Question about Hotpoint NBXR463EBWW Electric Dryer
It wont turn over
I turn the start knob over and it just makes a buzzing sound so i dont know if something electric is wrong with it or what so can u please help. thank you.
  • Anonymous May 10, 2008
    I turn the start button and the dryer will not come on.
  • daletrnr Sep 26, 2008
    put coil on and put dryer back together will not start belive wire my be in wrong place
  • 625 Answers
If you can do repairs, take off the front cover and remove the belt off the motor then try starting it. if the motor spins then the problem is the rear drum bearing or the felt "bearings" on the door. if the motor does not start even with the belt off, the start wining on the motor is burned up. replacing the motor costs around $150.00
Posted on Sep 22, 2007
SOURCE:
Kenmore gas dryer model 84152 wont start
-Make sure turn select knob to correct position.
-try again.
Good luck
Mai
Dec 16, 2013 | Kenmore 800 7982 Dryer
I have a maytag dryer that will not start. When I push the start knob, I get a buzzing noise that sounds like there is something wrong electrically behind the control panel. I took off the panel in the...
http://allrepairmanuals.com/maytag-dryer.htm?model_number=MDE308DAYW
Hi, what you describe indeed sounds very bad, and should be looked into asap, to do this yourself you will need a service and repair manual, accordingly i have provided a link above for you to obtain one.
You will need to be very careful, as with any electrical fault, the service manual has troubleshooting steps for you to follow so you can isolate and repair your problem.
Buzzing noises usually have to do with the motor, or gears belt etc.
Also to help below is a DIY website that will help you also
.http://www.acmehowto.com/howto/appliance/dryergoe.php
Feb 01, 2011 | Maytag MDE308DAYW Electric Dryer
On super mario bros on the last castle in world 8 what do you do?
hi, i take it your going on about the part where you keep going but you dont get anywhere what you need to do is turn the sound up so you can hear it bleep when you go a wrong way.
you have three platforms you can run across top middle and bottom now only one of them is correct if you choose the wrong one it will make a short buzz sound but if you have picked the right one it wont make any sound you need to remember or write down which is the right one as when you hear the buzz you have to start off at the start again, so say the first one is top and the second is middle but if you choose top again on the second one it will buzz and you will have to start all over again.
so if you take the top and it dont buzz you know thats the 1st one then on the 2nd lot if you pick the middle and it makes the buzz sound you know you have gone wrong so then it starts again so you choose the top again then choose the bottom on the 2nd section if this dont buzz then you know them 1st 2 sections you got right but then if you get the 3rd wrong you have to start all over again so for example you know the 1st one is top and the 2nd is bottom so on the 3rd section try another level such as bottom again then if that dont buzz you got it right and so on,
i think their is 5 different sections you need to get right before you get to the final bowser.
i hope i have got the right mario im just going back a few years when i had an old nintendo.
let me know how you get on or if you need further assistance ok
please rate this solution and leave a testimonial as i have a whole page of unrated posts, thanks
Dec 08, 2010 | Video Game Consoles & Games
I turn the start knob and it just makes a buzzing sound
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 06, 2010 | GE DBSR453EBWW Electric Dryer
My dryer making buzzing sound
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 02, 2010 | General Electric DVLR223EGWW Dryer
Buzzing noise from dryer and wont start
It sounds like your motor has gone bad....it will buzz really bad when it is trying to start and cannot...
heatman101
Asker's Testimonial " Thanks so much for your help. Now that you'v mentioned it, the buzzing does sound like it's coming from the motor. I'm,now, more comfortable in call " -
Apr 12, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Maytag dryer makes an electrical buzzing noise when start button
It sounds to me like the motor is not turning, but the heating element is coming on. with no air flowing over the element, it is getting too hot. Can you operate the start switch with the top tilted up so you can see if the motor is turning but the drum is not, and just where the buzzing is coming from. Also, I would try the dryer on manual setting and on air dry to see if any setting works. Good luck
Jan 07, 2010 | Maytag MDE6000 Dryer
Amana electric dryer just stopped working. I pushed the knob, there was a loud buzzing sound, and then the dryer just stopped
The buzzing sound is the motor trying to start and not being able to. There is either something stuck so that the motor can't turn or the motor is bad. The most likely case is that the motor has failed.
You can trying turning the drum by hand and make sure that it is free. Also by turning the drum you will sometimes get the motor off of a "flat spot" in the motor and it will run for a while again.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Nov 30, 2009 | Washing Machines
Turned knob and got a buzz. turned knob again and no sound. Just finished a load and was starting on the next.
Hi. im assuming the buzz came from the timer knob(behind the knob). if so, this will confirm timer failure and, you will need to replace this timer control module in order to restore proper function to your unit.
If the buzz was located behind the start switch, replace as well.
May 21, 2009 | Hotpoint Dryers
Hotpoint NBXR463EBWW Electric Dryer Logo
106 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Archie Ferrarini
Archie Ferrarini
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
