Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
No Suction The water/soap solution dispensing just fine but when I pull the machine back over the water solution, it is not being sucked up (usually it is easy to see as it you can see the water being pulled up through the clear plastic)
  • Anonymous Apr 26, 2009
    This has occurred with two Bissells now. I am leaving the Bissell brand for good.
  • amerish Apr 26, 2009
    no suction to get water out of the carpet had to use the old "nothing sucks like a hoover" thank god throw out bissel will go buy a NEW HOOVER
  • 25 Answers
It sounds like the lint filter is clogged. It is located on the top clear plastic piece (the one with the dial to switch from floor to tool use) and is on the underside. It is a small (1 inch square) red plastic piece with a little door on it. Flip open the door and it is probably clogged with hair, carpet fibre, etc.. Clean it out and hopefully you will have suction again.
Posted on Sep 18, 2009
Will not suck water out of carpet
take the tank off and make sure their is suction coming through the suction port. While you are there make sure the rubber seal is on it. Let us know if this is not the problem and we can go from there.
Sep 13, 2014 | Bissell 9400 ProHeat Upright Wet/Dry...
Powerwash Powerbrush machine not sucking
It might be clogged, but you would be able to see the clog through the clearview water suction area. There are a couple areas to check:
1. The black gasket where clearview water collecting unit and the base's front meet.
2. Check if you're getting sufficient suction: remove the water collecting unit. When you turn on the the unit, you'll feel suction out of a black hose pointing upwards next to the grey dial. If you're not getting sufficient suction you need to check that all the gaskets are seated properly. there are 3 gaskets: (1) an orange one seated between the black hose and the base unit (2 and 3): On the bottom of the unit there is a removeable panel. This panel has a gasket (red) and inside there is a white gasket.
Jan 11, 2010 | Bissell 9200 Upright Vacuum
Wont spray soap
Please look at my other posts for this solution
Aug 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Soap from dispenser will not release into carpet cleaner.
These are two different problems the first could be a clogged heater soap coagulates in the heater passages and clogs the flow of water to see if this is indeed the problem turn the unit on and try and spray water with the top trigger (floor nozzle) then try to spray at the hand nozzle if you get water at the hand nozzle but not the floor nozzle it is the heater. The hand nozzle water bypasses the heater. Also check the solution or soap tank if you pull it out and there is not red seal on the bottom it may be stuck in the machine and won't create a good seal check to see if it is still in the hole where the tank inserts. As for the unit not turning on that could be a number of issues cord,switch or just over heated. Visit www.stevessewandvac.com for any parts or questions about this machine or any other.
Aug 13, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Water will not suck back up
try vacuming the water up w/out adding water our anything else to the machine
Mar 17, 2008 | Bissell 1699 ProHeat Clear View Upright...
Can't get water to spray out of the hand tool nozzle
When you attach the main suction hose to the front of the machine, you also have to connect the soultion hose to a valve located on the side of the machine. When the machine is running, take a small screwdriver and depress the centre of this valve. You should get a spray of water out of the valve which will confirm the valve and pump is working. Now, connect the small solution hose, making sure you push it on all the way. When you pull the trigger on the handle of the hose, you should get spray. If it does not, you may have a plugged nozzle sprayer.
Feb 16, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Will not dispense soap from handle
The soap dispenser, on the side, make sure the seal is on the bottom of it and not in the hole. You may have to replace the valve asm for the dispenser part # 2101795
Sep 30, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Not dispensing water and no suction
I'm assuming the belts are OK.... Your heater is clogged. Unplug the machine and let it sit for 30 minutes. Take the handle apart, there will be a 4 inch by 8 inch metal box inside. This is the heater. Remember I said to let the machine sit for 30 minutes? If you didn't, the heater may be EXTREMELY hot!! Disconnect the two hoses going into it, and clean the metal pieces out (that the hoses connected to) with a needle or very small drill bit. You may want to remove the 6 or 8 screws holeding the heater together and remove the cover to clean it out. Reassemble and fill both tanks with VERY hot water ONLY and run the machine to rinse the entire system.
To prevent future reoccurences... use only Bissell extraction shampoos. Never put anything in the detergent tank except shampoo. (And only water in the water tank) Mixing chemicals with anything else turns the water/detergent mix to sludge. Also, when finished shampooing, put ONLY water in both tanks, and run the machine until one of the tanks run out of solution. Doing this rinses the hose lines out and prevents hardening of the solution in the heater ports.
I've fixed these machine for years. No dispensing is almost always the heater clogged.
Sep 29, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell pro heat cleaner
This could be due to dried out soap in the works below the dispenser. Try cleaning the hole, putting plain water in the soap dispenser to clean it out further. You could just put some soap in with the water. Be sure to run lots of rinse water through afterward to clean out the heating unit.
Aug 18, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
124 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
