Question about Garden
Acts like dead battery/ I charged battery, still nothing.. I havedcvacross posts of battery (disconected) but when the ground is hookedupI have no dcv reading across battery. No instrumentpannellights/clicking....just dead. Is this a short? a malfunctionsaftyswitch? Battery problem?...if so..why would I get dcv readingacrossbattery untill neg side is connected? Thanks for your time. Don
  • Samuel Charles Spriggs May 11, 2010
    This doesn't sound possible. Are you sure you are checking the battery voltage correctly?
    That aside it sounds like one of the battery cables is loose or corroded or broken -- most likely the ground.
  • Dennis Mulford
    Dennis Mulford May 11, 2010
    did you check the fuse?
  • 246 Answers
Hello Don:
>>Have the Battery Load Tested.
>>The Battery will Show Good with a Meter until it is Connected to a Circuit, then it will Show No Current if there is a Weak Cell.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
Posted on Apr 21, 2009
1990 Ford econoline Van run's but when I shut it off and try starting it again it acts like the batterys dead! After awhile I come back and it starts right up! What could be causing the battery to act...
Make sure the battery is good, then clean the battery posts and cable ends, and make sure the negative ground from the battery to the engines block is clean and secure.
Feb 09, 2015 | Ford Cars & Trucks
No power to car
check to make sure the battery cables are tight and you have a good connection. make sure the ground wire is tightly secure to a solid metal ground.
Can it be jumped off?
If so, have the alternator checked at your local part store.
Apr 06, 2014 | 2003 Pontiac Sunfire
Truck will not turn over, gauges all come on but nothing from the engine, acts like dead battery but it is brand new...it did it before and was told it was the battery, put a new one in....worked great for...
your charging system isn't working, if you replaced the battery and it worked for a few days, then its not being re charged after starting, I'm assuming you cleaned and tightened all the battery post connections when you installed the new battery , if not do so ,, charge the battery from an outside source, once you know its fully charged,, use a meter, and start the car ,, check the voltages at the battery posts,, you should be getting a reading of 13.5-14.5 volts, if not your alternator isn't charging the battery
Sep 07, 2011 | 2004 GMC Sierra
1980 caddy coupe deville has brand new battery, brand new alternator but the battery keeps draining.
Something is staying on after the key is turned off. easy way to find out what is staying energized is pull all fuses, disconect the battery, then put the amp meter in line with the positive side of the system between the positive battery post and the positive cable end. then put the fuses back in one at a time a see which one draws one or two amps. that will lead you to the draw down circuit. If nothing is pulling the battery down then the battery is not getting a full charge. Check the ground conection at the motor side of the cable and also the ground strap between the motor and the firewall
Apr 18, 2011 | 1980 Cadillac Deville
No outputn on charging system only problem stated 3-4 weeks ago at 75 mph no power and battery lght on dash started flickering now battery dead charged battery and kept chage started engin e and...
I would suggest going to a auto parts store like AuotZone and have system check.They will do it for free.You also may want to try disconnecting the POSITIVE CABLE and not the NEGATIVE it will die when you disconnect the ground.
Mar 07, 2011 | 1999 Mercury Cougar
Car wont start, acts like battery is dead. battery shows full charge. full lights, buzzers, etc. put it on charger-didnt start...cleaned cable connections-didnt start...tried to jump with truck-didnt...
Check the battery +12v power connection to the starter is in good order,
Check the ground connection between the battery negative and the engine/starter motor is robust and intact.
If no problem with above, replace the starter motor.
Oct 10, 2009 | 1993 Ford Tempo
Wont charge new battery
maybe your new battery is messed up
Apr 07, 2008 | Apple iPod nano 3rd Generation
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
