Question about Toro& Electric String Trimmer
String replacement ran out of string
Just bought gt 225 and cannot remove string from easy loader
Hi Mark,
Take it back for a replacement/refund. It shouldn't be like that when it's so new.
Jul 19, 2015 | Garden
How do I thread the singer 132k6 including the bobbin. is there a diagram i may see
Hope this sight will help if not you may have to contact the manufacturing company for owners manuaql
Jan 09, 2015 | Singer Sewing Machines
How to replace the string in grasshog xp electric trimmer
Ran into the same problem recently and discovered that one solution was to use a standard adjustable wrench and grasp the center, leveraging off the spool cover. If you look closely at the spool it is tapered so the very top of the hole in it is actually slightly smaller that the spool cover point it slides over letting it seal pretty tight over time.
May 21, 2013 | Black & Decker Black and Decker & Grass...
String trimmer leaks fuel
the primer bulb could be your problem. easy to replace
Apr 06, 2017 | Garden
Brush not spinning
Remove the bottom plate to see if the belt came off of the motor shaft, or perhaps it broke in two when the brush stopped turning. Hope this helps!
Jun 28, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
My machine ran over some string,made a funny noise and emitted some smoke,the hand suction pipe at the rear works perfectly, the motor runs fine,but the front of the vacuum will not work.thankyou very...
the string bound up the beater bar (brush), keeps the belt stationary, and the motor spindle is just rubbing against the belt and melting it. remove the belt guard, remove the brush, and the belt. clean off the brush bearings (at the ends of the brush) of the string and make sure the ends spin freely from the brush. replace the belt with a new one, and put it all back together.
Aug 17, 2009 | Panasonic Vacuums
St185 Homelite string trimmer starts then dies
I resolved my problem by taking apart the carborator and cleaning it. There were clogged passaged that had stuff come out of them when I used airisol carb cleaner to blow them out. I only had to make one gasket the carb mount gasket which is pretty basic only 5 holes.
It ran for the next 3 hours, ran fantastic!!!!!!
Jun 13, 2009 | Homelite Garden
Homelite string trimmer mighty lite
does it have spark? did you replace the plug?
Apr 29, 2009 | Homelite Mighty Lite Lawn Trimmer
Trimmer won't run - B&D CST2000
could be loose connection in the motor due to vibration.
Jul 07, 2008 | Black & Decker String Trimmer Cordless 12"...
Toro& Electric String Trimmer Logo
88 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
