Paper jam in Gestetner DSm645 in the area of "A". There is no visible paper that we can get to.
  • jill608 Apr 21, 2009
    We got the "tiny" piece of paper! Thank you
  • 19,396 Answers
To start cut power by unplugging power cord or tripping circuit breaker, wait ten minutes and see if this clears the error.
If that did not work, open the Duplex unit , and open the blue lever marked A2 in there, check for any tiny piece of paper that can trigger the misfeed error.
If no paper in there, then locate a blue knob marked A1, open in there and check there.
If still nothing , then open the bypass Tray and check for misfed paper.
You find the whole procedure with pictures here, pass the mouse arrow on blue words on website to see pictures.
Thanks.
Posted on Apr 21, 2009
DSm725 paper misfeed error
try cleaning the feed wheel in the paper tray cause that will not be picking up paper works for me .try using a damp cloth
Aug 20, 2013 | Gestetner DSm725 All-In-One Laser Printer
I CANNOT PRINT BUT i CAN PING THE PRINTER ON THE NETWORK ONLY A BEEP SOUNDS IS HEARD BUT NO PAPER OUT WHAT CAN I DO?
http://www.ricoh-support.com/enduser/gestetner/downloads.asp?FileID=27968&ricohmodelid=6161&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fbb%2Fhtml%2Fdr%5Fut%5Fe%2Fnrg%2Fmodel%2Fx2035e%5F45e%2Fx2035e%5F45een%2Ehtm
select the link which i have provided above and it should take you to the correct driver most times if you can ping the ip of a printer then its an incorrect driver software which is not allowing your system to print
Mar 02, 2012 | Gestetner DSm645 All-In-One Printer
I have a problem. When I turn on my printer, the first symbol from top constantly blinks and it doesn't print anything. How can I solve this issue?
Welcome to FixYa!
If the first symbol on the top is constantly blinking as shown in the picture below, It means that a paper or a foreign object has jammed your printer.
Jam can occur in 3 areas. Please refer to the image below.
1. Internal Areas
2. Input Trays
3. The Output Bins
To clear the jam, turn the printer off and disconnect the power cord. Be careful not to tear the paper in case of a paper jam. If a small piece of paper remains in the printer, it could cause additional paper jam.
Let's clear out the Internal Areas first. Push the button to open the print-cartridge door, and then remove the print cartridge. To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper. Please refer to the image below.
If jammed paper is visible, grasp it with both hands and slowly pull it out of the printer. Please refer to the image below.
If no paper was jammed inside the print-cartridge door, open the Output Bin or the back door
of the printer. To avoid damaging the printer, do not attempt to clear a jam in the top output bin by pulling the paper straight out.
Again, if jammed paper is visible, grasp it with both hands and slowly pull it out of the printer.
If no paper or foreign object is visible, close the back door of the printer.
Next, let's take a look at the Input Tray. (We have already taken out the print cartridge.)
Lift the Tray 1 roller cover, grasp the jammed paper or foreign object, and slowly pull it out of the printer. Please refer to the image below.
If no jammed paper is or foreign object is visible, open Tray 2 and see if a paper is visible. Again remove it slowly with both hands. Please refer to the image below.
Close Tray 2.
If no jammed paper is visible in the second tray area, pull down the upper media guide (we have already taken out the print cartridge). With both hands, grasp the jammed paper and slowly pull it out of the printer. Please refer to the image below.
Close the upper media guide and return back the print cartridge. Please refer to the image below.
These steps should clear out any jams that you are experiencing.
Connect back the power cord again and turn on your printer. You should be able to print now.
Thanks for using FixYa. Keep me posted.
Jas247
Mar 03, 2011 | HP LaserJet Black-and-White Laser Printer
I got a strait black thin line on left marging of paper
please let me know the the problem is comming while taking the copy or printing if problem comes on both first check the drum module and LD unit - thanks
Dec 26, 2010 | Gestetner DSm645 Digital Imaging System
Can't find paper jam. Looked and looked. Its a
hi if u cant find any bit of paper in paper path may be any path sensor out of order or may be dusty sensor just clean the all paper path sensors
thanks
May 13, 2010 | Gestetner DSm618d Copier
Getting paper feed jams
Hello sir; Try to press the "clearmode " key , on the right hand side top of the control panal.
Jan 31, 2010 | Gestetner DSm645 Digital Imaging System
Brother mfc8220 jam problem
We looked everywhere for a piece of paper stuck in the machine and couldn't find it. We finally fixed the problem by moving the paper size adjuster in the paper try until it was right up against the paper. If the paper is free to move around in the tray, apparently the machine sees that as a paper jam.
Feb 03, 2009 | Brother MFC-8220 Fax
Making black copies
Depends on how you scanned it by having the lid opened and no paper on the scanner. Are they totally black?
Jun 27, 2008 | Gestetner DSm645 Digital Imaging System
WRONG PAPER FEED
sounds like the paper size you are using is not set for that type.
If it is Letter you are using make sure you have letter in the tray, and depending on the machine it must also be in the same direction. If it is letter the long way make sure it is in the tray the same way.
Jan 22, 2008 | Gestetner DSm645 Digital Imaging System
Dsm651sp
Repalce the pick up rollers,paper feed rollers, seperation rollers of the trays which gives the pper jam
Oct 22, 2007 | Gestetner DSM 651 Copier
55 people viewed this question
k24674
jasbo
jasbo
