Question about Sunpak DX-8R TTL Ring Light Flash
Flash compatibility is the sunpack electronic ringlite compatible with the nikon d40
  • 4 Answers
According to what I read the sunpak dx-8r is, with the right module, compatable with digital SLRs. Check with B&H photo to get the right module.
Posted on Sep 19, 2009
Sca 346/2AF M don't recognized on Nikon D40 like TTL
Film Cameras were NIKON TTL Nikon Digital Cameras are I-TTL. These two systems are not compatible. Film cameras did the metering in real time. When enough light struck the film the flash was turned off. With I-TTL the flash fires a quick flash and the image is quickly analyzed and the flash fires again to take the photo. With digital it is delayed and it is NOT in real time. The camera only looks at a few pixels to make the analysis fast. I hope this helps
Sep 22, 2017 | Nikon Cameras
Sunpack Compatibilty
ifyour nikon has a hotshoe it should work quite well. I use sunpak flash on both canon and olympus without any problems. Just connect to hotshoe and shoot.
Please rate my help++++Thanks for using FIXYA
Jun 03, 2010 | Sunpak 383 Super Flash
Is a Quantaray QF30 compatible for a Nikon D40 camera?
I bought this flash on craigs list today for about 30 dollars. I did research and as long as the flash you buy is a nikon HOT SHOE mount it will work. (Look on the bottom of the flash) it will say Nikon i-ttl. I am using it on my D40.
May 12, 2009 | Quantaray QF30 for Nikon Flash
Is the quantaray 55mm lens hood compatible with a d40
yes and no. no because the lens diameter of the 18-55 is 52mm and yes if you use a stepping ring that you screw on the 18-55 to accommodate the 55mm hood.
Feb 22, 2009 | Quantaray Cameras
Sunpack pz40X II flash - compatible with Nikon D40?
hai i think u told only sometime....
may b ur settings are not rit in the cam.
Jan 07, 2009 | Sunpak PZ40X II TTL Flash
D40 compatability with Sunpak auto 144D flash
the voltage on the flash hot shoe contacts (center pin and rail connector) can be as high as 140V DC and this voltage is backfed into the camera through its hotshoe connector. There are adapters that can be bought that isolate this voltage that go between the flash and the camera, but different camera makers have different ratings for the flash voltage. My Vivitar 220 has 122 volts across the contacts from 4 AA batteries! Canon recommends nothing over 6v but Fuji says 60v and others dont say anything. SLR's used a mechanical trigger, modern digi cams use an electronic trigger. Also Digcams use electronic metering for exposure so they dont take into consideration the addition of another flash unless they do a preflash, TTL metering and the flash unit is capable of recharging in about 1/10th second. YOu may have to do some post processing or set the camera on manual to adjust the exposure.
Jun 08, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Sunpak auto 144D flash compatability
Seems to work OK with my Nikon D80
Jun 08, 2008 | Sunpak Auto 144PC Flash
Auto focusing problem
Your camera is only compatable with AFS-type lenses because it has no screw-drive motor.  You can only use AFS Nikkors and Sigma HSM lenses (the lens actually has a motor inside).  You were misinformed.  Bring the lens back and ask for a refund. Take that money and purchase a compatable lens somewhere else.
Sep 22, 2007 | Quantaray 500mm/1000mm Preset Telephoto...
Sunpak DX-8R TTL Ring Light Flash Logo
253 people viewed this question
Top Sunpak Cameras Experts
bhargav
Doberman
Are you a Sunpak Camera Expert? Answer questions, earn points and help others
