Question about Garden
We have connected up the hose pipe and plugged in the washer and it keeps turning off! What are we doing wrong?
    Problem Solver:
  • 10 Answers
Most washers when turned on will build up pressure and then go into bypass(shut off) untill trigger is pulled,
Posted on Apr 22, 2009
My F09 and my E01 codes keep coming on in mid cycle and shutting down the cycle
F09/E01 are related codes.
LONG DRAIN: If the drain time exceeds 8 minutes without reaching reset level in pressure sensor, the valves are turned off and the drain pump will stop running. NOTE: Suds can cause delays in draining. Washer drains for 4 minutes, pauses 5 minutes, then tries again for 4 additional minutes of draining. F9E1 will display if washer does not drain. (Normal drain takes less than 2 minutes)
Possible Causes:
Verify that the drain hose is not blocked or kinked.
Make sure drain hose is not sealed into drain pipe.
Make sure the drain hose height does not exceed 96" (2.4 m).
Check/clean drain pump filter of foreign objects.
Check connections from tub to air trap, air trap to pressure hose, and pressure hose to pressure sensor.
See TEST #8 (Drain Pump) on page 19. Is pressure hose pinched, kinked, plugged, or leaking air?Is pressure hose pinched, kinked, plugged, or leaking air?Is pressure hose pinched, kinked, plugged, or leaking air?
Oct 03, 2016 | Whirlpool Washing Machines
Why is the hot water pipe dripping after tighening up.
First the is a hot and cold water pipe. To those are connected hot and cold water outlet bib valves to which are connected, respectively, hot and cold water hoses going to (or you could say, coming from) their respective connections to the washer. Correct this if I am wrong but, it appears you might be talking about those hose connections to the water spigots but calling them pipes, not hoses. If that is true, you contecture is correct: it is most typically a worn out hose washer or o-ring and replacing that item should correct any dripping. By sure the part is characterized for hot water.
Oct 28, 2014 | Washing Machines
"No inlet" light is on.
When pipes are disturbed, often times debris is knocked loose from inside the pipes and ends up blocking the inlet screens on washers, etc. Turn the water supply off to the washer, remove the hose from the back of the machine, and look for a plugged screen right there where the hose connected to the machine.
Jul 30, 2011 | LG WD-3243RHD Front Load Washer / Dryer
It is leaking water from the bottom as it washes
Plug off the mains. Open up the washer top & behind. There should be a loose or torn rubber pipe. Examine all hoses (pipes), including door seal. Three pipes go from the inlet to soap holder, below the drum you will find a big hose to the filter and pump. If you cannot find anything turn the machine on (keep kids away, locked out). Run the machine without clothes or soap to observe where the leak comes from. You can either tighten the hose, with mains off or replace the hoses. Try sites below for spares with make & model number, depends where u are.
marcone.com
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Feb 12, 2010 | Zanussi FJS1225W Front Load Washer
Washer still has lots of water in it at the end of the spin cycle. Also, we notice bad oder each time the washer is used. Are these related? How do I fix this problem?
The most common problem is the water pump is malfunctioning and not allowing the water to drain all the way out, if the machine sits over a week the water turns sour and smells bad. so check that the pump is not plugged up and check that the pipe from the pump is not plugged up. if hose is not plugged up and the belt on the pump is tightened up it could still be a bad water pump so I suggest you replace it. Also with a water hose push water threw the drain pipe in the wall to see if the pipe is plugged, it should take full water hose pressure without a problem, if it backs up then you have a plugged drain pipe. remove the drain pipe form the hole in the wall and push hose onto the water hose put washer on spin and have other end off the hose bib, watch the water flow as it pumps water out of the spin cycle if the water does not come out fast than you have a bad pump or a bad water pump belt. since it won't drain all the way this will cause the water to smell sour.
Dec 13, 2009 | GE Washing Machines
Electrolux dishwasher won't drain. Not a clog in the outlet hose or drain pipe.
The drain hose on a washing machinemag-glass_10x10.gif connects the drain pump to a stand pipe, a U-pipe under the sink, or another place for draining dirty water into the sewer. If your washer won't drain properly, the problem is sometimes an object blocking the drain hose, like a pair of underpants, a child's sock, or pieces of something that broke up in the washer.
  1. Unplug the washer and put the plug on top of the machine to keep it out of any spilled water.
  2. Step 2 Take any wet clothes out of the washer and bail the water out of the drum with the bucket. The washer may be too heavy to move if it's full of water and wet clothing.
  3. Step 3 Pull the washer out from the wall enough for you to get behind it.
  4. Step 4 Remove the plate from the back of the washer by taking out all the screws. Different brands and models of washers vary in how many screws hold on the back plate, and not all models require removing the plate to get to the pump where the hose is attached.
  5. Step 5 Locate the drain hose. Of the three hoses coming out of the back of the washer, the drain hose is the largest in diameter and is attached to a drain pipe instead of a faucet.
  6. Step 6 Check the drain hose for kinks and bends. These are often the cause of a blocked or slow-running drain hose.
  7. Step 7 Remove the drain hose from the washer by detaching it from the drain pump. You will need a screwdriver or a slide-lock wrench to open the clasp that holds the hose to the pump, depending on what type of clasp it is.
  8. Step 8 Keep the bucket nearby to catch any water that comes out of the drain pump when you remove the hose.
  9. Step 9 Remove the other end of the house from the pipe it drains into.
  10. Step 10 Bend the clothes hanger open so you can use it to poke inside the hose. Push or pull out the material that's causing the blockage.
  11. Step 11 Replace the hose and run the washer to check if it's clear.
Nov 13, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Washer tub will not fill with water and cycle timer operation seems erratic.
it's being sucked out by siphoning through your sewer pipe .Probably a siphon problem . Check your drain hose to make sure hose is not stuffed too far down drain and air can get between the hose and the drain pipe . If you have tapped the hose to the drain to keep water from coming out the drain pipe , go to home depot or an appliance parts house , and get a siphon break . When a washer fills , but water level doesn't rise in the machine ,
Aug 24, 2009 | Washing Machines
How do I disconnect the washing machine?
the pipes are connected to the water pipes there should be a red one and and blue one. or the taps on the pipes are sometimes coloured. turn the taps so that they are not running level with the pipe. or the other way than they are now. they will stop at the right point. unscrew the hoses at the pipe end white plastic ridged screw caps you might need a gripping spanner. make sure as you take each one off you do not loose the washers inside there. black rubber things, the drain should just lift out but have a bucket ready because when you put the pipe on the floor lots of water will come out of the pipe. hope that helps. liz
Mar 28, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Error code 20 on Kenmore C47192 front loading washer
F20 is an indication of low water flow. Check that the screens in the hoses or the valve at the back of the washer are not clogged. Mineral buildup in the water lines can break free, causing the screens to plug.
Press Stop twice to cancel any cycles, unplug the washer while you check the hoses, then plug back in.
If you find plugged hoses, then you should not have any additional problems. If you didn't, check to make sure there is adequate flow from the wall valve by removing the washer drain line from the wall drain pipe, put the washer end of the water hoses into the drain pipe one at a time, and turn on the faucet to assure there is good flow. Be sure to hold the hose into the drain pipe.
Jan 19, 2009 | Kenmore 43142 Front Load Washer
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
