Question about Dell E152FPc 15" TFT LCD Flat Panel Monitor
LCD monitor no display - flashing power button
I have a Dell E152FPc 15" LCD Flat Panel Monitor. Bought it used. It was tested and working before being mailed. When I powered it up all I had was a black screen and a flashing power button. Pushing the power button does nothing just keeps flashing. Any ideas?
  • Anonymous Apr 28, 2009
    Hate to criticize but that wasn't very good advice from a GURU. The problem is clearly related to power since pushing the power button has no effect. If it were a refresh rate problem the user would still see a POST boot up sequence.
    Problem Solver:
  • 3 Answers
Hate to criticize and then not help out. I have this exact same problem with one of my E152 Dell Displays. I have read around and this whole line of displays seemed to have trouble. I found many issues like this and no solutions.
So, I like to tinker and tinker i did. I opened the case, removed the screen and went straight to the power supply board where I found two burned out capacitors.
RATED:
Value Voltage Diameter Height
1000uF 16v 10mm 16mm
Found a great source for replacement parts and instruction to replace the caps at BadCaps.net
Let you know how it goes.
Posted on Apr 29, 2009
  • mplacchetti
    mplacchetti May 07, 2009
    GOOD NEWS JSGreen! This problem is solved.
    For about 25 cents in parts and an hour and half of dissaembly/reassembly time I am about to put my failed E152 Dell Display back in service on the shop floor.
    I boutght about 20 caps from Newark Electronics. I still have 8 other E152's out on the shop floor and judging from all the hits on the web with this monitor and this exact same problem I fully expect some of them to fail.
    Contact me if you want me to step you through the repair process.
  • 167 Answers
Hello, my best guess is that the refresh rate is set for a crt monitor. hook your old one back up, if you can. and change it to 60 hertz or 70hertz. go 2 display properties then settings then advanced; then monitor. set the refresh rate as i said and turn off the computer, hook the new one back, and you should be good to go. good luck! and please rate this solution. if you need further assistance, reply
Posted on Apr 21, 2009
  • 1 more comment
  • glenn hoffman
    glenn hoffman Apr 21, 2009
    hello, one more thing i wanted to say, most people when they replace the crt monitor with a lcd, forget or don't know this. a crt is set at about 85 hertz. the lcd monitors don't handle that. the refresh rates for lcd's are 60,70,72 hertz. so do like i said and you should be fine. have a nice day! reply if you have trouble.
  • glenn hoffman
    glenn hoffman Apr 30, 2009
    then why not offer a solution instead of neg.comment? (guest) also guru does not mean you are right all the time. and i do this on my spare time at no monetary gain. solution offered is based on past experience on flat panels of different brand. added to the shop. nothing displayed until crt was reconnected and refresh rate was set at 72 hertz. then flat panels were put back and worked perfectly! no post was displayed, just flashing power light. before that. (explain why, if the statement you made is correct?)
  • glenn hoffman
    glenn hoffman May 01, 2009
    looked over the bad caps.net site,looks like good source for parts.
How do I get rid of flashing Display mode out of range message
Terry,
That monitor only has VGA in port. So it sounds like the computer VGA out port is not sending a correct 1024 x 768 at 75 Hz signal to the monitor. The problem could be a defective video card.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 24, 2015 | Dell E152FPc 15" TFT LCD Flat Panel...
Manual monitor e152fpc
there are two resistors with copper platr attached replace them. it will mean soldering. remember. 4-12-02 on the power board well she's old.
Dec 09, 2011 | Dell E152FPc 15" TFT LCD Flat Panel...
My dell tft monitor blinks after its been on for some time what do i do
my dell lcd monitor is blink only when i power on.1second only action
Jan 22, 2011 | Dell E152FPc 15" TFT LCD Flat Panel...
My E152FPc on lite does not come on & no picture, How can I repair?
Did you check the driver is installed if there is one and all the cable is connected well? Tried another E152FPc on lite?
Dec 05, 2010 | Dell E152FPc 15" TFT LCD Flat Panel...
How do i open a Dell TFT monitor model 1505?
poginga, Try visit to YOUTUBE for video clips "lcd monitor disassembly" and or "lcd monitor repair" to get basic idea of how to !!! DO NOT USE SHARP BLADED INSTRUMENTS OR YOU WILL END UP IN THE LOCAL "ER" TRYING TO EXPLAIN THE BLOOD GUSHING OUT FROM YOUR BODY" 12fixlouie
Feb 22, 2010 | Dell E152FPc 15" TFT LCD Flat Panel...
No video. Power is good but no video signal from cpu
Try this:
While powered and connected to the computer, shine a very high powered flashlight on the screen. You should see a faint shadow of the display from the computer. If so, your inverter board or backlights are blown. If not, the LCD controller matrix may be blown. Either way, I would suggest just getting a new monitor.
Nov 20, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
My monitor do not work right
Are you saying that you can faintly see your desktop or just the reflection of your desktop??
if you are saying you can faintly see your desktop it means that the fluorescent light isn't firing up properly, take it to a repairman or if its under warranty, take it back for a swap or a refund.
Mar 24, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
After monitor is turned on, it goes blank after a few seconds...
Sounds like the cable that connects the monitor to the computer hass a loose wire connection in it.
When it turns green, try flexing the cable near the connectors and see if the color changes on the monitor. I suspect that you have a wire in the cable that was not soldered properly by the manufacture.
If it changes color, I'd contact who you bought it from and have them replace it.
Hope thid helps. Bud
Jan 08, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
DELL FLAT PANEL MONITOR
Throw it in the garbage and buy a new one.Dell sucks
May 23, 2008 | Dell E152FPc 15" TFT LCD Flat Panel...
Dell E152FPc 15" TFT LCD Flat Panel Monitor Logo
609 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
