contact by a rubber gently.
4,Try to go to bios menu and restore to default
5,Check CMOS battery and power supply(SMPS) with spare one
6,If these fixes are not working try replace motherboard
Jul 26, 2010 | Intel Motherboard
When turning on computer it gives me an error message saying no boot disk please insert boot disk
press f12 during start up and select your harddisk and if that doesnt solve it take out your harddisk (large plate that you can remove at bottem of laptop)
and boot your laptop switch it off put in harddisk and switch on again
Apr 20, 2010 | Acer Aspire One PC Notebook
Acer Aspire 5100-5674 won't boot. Keyboard won't work, mouse initializes. PXE-E61 : Media Test Failure then PXE-M0F : Exiting PXE ROM I really need some help, I just bought it. And would really like to...
PXE errors are generated by the network boot ROM. In other words, the boot process is attempting a network boot (your BIOS' 4th boot option), which means that your system was unable to boot from a HDD, CD-ROM, or USB device (the first 3 boot options).
PXE-E61 Media Test Failure, System won't boot:
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration
Also verify if your harddisk is detected by BIOS
Jul 30, 2009 | Acer Aspire 5100 Notebook
Hi my acer laptop is giving me a display saying it cannot find the operating system
Either your master boot record got hosed or the entire hard drive has failed. When booting the machine, enter the system BIOS and check to see that your hard drive is recognized. If it is not, you will need to replace it. If it is recognized, you will need to boot from your OS installation CD and try to repair your existing installation. It should automatically be able to detect the problem and fix it without any other kind of manual intervention. If that is not the case, post back here to this thread and I'll offer other suggestions.
Jul 11, 2009 | Computers & Internet
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
Display problem
The most common beeps that you will encounter 95% of the time in repairing PC's are:
or this might help
AMI BIOS
AWARD BIOS
Pheonix beep codes
1-1-4 BIOS failure
1-4-2 Memory error
the vga board has failed, its a very common problem in acer laptops, you can get a replacement part from www.acerparts.com im not sure if they ship into us but for europe thats where I get my parts.
my acers vga failed two times, ones within warranty and 12months after that, I have to say that acer products are really bad quality, I'm not sure about the latest models but from what I've seen the vga chipsets have real issues with the motherboards and keep failing over and over again.
I have not looked inside your model but the vga is either integrated into the motherboard = that means the repair will cost the whole motherboard, better to buy a new one.
if your model has a removeable vga like mine does, then you can consider changeing it to a new one. contact acer parts.
One of the covers in the bottom is the memory, one is network and last one I don't remember.
here are the contact details if your acer is out of warranty
http://www.acerparts.com/contact_us.php
The parts for your model are at http://www.acerparts.com/index.php?cPath=561_562_1064
you will have to contact acer parts directly, it may be that the vga is build into the motherboard or then the vga parts are not listed.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 29, 2008 | Acer Aspire 5570-2758 Notebook
Acer 3100, NO Boot, keyboard locked out,
For my case I think its a bad BIOS.Normally its a hard step to reprogram a BIOS.But first try thet step you said about removing CMOS battery and leave it for atleast 1 day(Without Notebook battery or AC) if its doesn't then try to read this one.No harm in reading even thought its a HP website..
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447626+1208634698316+28353475&threadId=974719
Best of luck,takecare.
Apr 18, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
134 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
