Question about Sony SSC-CD73V Color Mini Fixed Dome Camera
CAMERA GOES TO BLACK & WHITE A HOUR AFTER RESETTING POWER ON IT A
The wire run is about 300 ft
  • 10,865 Answers
The SSC-CD73V and SSC-CD73VT cameras
offer a “Day/Night” function to provide
optimized sensitivity in both day and night
shooting scenarios. As the scene illumination
reduces and the acquired image darkens, the
infrared cut filter is automatically removed and
the camera switches to B/W mode, requiring
only a minimum illumination of 0.2 lx.
Incorporating an optimized lens for the
“Day/Night” function, the camera can produce a
clear and crisp image under normal illumination
or when used with near IR illuminators. In
addition, “Day/Night” modes can be
automatically switched, or manually initiated on
demand through an external control signal.
Posted on Apr 21, 2009
How do i wire up camera after somebody cut off plugs
INDUSTRY STANDARD WIRE CODE COLORS FOR CAMMERAS ARE AS FOLLOWS
RED- POWER SUPPLY POSITIVE
BLACK - POWER SUPPLY NEGATIVE
WHITE- VIDEO CENTER
YELLOW- AUDIO CENTER
THE SHIELDS ON VIDEO AND AUDIO HAVE TO BE JUMPERED TO BLACK - POWER SUPPLY NEGATIVE
NEVER ALLOW POWER SUPPLY POSITIVE TO TOUCH VIDEO OR AUDIO LEADS
Oct 09, 2014 | Lorex Home Security
Replace power cord
When a plug wire is replaced say on a stereo there is no hot or neutral it makes no difference which wire goes where there are instances where hot and neutral are a concern but not with a 2 wire plug that is not separated by color if you have 2 white or 2 black then there is no order just wire and go.When color is in question the wires will be colored I hope this helps.
Jan 20, 2014 | Dremel 300-N/55 300 Series Tool Kit
I have an intermatic C8865 timer. i want to wire it into an EFM model AF150-1 coal stoker furnace, because the fire goes down to far inbetween actual times heat is called for. also have main switch for...
Intermatic C8865 timer is a 5-hour cycle timer that repeats same cycle each 5 hour period.
This timer has 120Volt clock motor and is 120V timer.
Timer has NO and NC terminals.
NO terminal turns ON when timer turns ON
NC terminals is ON all the time, except when timer turns ON. At this point NC terminal turns OFF.
You have 3 things: 120V timer, 120V honeywell transformer, 120V stoker motor/fan
The transformer needs to be ON at all times.
The stoker motor is going to turn ON when the cycle timer turns ON.
You have 120V cable with black wire, white wire (and bare ground, which connects to green ground screw and to other bare grounds and won't be discussed further)
Black wire is hot
White wire is neutral
Black wire connects to 'Switch common terminal' on timer.
Same wire also connects to black wire on Honeywell transformer.
White wire connects to 'Clock terminal' on timer
Same wire connects to white wire on Honeywell transformer and to white wire on Stoker motor.
So all the white wires are connected together.
Last wire is black wire to stoker motor.
This wire connects to NO terminals on timer.
Here is drawing.
Add a comment any time
Dec 13, 2010 | Intermatic C8865 Timer, 1HR CYCLE TIME, 30...
Installing a GE digital wall timer. Instructions say" connect Hot/live wire of main to black of timer. Connect Hot/live wire of load to red of timer. connect white of (neutral) to white of timer. green...
Review:
Black goes to Hot wire from breaker box
Red wire goes to Load (light, fan, motor)
White wire goes to Neutral
Green to bare copper ground wire
Orientation:
Your original switch had 2 wires plus bare ground.
One of these wires is Hot, the other goes to Load.
You said original wires are Red and Black
How do you find Hot wire?
-Your original switch had 2 wires.
-Remove timer from box.
-Pull original 2 wires out where you can test them
-Turn on power
-Use regular tester
-Tape tester leads to wood sticks so your hands stay away from voltage
-Power is on
-Test each original wire to bare ground wire
-When tester lights up, that is Hot wire ... this wire connects to Black wire on timer
- The other wire goes to Load so it connects to Red wire on timer
How to test for Neutral wire
Test Hot wire to your white wires - No need to untwist them.
When tester lights up, that is Neutral
White wire from timer connects to Neutral.
Green goes to ground wire.
How to reset timer
I'm not sure which timer you have. Probably GE 15086. Reset is small round button below HOUR button. Use paper clip and push-in reset until timer flashes 12 o'clock.
Sep 25, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Need wire diagram how to install 3 N 1 start relay on a true t12f freezer
The two stripped black wires connect to power.
Black tabbed wire to common.
Red tabbed wire to run.
White tabbed wire to start.
Looking at pins on compressor, read like a clock. Common clockwise to Start clockwise to Run
Apr 29, 2010 | True 12 cu. ft. / 340 liter Commercial...
Need help with the wiring on the reddy heater 110 btu
CIRCUIT CARD-
-Photocell blue wired go to two terminals marked BLUE PHOTOCELL (any order)
-Motor red wire plugs onto terminal marked MTR MAIN, motor white wire plugs into terminal marked WHITE MOTOR.
-potentiometer (thing with knob) two white wires plug into terminals marked TEMP SEL
-Black wire from switch to terminal marked L1 BLACK
-White wire from power cord goes to terminal marked N White
-Ignitor (used to be yellow wires) goto terminals marked IGNITOR and IGNITOR RET (any order)
OTHER-
-White wire from power cord goes to switch terminal marked 3A , other pigtail of the white wire goes to board as described above.
-Black wire from power cord goes to swtich terminal marked 4B
Nov 14, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Told motor was bad, replaced motor, new motor does not run
Black to Black, Purple to White and the new motor requires a run capacitor which brown goes to one side of capacitor and brown/white goes to the othe side of the capacitor. This is providing the old motor is a single speed. If the old motor is a two speed you have an incorrect replacement motor.
May 02, 2009 | Heating & Cooling
Need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Feb 17, 2008 | Cameras
Sony SSC-CD73V Color Mini Fixed Dome Camera Logo
187 people viewed this question
Top Sony Home Security Experts
JonSnell Electronic
JonSnell Electronic
Are you a Sony Home Security Expert? Answer questions, earn points and help others
