Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
I have had my hp dv2700 notebook for a little over a year now and it gets pretty hot also. It does this thing where its internal fan revs up over and over sometimes for 15 minutes...when returning from sleep mode. i have an intel core 2 duo, t7250, with 2ghz of memory. It works wonderfully other than the getting pretty warm from time to time. Basically, all I did was get a targus laptop (dual) fan and now it rarely gets to that super hot point. DONT put your laptop on a pillow, or bed, or carpet while using it for extensive periods...as with any laptop it just needs to breath to function. i would suggest the dual fan though...whenever it starts getting a little warm....turn on the fan and put a folder or something hard under the fan so the ventallation is there. this will do the trick....assuming you aren't having multilple problems with your hp dv2000.
Even i am also having HP pavilion dv 2700 and purchased 1 and half back. My battery is not charging properly and engineer said the problem with motherbaord. I dont know how HP doing such kind of poor designing. after 6 months from the purchase the hard disk is correpted and all my data gone and could not be able to recover. Thank god my laptop was under warranty...
Hope HP is purposefully doing this kind of design... some of my friend having IBM and DELL and they never faced any problem with their laptop.
Posted on Feb 08, 2010
Blow out the intake vents as these get clogged with dust and fluff. Had one in just the other day and after five minututes thought I could fry an egg on it. After blowing out the vents coolled off and is now runing as it should
Posted on Apr 25, 2009
How to properly disassemble hp 6730b to clean fan
https://www.youtube.com/results?search_query=hp+6730b+disassembly hp 6730b disassembly YouTube
Sep 30, 2016 | HP Compaq 6730b Notebook PC
COOLING FANS HAS STOPPED WORKING in my laptop. HP Pavillion DV2700 dv 2915nr
If your computer still works, turns on and boots the OS. Then it's most likely just the fan it's self that is bad.
Aug 05, 2011 | HP Pavilion dv4000 Notebook
How can i get the drivers of my laptop HP pavilion dv2700 Notebook PC
Download HP pavilion dv2700 Notebook PC drivers from the below link
http://tinyurl.com/dv2700drivers
Jan 13, 2011 | HP Pavilion dv6000z Notebook
My fan runs extremely loud on and off
It is set up to run if CPU gets warm/hot. Quiet normal.
If it didn't you would son know. One Cooked CPU with Chips. Expensive tak Away.
Some fans are noisey. You could go to the expense and have a replacement???
Nov 16, 2009 | HP Pavilion dv2915nr Notebook
Hp pavillon is roasting hot fan working but not cooling any ideas
Put something between the table and the notebook PC so that there is some ventilation. This might cool down the notebook. That is what I do for my Thoshiba laptop. Another option is you can buy something that is made specifically for this purpose. It is a small square shaped plastic sheet like thing which as a few small fans in it. The fan takes it power from usb port. The whole thing is about 7or 8(maybe even lesser) mm thick. Price around $20. Or else buy the smallest fan that runs on 110v (if your normal power is 110V AC) you can get and put it behind the notebook facing outwards. Idea is to exhaust the hot air from the surrounding of the notebook.
Oct 30, 2009 | HP Compaq Presario 2500 HP Pavilion ZE...
HP Pavillion Entertainment PC overheating and turning itself off. Tried to to buy a Gear Head external fan to cool but not helping. What to do?
Mine got so hot the Motherboard burnt up and cost $300 to fix. It still gets hot and I use a cooling fan. This is REDICULOUS!!
Sep 21, 2009 | HP Pavilion dv7-1132nr Notebook PC
Dv2700 when starting laptop only goes first screen
If it will boot from the windows disc, install the disc and boot from cd. When windows loads, go through the start repair or recover.
Aug 30, 2009 | HP Pavilion dv2915nr Notebook
Laptop getting very hot
Make sure that the internal fan is cycling or working. if this fan is not running, it will allow the laptop to reach unsafe temperatures that will damage the circuitry over time.
Replace the cooling fans if they are not functioning.
May 31, 2009 | HP Compaq nc6320 Notebook
HP Pavilion dv2000
I have a 3 year-old DV2000 that recently has been overheating and shutting itself down. I installed a program called Core Temp to see if it was overheating. After switching it on, the temperature would quickly climb to about 80ºC at idle and go above 90º if I used the internet or any program that required a lot of processing. I saw the temperature go up to 100ºC whilst using Skype yesterday, at which point the computer switched off and I had to let it cool down for a while before switching it back on. It was also running incredibly slowly at times and I was worried it might have a virus.
Today I finally found a can of compressed air (hard to find here in Bogota) and sprayed some into the air vents at the back left-hand corner (this took about 2 minutes). When I switched the computer on, the temperature was stable at 55ºC and has reached a maximum of 60ºC under load. Right now, it is at 58ºC and is running much faster than it was before. The product I used is called "Air Express" (made in Mexico) and it is basically a canister of compressed air.
Feb 19, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
898 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
