Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
Put battery cables on wrong
My son put a new battery on our riding mower. However, he put them on backwards. Upon starting it the mower made an odd noise. Sounded like it was trying to start then grinded and nothing now not even electric signals after putting cables back correctly.
  • elleabridges Sep 25, 2009
    Battery is good. Any chance of a website that would tell me how to get to it?
Probably burnt the solenoid that feeds the starter. cheap part, but difficult to get to.
Posted on Apr 25, 2009
  • 10,865 Answers
For starters remove the battery and take it back to the store where you bought it and have them test it. Your solution may be to purchase another battery.
Posted on Apr 21, 2009
John deere lawn tractor. Had a dead battery. my son tried to jump it but cables got hooked up backwards, cranked 10 sec. Now turns over but wont start and smokes under the flywheel
Because he shorted out the alternator under the flywheel. There also maybe other damage as these are not protected from reversed voltage.
Apr 30, 2015 | John Deere Garden
No, Need to see a diagram of the springs that are on the deck of riding mower Model #247-288851
Hope this helps. Craftsman Tractor model #247288851 Deck and Belt Diagram
Apr 11, 2015 | Garden
Battery was dead. Charged it up. Mower starts and runs rough, surging and bucking. However, When I started it and disconnected the battery, it immediately smoothed out, running perfectly.....super...
One of the cells in the battery is probably not working, and the charge is leaking off.
That may be why you had to charge it.
A new battery should solve both problems.
Mar 27, 2015 | Husqvarna WE261 960220007 26 190CC Weed...
I got a troybilt rider mower. I dont know anything about mowers. I got this from a neglected owner and the final thing that got him to sell. Was the battery charger was wrong and it blew the acid all over ...
There should be a second belt that goes from the engine to the transmission. This could either be slipping due to a mis-adjusted pulley or another bad belt.
May 18, 2014 | Garden
S2046 low battery tried to start. Replaced battery now no sound, no start. Yes did hook up correct cables. Where can I find images of safety switches?
When trying to start with a low battery the engine Sometimes will stop on the top of the firing stroke putting it under extreme compression..almost like being stuck..you must turn tne engine backward a little just enough to get it off the compresdion stroke then try and start..This very same no click no nothing even when jump start happened to my cub cadet this summer after trying to start with a low battery...i used a pipe wrench and turned the dry shaft back and it started..then and all summer...give it a try good luck..
Nov 14, 2012 | Briggs & Stratton Starter Scott's Equip...
Mower will not start.
are the battery cables good jump them with jumper cables
Apr 23, 2012 | Garden
I have a troy bilt riding mower. I put a new battery in it last summer. This yr., my son left the key in on positon when he got done cutting the grass. Naturally it killed the battery, I jump started the...
Try charging the battery on a bench top charger, preferably a maintenance charger those usually tell you if your battery is able to charge or not. Or take it to your local auto-zone and have them check it it might be old and unable to hold charge. Check to see if you have a dry cell if so your battery is most likely shot. Sometimes jumping these small batteries, if done the wrong way can ruin them, always best to charge them slowly with bench charger now a days they are very inexpensive check one out if you go to auto-zone. If battery checks out then you need to check your mower units charging system. Good Luck...
Jul 27, 2011 | Garden
It may not be charging due to a bad connection to the battery or to the generator on the engine. The generator on the engine may be going or has gone bad.
I hope this helps.
Jul 27, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
I HAVE A GARDEN TRACTOR MODEL # 917.276920 I REPLACED THE WIRING AND I CAN'T GET IT TO DO ANY THING . I CAN HOOK JUMPER TO THE STARTER AND IT STARTS RIGHT UP WHAT HAVE I DONE WRONG
is there any water in the battery? Did you test the battery (while unhooked?) Have you charged the battery? If all else works when you put jumper cable son it, I'd say you might just need a new battery...
Ck
Feb 13, 2011 | Sears Garden
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
138 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
