Question about HP 49g+ Calculator
Flash update Everytime I turned on the calculator, it says "flash needs update" 1)USB 2)SD card, I tried inserting the surveying pac sd card by d'zign but it does not recognize it. Where can I have it updated?
I had the same problem with my hp 49g+. I don't know how to solve it using the sd card, but you can use the usb. Check this forum:
http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv014.cgi?read=66698
Posted on Apr 03, 2008
How to view contents from flash drive
There are external memory card readers, you can connect to any USB port of all modern computers. Perhaps even your flash drive has an USB connector, so you can put it in an USB slot from the computer.
If the flash five is a mini or micro SD card, you need an adopter from Mini (Micro) to SD ann that combination should be inserted in the external memory card reader.
Sep 26, 2014 | Electronics - Others
Hi i have my memory card password forget
you can unlock your 2gb sd card..
1. Insert the sd card into a software phone. (eg. Nokia 6120c, 5800, 5233 etc..)
2. Select settings > data mgr > memory > options > format memory card..
Note- formating memory card will delete all datas in your sd card
Sep 24, 2011 | SanDisk 2GB microSD Memory Card
When i try to format my micro sd card system shows remove write protect how can i format it
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
I hope this helps.
Aug 09, 2011 | SanDisk 2GB microSD Memory Card
HP 49G+ trying to dowloading a surveying program from hpcalc.org. Unfortunately Xmodem Transfer cannot locate my calculator. I have ran through the troubleshooting hints, to no avail. Thanks, Brian
Why not use the SD card slot on the calculator? Use an SD card formatted in FAT 26 or FAT 32 of not too large capacity, say up to 2 GB. Using a computer, transfer the program on the card and store it at the root of the card: DO not store it inside a folder.
Once the program is on the card, remove the card from the computer and insert it in the SD card slot of the calculator. Turn calculator on and use the file explorer of the calculator.
Press Green Left Shift followed by the APPS key to enact the Files explorer. Navigate to the root of the SD card, copy your program and drop it in one of the three internal memories. IRAM, ERAM or FLASH
Jul 27, 2011 | HP 49g+ Calculator
How to format corrupt memory card?
You will need a card reader (unless your PC has an SD/MCC slot): 1- Insert the SD into slot or into the card reader and then insert the card reader into a USB port. (please wait for few seconds) 2- Click on Start - RIGHT click on MY COMPUTER -Choose Manage 3- Look at the left information pane and click on STORAGE 4- You should see all your drives on there to include the SD drive 5- Right click on SD drive (it should show you the path ie E:\, D:\ etc and the size 1-2-4-32 GB etc...) 6- Choose FORMAT (There will be a drop down menu, please choose NTFS) and wait for it to do it's thing (this is irreversible) Wait till you see the words HEALTHY PARTITION (followed by the drive name) You are done! Have a great day!
Apr 27, 2010 | SanDisk 2GB microSD Memory Card
Cant copy movie to it
pls insert the micro sd card to ny phone and format it and then connect it to the computer and check the followings.
1) whether the usb is recognizing ur card
2) right click on the mass storage drive created under my computers and select properties
3)update driver
4) now try copying the movies.
it should delinately work
thanks and reply back ur experience
Apr 20, 2010 | PNY 2GB microSD Memory Card
Trouble in formatting my SD micro sd for my lg chocolate cellpfon
use some other card reader for the purpose and format it from there.
Feb 14, 2009 | SanDisk 2GB microSD Memory Card
Cannot detect SD flash memory
plzz check with some other SD Card and if that card also doesnt works with it than plzz check the drivers for the SD Flash
Jul 07, 2008 | Acer Aspire 1690 Notebook
Unit will not boot past Magellan splash screen
try to press the reset button on the left side next to the usb port with a small paper clip or toothpick and see what happens and see if it did is firmware update,if not do it over and the unit plugged in with powersupply and the usb and leave it alone and let it reset a few times until it says to unplug from the usb .for the sd card make sure is a flash sd card.i have a mastreo 4000 with a 2gb sd flashcard and it has no problem.theses units has unlimited amount of any size of gb sd flash card.let me know what happens.
Mar 02, 2008 | Magellan Maestro 4040 GPS Receiver
HP 49g+ Calculator Logo
429 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
