Question about Northstar Explorer 550 GPS Receiver
Each time i switch off Northstar GPS-60 on aircraft,i have to reinsert the flight plan .Perhaps 3.2 Volt Memory Battery has gone dead. Where can i get the battery?How to replace it? abk sinha India
Where can I see a list of which aircraft has been legally flying over our house?
You can use a program like flightaware.com to see flights that are on an instrument flight plan. That won't get you any info on most flights though.
Jan 04, 2017 | Aircrafts
Gpsmap 180 firmware corrupt
It sounds like it has lost its memory battery. Usually you
would get a "memory battery low" message as it is on its
way out but you don't mention that so perhaps it has
completely failed.
The battery is rechargeable - if you leave it switched off
and loaded with a fresh set of alkalines for a few days it
may recover. If not contact Garmin as they have replaced
many memory batteries free of charge even out of warranty.
Oct 30, 2007 | Garmin GPSMAP 430 GPS Receiver
Tip
Learn About an Aircraft, Part 1
First we'll cover panel instruments and how they're used.
Familiarize yourself with the six pack.The six instruments in the center of the instrument panel used mostly for IFR (Instrument Flight Rules) and are always in the following order:
  • Top left: The "Airspeed Indicator" shows aircraft airspeed, in knots. (nautical miles) per hour. It also displays the airspeed limitations in white, green, yellow, and red arcs.
  • Top center: The "Artificial Horizon" Has a small aircraft symbol that depicts the aircraft required attitude,for level flight, and shows whether the aircraft is climbing or descending, as well as the angle of bank.
  • Top right: The "Altimeter" a three hand clock type instrument that shows altitude of the aircraft in feet MSL, (feet above mean sea level).
  • Lower left: The "Turn and Bank Indicator" is a dual instrument which tells your angle of bank and whether you are in a coordinated turn. Sometimes called the "Needle Ball". For straight and level flight, keep the wings level and the ball centered.
  • Lower center:The "Heading Indicator". A stable gyro instrument that shows the aircraft's current compass heading. Use the Control Wheel to keep the aircraft on the desired heading.
  • Lower right: The "Vertical Speed Indicator" which tells how fast you are losing or gaining altitude, in feet per minute. Keep this instrument at zero to maintain level flight.
http://i.fixya.nethttp://i.fixya.net25643176-w123deulyqo0pc5nhlq3ghvj-3-0.jpg
on Apr 12, 2015 | Sport & Outdoor - Others
Camera wont turn off
As long as the memory access light is flashing, you should not try to switch off a camera.
If no light is burning, you can remove the battery (batteries) and wait a few seconds, before reinserting the battery.
If your power button is causing he trouble, perhaps you can't switch it on anymore.
But sometimes it is just a software problem, and will be gone after this trick.
If the error keeps coming back, or you can't switch the camera on again, contact your camera shop, of a certified polaroid service centre.
(Or buy a new camera?)
Feb 20, 2014 | Polaroid Cameras
Microsoft FSX - Aircraft flies "Nose-up"
This is a calibration issue for the controller you are using. Recalibrate it. It is receiving and elevator down instruction.
Mar 27, 2009 | Microsoft Flight Simulator X for Windows
Saitek X52 Flight Control Problem
Make sure you have the latest drivers for your operating system and graphics card, including direct X. Good luck
Feb 02, 2009 | Saitek X52 Flight Control System
Remove the X52 and drivers from your system. You have to install them in a certain order, so look in the documentation for the correct way to install and you will be okay. Good luck
Feb 02, 2009 | Saitek Pro Flight Yoke System Flight...
Garmin 295 GPS will not turn on
I had this exact problem. I deactivated the flight plan that was still in the system from my last flight & the problem went away.
Jun 21, 2008 | GPS
Garmin gps failure
Bought a PN-60. Purchase download for costa rica, will not download software. Did a auto detect, no dive found. This is a new cable and the usb port has port has been checked with other devices. Stuck in Costa Rica with a use gps. Cost of shipping this back is not cheap.
Mar 31, 2008 | GPS
Northstar Explorer 550 GPS Receiver Logo
159 people viewed this question
Top Northstar GPS Experts
Are you a Northstar GPS Expert? Answer questions, earn points and help others
