Question about Refrigerators
Older Admiral refrigerator. ice maker doesnt turn off
Older Admiral refrigerator. The ice maker workd fine other then it does not turn itself off when bin is full, completely overfilling compartment, however does turn off when I mannualy lift the bail bar to stop position.
  • 2 more comments
  • gabebaker Apr 21, 2009
    Bail looks to be in proper condition and position. I did go ahead and remove the bail and lessend the angle on it by slightly bending it before reinstalling. Will see if this solves the problem. Is there a microswitch of some kind that the bail pushes on once bail rises to full positon?
    Thanks for your assistance...
  • gabebaker Apr 22, 2009
    That is what I am thinking (not enough pressure on switch). How do I get to it to check and make sure it is secure? If bail re-position doesn't solve, I will likely go to the switch next. How does the cover come off?
    Gabe
  • Samuel Charles Spriggs May 11, 2010
    Yes, there is a switch the bail operates. If you can get the switch to actuate by moving the bail by hand, it should be okay -- maybe it's just requiring more pressure than it has been. This might indicate the switch is loose in its mount (??)
    Sounds like the bail has been bent upwards. This causes the cutoff point to be too high for the ice to push it up to the off position. Check this and let me know if it has been bent.
    President:
  • 1,489 Answers
Gabe,
I'm not familiar with this particular icemaker, but the cover will either pop/snap off or it has a screw or two in it. Make sure there are no screws before you try to pop it off. You sound pretty handy, so I have confidence you will get it off successfully.
Charlie
Posted on Apr 22, 2009
Ice maker is not producing ice. the water dispenser on the door is working just fine. turned off the freezer to see if the line to the icemaker was frozen, still no luck. ideas??
Your ice maker may have gotten switched off inadvertently. Check the position of the bail. If it is in the raised position ice making is turned off
Aug 14, 2013 | Admiral 26 cu. ft. Side-By-Side...
Noisy ice maker
There should be a lever on the ice maker that you flip up to stop it from making ice.
Mar 20, 2010 | Admiral 26 cu. ft. Side-By-Side...
Ice maker stoped
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
yy
Sep 25, 2009 | Admiral 26 cu. ft. Side-By-Side...
My ice maker quit making ice. I've had this
Check for broken gear or cam in the ice maker module. You can repair them but it might be easier to replace. If your gear and cam are good it pobably is something else that's wrong.
Jul 05, 2009 | Admiral 26 cu. ft. Side-By-Side...
Whirlpool refrigerator ice dispenser no longer workds
HI, the Ice maker control module will need to be replaced in your unit asap if possible. this module controls and initiates the actions when the lever is depressed.
Jun 05, 2009 | Whirlpool GS6SHAXLS Side by Side...
Admiral side by side refrigerator ,model sal2027gbb
icemaker water valve is bad check to see if you can tell if the unit is turning
Apr 16, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice maker is not working
Check that the arm is down on the ice maker itself, also read the instruction manual to see if there is a seperate on/off switch for the ice maker
Feb 12, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral Refrigerator Ice Maker
pull your icemaker tube out and see if it is frozen with ice,let me know-mike
Sep 22, 2008 | Admiral Refrigerators
Admiral Ice maker water filter, which one?
I have an admiral HMG19149 refrgerator with an ice maker. my problem is that the ice tast horable and cant be used. I looked for a filter to change but can't find it. Please help
Jan 14, 2008 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
122 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
