Question about Zyxel AG-225H (AG225H) 802.11a/g/b Wireless Adapter
DLL Install Conflicts
AG-225Hv2.exe Illegal System DLL Relocation OS - XP 32 The system DLL user32.dll was relocated in memory.The application will not run properly.The relocation occured because the DLL C:\windows\system32\HHCTRL.OCX occupied address range reserved for windows system DLLs. The vendor supplying the DLL should be contacted for a new DLL. Failed to load control ?SocketXCtl? from SocketX.OCX. Your version of SocketX.OCX may be outdated. Make sure you are using the version of the control that was provided with your application. Regards Cawboye
Re: DLL Install Conflicts - Zyxel AG-225H (AG225H) 802.11a/g/b Wireless Adapter Network & Wireless Adapters
Socketxclt outdated
Posted on Jan 02, 2008
I had the same issues. This link should give you an update that will help fix the issue.
Posted on Nov 19, 2007
0 characters
3 Points
Can i add a wireless dual band usb adaptor for wifi to my xp home edition
yes. System Requirements OS: Windows 7(32/64bits), Windows Vista(32/64bits), Windows XP(32/64bits)
Oct 15, 2014 | TP-LINK Network & Wireless Adapters
Wireless adapter problem
Dec 30, 2011 | Trendnet TEW-664UB IEEE 802.11a/b/g IEEE...
Entry point apsCreate MIB could not be located in the dynamic link wlanapi.dll
I don't see a question but I assume you are getting this message from your OS when you boot the computer. Uninstall the device shut down the computer and reboot then reinstall the device. This should reload the .dll file that is causing you problems.
Oct 12, 2009 | D-Link Network & Wireless Adapters
I have a error each time i start my computer it said.. the procedure entry point apsGetinterface count could not be located in the dynamic link library wlanapi.dll.
this is a wireless lan or router program.. install the program by disable antivirus on your system. Sometimes the program cannot copy to the system due to virus signature of it might your antivirus that file a virus then he remove it automatically. Run the setup on you router or wireless lan on it. Good luck!
Jul 22, 2009 | Network & Wireless Adapters
AegisE5.dll was not found.
The file bcmwltry.exe is the tray bar process for the Broadcom Corporation Wireless Network software.
You can try eliminating the program from start up.
Click on Start >>Run, type "msconfig" (without the quotes), then click on OK.
When the System Configuration Utility loads, click on the "Start Up" tab, then scroll down to the "bcmwlt.exe" entry and UNCHECK the box next to it.
Click on Apply, then OK, and the computer will need to be restarted. Do it. Upon restart, you'll see a System Configuration Utility warning. Simply choose the option to stop it from repeatedly opening.
This will be fixing your problem
Have a great day!
Pablo :-)
Oct 22, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Sounds like you have a corrupted ActiveX control. Fortunately it is very easy to verify this by locating a folder in your Windows sub folder call Downloaded Program Files. c:\(windows)\Downloaded Program Files\.
Once you open this folder you can right click the ActiveX control entry and select update or in most cases choose Properties to diagnose a problem. When you select Properties, you'll be presented with a popup with three tabs, the dependency tab, when selected, may have a notice that the Control is damaged/broken. If it is, back out and then right click the Control in question and choose Remove. When needed the ActiveX control will download again.
If however, you get this Alert of an attempt to relocate in memory a critical system file then chances are high this ActiveX control is Malware or a Trojan because according to Microsoft programming standards, there is never a reason to change that DLL in question and this is one of many DLLs that have reserved addresses in memory for a reason. It would only be attempting to change that file if you are under attack.
To be certain you are virus/malware/trojan clean go to:
It too will want to download and install an ActiveX control so look for the Alert Bar and you can definetly trust this Control. Once installed it will scan your system using a database at their online site that has not chance of being infected.
If you have any questions, concerns or need for more clarification please don't hesitate to use the comment box below to contact me.
Jun 11, 2008 | Network & Wireless Adapters
Hi , yes it's a known problem and Microsoft/DLink both has confirmed that.
Please download the updated drivers by clicking on the link. below. AS er your information your router's model no. is the 6th entry on the page.DWL-G630_revE. Download and re-install the drivers.
It will fix the problem
For more information
Jun 05, 2008 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
DWL-G630 WinXP SP3
Hi everyone who upgraded to SP3 or Vista! I just wanted to let you know that I also encountered the same exact problem when upgrading another person's computer, and the answer to your question (which has already been suggested) is to get the updated driver directly from the manufacturer:
Make sure you click on the driver for your EXACT model number. If you do not have internet connectivity at all on the affected computer, then dowload the driver's zip file to a portable USB memory stick (or CD, or DVD) on another computer and transfer it to the affected computer that way.
Next, unplug the D-Link.
Next, open the Zip file with the driver and run the setup.exe file. It will uninstall the existing installation first. Then you have to RE-click on the setup.exe file to reinstall the correct driver. If it asks you if you wan to use the Windows Zero Configuration Utility, tell it Yes.
This is absolutely the correct answer/solution. No guesswork involved.
-Tha Mp3 Doctor
May 07, 2008 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Application won't start up (VIsta)
if you managed to get the driver installed, you should get an option to use either windows wireless management or the software that came with the adapter, you may be able to dissable the cards software and use windows own
Sep 09, 2007 | D-Link AirPlus G DWL-G510 802.11g/b...
Zyxel AG-225H (AG225H) 802.11a/g/b Wireless Adapter Logo
239 people viewed this question
Top Zyxel Network & Wireless Adapters Experts
 C. Dante
C. Dante
Are you a Zyxel Network and Wireless Adapter Expert? Answer questions, earn points and help others
