Question about Compaq Presario X6000 Notebook
Laptop motherboard repair components
My compaq presario X6000 stopped working, due to problem in power circuit on motherboard. took motherboard out to find two power MOSFETs burned. their number is BE443G, I cant find those components any where to buy. can you help?? Guess i can replace those with 348D IC.
Re: laptop motherboard repair components
Bonjour j'ai un laptop dell qui s'aliment avec le chargeur et la battery mai ne charge pas
Posted on Jan 08, 2014
Re: laptop motherboard repair components - Compaq Presario X6000 Notebook PC Laptops
Over hit chip under battery
Posted on Jan 03, 2008
  • 68 Answers
The best way to find the part you need is search around for the board manufactures name. Then goto there web site. You may be able to download technical data right off the manufactures web site. Over heating is a big problem with lap tops. You never want to place your laptop on a soft surface when its on. A soft surface blocks the fan from extracting heat from your laptop , resulting in a over heat and eventually failure. You want to place your lap top on a hard surface when its on. This will provide ample room for your fans to cool your lap top efficiently. You can also purchase a laptop docking plate. It not only is a hard surface but also it has its own fan to increase the cooling capability of your laptop.
Posted on Sep 22, 2007
0 characters
3 Points
Can I get a presario to boot vga output only?
Yes you can go ahead and use an external moniter to use your notebook but reformating would not help. try to go to HP.COM nad get the graphis driver and bios updated still if its the same you need to contact HP and they would take it for repair, however if it is not in warranty then they would charge you, for repair,since the graphics card is always embedded with the motherboard it will not be possible to replace it on your own. you can also check the repair prices in local stores.
Apr 13, 2010 | Compaq Presario X6000 Notebook
Compaq presario f560us will not come to life
It is due to one or more faulty components on the motherboard. You have nothing to do unless you are a laptop technician.If you can do chiplevel repairing I can further assist you as I am a chip level technician.Contact me. Make a comment for this.
Mar 08, 2010 | HP Compaq Presario F560US Notebook
I have Presario X6000 keyboard problems
it is doing so because of the faulty keyboard ..pls see the backspace button is stuck or not can clean the keyboard by removing it ..
Thank You
Dec 07, 2009 | Compaq Presario X6000 Notebook
My compaq presario is not charging and I bought a new charger for it and it still wont stay on for longer than a min it just cuts off if I fiddle with the power cord a little the screen changes from a dim...
common problem,power cord gets pulled on accidently,causes plug inside computer to pull loose from the motherboard.will need to disassemble,then usually just touching the connections with a soldering iron to remelt them is enough to fix it,leave this to qualified tech.or if under warranty then send for repair hope this helps ,aloha from maui todd0708
Oct 22, 2009 | Compaq Presario X6000 Notebook
Laptop wont stay on longer than approx 3 seconds. How do I check the switch?
if the switch at least starts the laptop.. then it is not the switch
check that you can boot the pc with the battery pulled out of the laptop and the power supply plugged in...
if this works then you need a new battery
if this does not work.... then the motherboard or the power adapter plug maybe the issue.. is the plug on the side of the laptop solid... or sloppy fitting..
if solid then the motherboard cpu and memory are the suspected components next..
is there beep noises during boot for the three seconds that occur???
Sep 28, 2009 | Compaq Presario X6000 Notebook
Laptop screen turns white
You can put your laptop on top of a icepack, cause your Graphics card is probably getting to hot. Thats why your screen turns white(probably only when gaming).
It is likely one of your fans is broken
Feb 24, 2009 | Compaq Presario X6000 Notebook
Compaq Presario Laptop powers on but turns off in less than a second
Before I can help you ,I need the model number or the "service tag" number off the bottom of the computer.
Whenever you ask a tech question you must always begin with a model number / part number,etc. HP makes hundreds of different model Presario Laptops and each has it's own quirks. Only with a model number can an accurate diagnoses be made.
Aug 19, 2008 | Compaq Presario X6000 Notebook
Compaq Presario X6000 PC Notebook power connector gone bad
Welcome to FIXYA
a common problem for all laptops when you plug in and remove it alot there is not recall on any laptop i know of for this problem and your repair man is right you will need to take it in and have it repaired for where no clue i do know if you call the company to have them fix it they will but will cost you and might take a few weeks to get it back
hope this helped out have a good day :)
Jul 16, 2008 | Compaq Presario X6000 Notebook
Compaq Presario X6000 Notebook Logo
393 people viewed this question
Top Compaq PC Laptops Experts
John mullen
 Mike M
Mike M
Are you a Compaq PC Laptop Expert? Answer questions, earn points and help others
