Subwoofer amplifier I bought a Pioneer VSX-1018 Receiver, which I understand will allow me to run either a 7.1 system or a 5.1 system + a stereo system in a second zone simultaneously. My question is, can I use the second zone to drive a passive subwoofer instead? I have a 10" passive in-wall subwoofer and I would rather not have to buy a seperate amp.
    Sniper:
  • 86 Answers
Here's how I'd do it... connect the subwoofer pre-out to one of the unused analog inputs (CD or CD-R perhaps?). Turn on Zone 2 by pressing the MULTI-ZONE ON/OFF button. The MULTI-ZONE indicator will light.
Press CONTROL. (Zone 2 should display) Use the INPUT SELECTOR dial to select the source for the zone you have selected. In my example, CD or CD-R.
Of course, you'll need the sub hooked up to the Surround back speaker terminals.
Here's a link to the manual online:
Pioneer VSX-1018 Manual
Things to keep in mind:
The Surround Back setting must be set to ZONE 2. See page 41 of the manual.
The volume level going to the sub will probably need some tweaking. Check out page 7 to see how to manually adjust volume levels, or get it close by adjusting the Master Volume while in Zone 2 control.
I'm not sure if the auto setup function (with the included microphone) will work properly with this setup. And, of course, this is not a "suggested" setup by Pioneer, so please use caution when hooking everything up.
Posted on Apr 21, 2009
Pioneer Elite vsx-27tx receiver with no bass!?
There may be a subwoofer mute function on your amp. The sub out is nothing more than a preamp output with a low frequency response. It is meant to be amplified by an external amp. Either check your powered subwoofer for operation or look through your operators manual for a sub mute function.
Feb 11, 2010 | Pioneer VSX-27TX Receiver
Have a Pioneer VSX-1018 receiver. When I connect
You speakers are out of phase. Check to see if the polarity is correct on the receiver and the speaker. Positive (red) with positive, negative with negative (black). Also check the impedance of the speaker, it should be located on the back of the speaker measured in ohms. Make sure that your receiver matches the impedance of your speaker. You can find this in the settings of the receiver.
Dec 08, 2009 | Pioneer VSX-1018AH-K Receiver
Just fried my 2nd home stereo receiver
yeah check the ohms for the receiver an see what the subwoofer ohms are.that can fry them
Oct 04, 2009 | Pioneer VSX-D509S Receiver
Speakers for pioneer vsx 1018
I think you're making this way more complex than it is.
This unit should have no trouble with any reputable speaker. Don't read too much into short term impedance readings as long as you run only one speaker per channel. Every speaker has a dip somewhere in its frequency range and the Pioneer will probably protect itself and the speaker should impedance or current get too out of whack. This is a high end unit and has plenty of clean power to feed any speakers out there.
I'd buy it if I didn't already have a 6-year old predecessor (VSX-T36TX) that I paid twice as much for and has only 5 amplified channels, less features and lower power output. ;-(
Good luck and happy listening!
Mar 28, 2009 | Pioneer VSX-1015TXK Receiver
Sibilant output from Pioneer VSX 1018 AH-S
Suspect a DTS board capacitor failures the ESR characteristics.
To troubleshoot connected any available device to RCA stereo connections at input to multi channel in. Test input to the corresponding speaker output confirming audio quality. This circuit bi-passes the DTS function and connects to the power amplifier for the speaker.
Connect any audio amplifier from the preamp out and confirm the quality of the audio.
I suspect that the pre-amp out will contain the distortedf noise. If the distrotion appears in all the channels it is most likely the DTS.
These are repairable.
Hope this helps?
May 09, 2017 | Pioneer VSX-1015TXK Receiver
Pioneer vsx 90txv and bose EQ
I wrote this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great! With one caveat - My receiver actually has 5.1 analog Outputs so I can drive up to 6 external amplifiers if I want to (I drive 4). IF yours does NOT (*) we have to be creative in extracting the front two channels from your multi-channel receiver. The obvious alternative place would be at one of the few OUTputs on the back, assuming you have one free to use.
* I can't find your exact manual so I have to extrapolate features.
I see on the SR>6003< there are Pre Audio OUTS so I'm betting your receiver does, too.
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out; (or VCR or Tape Out if you don't have Pre Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
*** If you use a Tape or VCR Out you will NOT be able to SELECT the source you use for the 901 Pre-Outs for listening, or else the 901's will not get any sound sent their way. DO NOT USE the monitor switch for that source.
Feb 01, 2009 | Pioneer VSX-90TXV Receiver
How to connect 901 equalizer to a Pioneer VSX 47TX
I have a VSX-36TX so this is how it's going to work...
You will need a separate stereo amplifier for the 901's to accomodate the need for the Active EQ. There is no way to separate your receiver's front L&R channel preamplifiers from their amplifiers.
I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver and the 901's amp channels. My receiver controls everything and just drives the Center and Surrounds. You would probably just get a nice 2-channel amplier for the 901's. However, the VSX 47TX doesn't provide power for a Subwoofer, should you decide to get one, so you would need another amplifier channel for that, too. Therefore, you might look around for a powerful 3- or 4-channel amplifier so you could drive the Sub, too.
Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. I'm using only 100W for mine and it has plenty of steam for the 901's.
For connection I would run a pair of RCA cables from the Front L&R Audio Line OUT to the Active EQ's Line IN; then the EQ's Line OUT to a separate amp's Line IN. Attach the 901's to the new amp, run through the receiver's setup procedures for volume, etc and you're done.
Not what you might want to hear but 901's have special requirements. I've had mine for 25 years and have no regrets.
A separate subwoofer channel on the amp could be used. Just run a single RCA channel from Sub OUT to one available channel IN on the amp and attach the subwoofer to it. Two would work, also. That's what I do. You could use a 1-2 RCA splitter to feed two avaailable channels on a 4-channel amp. The iterations are many. Have fun.
Jan 24, 2009 | Bose 901 VI Main / Stereo Speaker
Sub woofer
The subwoofer is totally independent from your Pioneer VSX-D412. You can check if it works like you did with a finger on the hot point of the RCA cable (not very good test, as you will hear noise and can't say if that means it works OK) or better connect a known receiver to the speaker connections in the sub and test to see if it’s working properly.
Regarding the receiver, you may not have enabled the VSX to output to the sub. Read the manual on how to check for that. Only Dolby Digital 5.1 signals will allow the sub out, in a receiver of this level. It normally will not let you use the sub in stereo mode. Some more complex units will allow you that, but I believe not this model.
Good luck
Nov 01, 2008 | Pioneer VSX-D412 Receiver
Pioneer VSX-505S Subwoofer Installation
That type of subwoofer is not used with this receiver. This receiver actually outputs no power for a subwoofer, therefore only needs a plain ol' rca signal wire. This is due to the fact that you need a powered sub... one that you plug in to the wall and it has its own built in amp. you simply run an rca from yyour 505s to that sub.
Feb 10, 2008 | Pioneer VSX-505S Receiver
370 people viewed this question
 Grubhead
Grubhead
