Question about Toshiba Satellite M35X-S161 Notebook
Toshiba m35x s161 powers up 10 seconds and shuts down, will not boot. Nothing on the screen.
Where do you insert the hard drive in a toshiba satellite m35x-s161?
Fip it up side down, look at lap top rear on your right, remove screw just before footing, slide out the HD adapter/bracket.
Oct 22, 2010 | Toshiba Satellite M35X-S161 Notebook
My old laptop toshiba m35x-s161 won't turn on the light on the power botton turns on and it makes some noise but nothing more happens
Sounds like there is a faulty connection between the power switch and the computer. Probably why its making a little noise.
Take in for repair and replace power button.
Jul 24, 2010 | Toshiba Satellite M35X-S161 Notebook
My toshiba m35x-s161laptop has issues
may be the procesor unit(cpu) is too bot because a dust.....
Mar 06, 2010 | Toshiba Satellite M35X-S161 Notebook
When powering from full shut-down, takes about 30
whenever you want to turn it off, put it on hibernate.
Jan 02, 2010 | Toshiba Satellite M35X-S161 Notebook
Black Screen ALL MOST, some time it is ok, some time not.!!!!!!!
can you try to Attach an external monitor and check if it has the same problem on the external monitor?
Sep 12, 2009 | Toshiba Satellite M35X-S161 Notebook
Screen Issue
I would check to see if the RAM has become loose, if you can reseat the RAM. Do you hear any beeps when nothing is displayed?
Aug 18, 2009 | Toshiba Satellite M35X-S161 Notebook
Toshiba M35X-S161 motherboard replacement issues
How to remove back cove rof my Toshiba M35X-S161 to get the charging input jack to repair it?
Mar 28, 2009 | Toshiba Satellite M35X-S161 Notebook
Toshiba M35X S161 Ribbon Connector
You can buy another one cheap at a computer retailer, maybe. Search eBay too. There are various good things available there.
Nov 30, 2008 | Toshiba Satellite M35X-S161 Notebook
Wont start or boot up
I had the same problem and found that disconnecting the power lead and repositioning the ribbon cable from the on switch did the job after about 5 attempts
Aug 13, 2008 | Toshiba Satellite M30X Notebook
Toshiba m35x-s161 won't do anything...
can you access the bios if so reset to default and restart if you cant start up to as far as you can get then try a soft boot (ctl,alt,del all together at once) failing this you could try insert system disk and try to reboot and see if it try to install new copy.if you can get to any of these positions you can reset bios by unplugging and reconnecting rtc,this requires dismantling laptop,i may have service repair manual for your pc ,have to check
Feb 22, 2008 | Toshiba Satellite M35X-S161 Notebook
Computers & Internet Logo
81 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
